What's this tube for? - LotusTalk - The Lotus Cars Community
post #1 of 8 (permalink) Old 09-18-2006, 08:20 AM Thread Starter
buzzy's Avatar
I was checking out underneat the front of my car to see where water could be getting into the drivers side footwell and I spotted this little tube coming out of the passenger side. Looks like a drain for the heater/ac unit, but does anyone know what it's for?
Also, is the flat vertical section behind the suspension directly infront of the footwells?
Luke
buzzy is offline
post #2 of 8 (permalink) Old 09-18-2006, 08:24 AM
0o7
probably a/c condensation
0o7 is offline
post #3 of 8 (permalink) Old 09-18-2006, 08:34 AM
Chris's Avatar
I noticed 2 black rubber tubes (not articulated like yours) on both sides of the car in around the same location as the one pictured in your thread. I always figured it was the drains for the engine lid.
I once owned a miata and the frame filled with water causing a big sloshing sound when ever I hit the brakes or accelerated. Turns out the drain tubes from where the softop met the body were plugged with a build up of leaves and other debris. Once I cleaned it out the problem went away. Maybe you have a similar problem with your Liz.
2006 Lotus Elise - CO, Sport/Touring, Ohlins double adjustable Coilovers, Adjustable Front Sway Bar, LSD/TC, Seamless Front Clam, StarShield, Hardtop, Stebel Horn, Tripoint Supercharger-10psi, Aquamist, ForcedFed Header, Sport CAT, Larini Exaust w/F1 Tips, ACT Clutch, Fidanza Flywheel, Porterfield R4s Pads, ULTRAdisc 2 piece rotors, Hoosier R6's on SSR Comp Rims, Carbon Fiber DoorSills/CenterConsole/AC Control Surround, Fire Extinguisher, Garmin NUVI.
1997 BMW M3 - Downgraded to Winter Beater.
Chris is offline
post #4 of 8 (permalink) Old 09-18-2006, 09:11 AM
nugg_dawg's Avatar
correct!
John
nugg_dawg is offline
post #5 of 8 (permalink) Old 09-18-2006, 09:15 AM
TimMullen's Avatar
That's because that's what it is. The corrugated tube (looks like the kind that wiring goes into) is the AC drain.
94 Miata R Package - Black
TimMullen is offline
post #6 of 8 (permalink) Old 09-18-2006, 03:01 PM
Chris's Avatar
Just realized the picture of your tube is at the front of the car. The tubes I spoke of are in the rear, probably drains for the boot lid.
Chris is offline
post #7 of 8 (permalink) Old 07-20-2013, 02:09 PM
Where does this hose go through, to attach to the AC condensor/heater core unit?
05 Elise, Chrome Orange
RelativePants is offline
post #8 of 8 (permalink) Old 07-21-2013, 09:59 AM
I'll answer my own question. This tube connects to the AC unit, and goes through the arch in the plastic piece nearest the cabin.
I had pulled this out when replacing my resistor pack, and was able to put it back in with a helper, my iPhone (to check position under the A-arm pivot), and a long flexible grabber.
To replace tube:
1) With AC unit removed, push the end of the tube without rubber coupler through the arch, you will feel it hit the back of the extrusion to which the A-arm pivot connects. At this point, push the tube toward the passenger side.
2) Check that the tube is underneath the A-arm pivot, if yes proceed. If not, pull it back through the arch, and try again.
3) Have a helper hold the tube, so you don't pull it through the arch. Use a grabber to grab the end of the tube, and pull it into position.
4) Temporarily tape the tube in place near the A-arm pivot, to avoid pulling it back out.
5) With AC unit partially in place, connect tube to the bottom of the AC unit. There is a hole where it attaches, and a rubber plug on the other side.
