What the Heck! Push in throttle, no response, just idles.
Title says it all. Im trying to do a coolant flush and pump coolant through the system. I started the car to do so and wanted to raise the RPM's upward of 2k to get the temps up. I go to push the gas pedal with my hand and nothing, no throttle response whatsoever. What am I missing here?
Also, Peak Global 50/50 is recommended correct (in the gold bottle)?
Also, searched all over this site for a good DIY on coolant flushes. I cant find one that explains things very well and I hear its a real PITA on these cars. Any links youd guys suggest?
Uh oh, ill start with is your check engine light on? Which of your ecm's is in control of the throttle. If you could, post up a pic of your throttle body and throttle pedal just to make sure they are stock
Do you know what all things your stand alone ecm controls?
stock TB & stock Pedal. CE Light is on due to test pipe, but dont have a scanner to check codes...ARGHH. I think the stock ECU controls idle, and the Stand alone controls throttle response.
Call up the local auto parts stores to see if they rent the diagnostic code scanners, or find someone in the area that has one. Your check engine light is on because of the exhaust but it may now have other reasons for being on as well. You may also have a wiring problem too, which is going to be loads of fun!
So I took out the plug too the throttle position sensor, noticed a few bent prongs on the inside of the sensor. I straightened them out and pushed the plug back in (I dont get that snap like you normally do with your other plugs).
Anyhow, if I have the TPS plugged in, the car wont start. If I unplug the TPS plug, the car fires right up. Also, the TPS is making a loud, noticeable mechanical hum with the plug plugged in. What the heck!
This is a new one too me. Man your gonna understand this car a lot better after you chase all these issues out.
Good luck, I'm sure you'll get it, just be sure to post pics of anything you touched on the car so the smart guys can see what's unplugged or going to the wrong hole!
Might want to start a fresh thread but in any case knowing model and year would help.
Related Threads
The Lotus Cars Community
2.7M posts
51.5K members
Since 2002
