Any one have the LETSLA Short Shifter Linkage? - LotusTalk - The Lotus Cars Community
post #1 of 23 (permalink) Old 04-08-2012, 10:43 PM Thread Starter
blueboxracing's Avatar
Looking to see how much of a difference it makes... Any one local to the Seattle area have this installed?
- Jesse
blueboxracing is offline
post #2 of 23 (permalink) Old 04-09-2012, 03:28 AM
it makes a huge difference. i installed mine a few years ago. i've driven about 50/50 street/track miles. the shifting has a much better feel with a shorter throw. i have had no problems with the LETSLA product.
Jason
06' Fed Elise
My frame, rear subframe, steering rack, A-arms, front crash structure, suspension uprights, and fuel tank are stock.
jasondew is offline
post #3 of 23 (permalink) Old 04-09-2012, 03:43 AM
4380r's Avatar
- Jesse
I had the very first production unit on my car. Troy installed it for me. I know you're looking for a local car you can actually test drive to see how it feels. I can tell you that it DOES make a difference. It engineers out a lot of the 'slop' on the linkage on the trans., but does not address the mediocre shifter itself, beyond recommending the stiffening bolt.
I found the key to the LETSLA working as it should is the adjustments of the cables. That can be a bit tricky.
Owned, loved, enjoyed, and now gone:
1969 Europa S2 Blue
1970 Europa S2 White
1974 Europa Twin Cam Blue
1984 Turbo Esprit Calypso Red
2005 Elise Starlight Black
2005 Elise Saffron Yellow
2005 Elise Ardent Red
2006 Exige Graphite Grey
2007 Exige Canyon Red
Other:
1970 MGB GT
1970 Datsun 510
1984 Honda CRX Si
1984 Pontiac Fiero
2004 Chrysler Crossfire
2009 Pontiac Solstice Coupe
4380r is offline
post #4 of 23 (permalink) Old 04-09-2012, 04:19 AM
Relapsing Honda fan
yellow99s's Avatar
I'm not local but I'll tell you after spending another hour last week adjusting mine, I still wish I hadn't purchased it. Now I'd spend the money on new aftermarket cables instead.
yellow99s is offline
post #5 of 23 (permalink) Old 04-09-2012, 08:16 AM
MotoGeek's Avatar
You can try mine sometime. I'm not a big fan of it. It's fun for casual driving because it feels "racey" on the short setting, but it takes away a lot of the feel and precision resulting in more frequent missed shifts. Someday I'll get motivated and reset it to the stock throw, where it will probably show a bit of improvement over stock.
MotoGeek is offline
post #6 of 23 (permalink) Old 04-09-2012, 08:55 AM Thread Starter
I was considering doing the RaceMounts4 from S111 first to try to clean up some of the slop. For those who have it, do you feel like it made enough of a difference to do both at once?
MotoGeek - Are you ever at at any of the local track events?
post #7 of 23 (permalink) Old 04-09-2012, 10:34 AM
spf4000's Avatar
Stiffer engine mounts make more of a difference over the LETSLA. Anything other than the "default" settings on the linkage can cause binding and lead to failures to the link assembly or cables. I still have mine on because I got it to work OK, but I've seen a few failures. The major issue I've seen is the pivot bearing popping out because the aluminum bracket housing the bearing is too thin, causing the bracket to warp. They may have dealt with this issue on later models, but the early ones I've seen were prone to this issue.
spf4000 is offline
post #8 of 23 (permalink) Old 04-09-2012, 11:19 AM
XHILR8N!'s Avatar
Parts look great and feel great in your hands. Adjustability is nice.
I really did not realize it as a huge improvement though.
As said earlier, stiffer mounts helped. But these are track only for most folks. Lots of vibrations, buzzing. Sort of cool though.
2005 Elise LRG, track prepped ,
2016 370Z Nismo
2013 Bentley Continental GT Speed 2019 Lexus LC500
XHILR8N! is offline
post #9 of 23 (permalink) Old 04-09-2012, 11:33 AM
Giantmcm's Avatar
I have had the letsla for almost a year now and I have to say I LOVED the improvement over the factory feel. It is very crisp/exact in feel.
I had it on the suggested short throw setting, and loved it. However I did have misshifts and so I took mine up one bolt hole pattern to see if I like it better. After driving on it for a month, I am going to take it back to the short shift setting, but I am going to let a little more cable out. I think that is the only reason for it being "off" for the mis shifts. Cable adjustments are the key to making it feel "Perfect."
I also have engine mounts (innovative front and rear) and love the way the car reacts with the changes. I personally did not see that much of an improvement with the shifter when I installed the motor mounts, but all in all I would give the letsla kit props for being a great design and comfort feel. The one thing I can definately encourage is putting a heavier shifting knob on the shifter. That was the LARGEST improvement I ever felt.
Also, you are more than welcome to drive mine when it is done.
Maverick ML8 - Other daily
Giantmcm is offline
post #10 of 23 (permalink) Old 04-09-2012, 11:48 AM
FWIW, based on my reading of the various threads on the LETSLA it seems that most of the folks that say "huge improvement" have older models, most commonly '05 or '06 Elises. There are also some comments to the effect that Lotus improved the stock shifters, maybe MY '07+? I've never seen anything definitive on this. I really can't say myself, since the only Lotus I've ever driven is my own. But I can say that I think my '08 Exige shifts pretty well, certainly well enough that I'm not willing to risk creating a problem where none currently exists. YSMV.
-Ed
'08 Arctic Silver Exige S240
AustinP is offline
post #11 of 23 (permalink) Old 04-09-2012, 11:49 AM
MotoGeek's Avatar
I don't get out to the track much, but I was considering checking out the ridge in a few weeks.
MotoGeek is offline
post #12 of 23 (permalink) Old 04-09-2012, 01:09 PM
elise/europa's Avatar
I have the Letsla as well as the heavier cable... just perfect...
Until this year, the car was with the letsla, it was very nice, a lot better than stock.
Elise 2006, white, K20 turbo GT3076R, 395 whp
elise/europa is offline
post #13 of 23 (permalink) Old 04-17-2012, 10:41 AM
I've got it on my car, I live in Kenmore if you want to feel it.
- 2005 Elise
- 2001 Toyota Tacoma
- 2008 Toyota Yaris
- 1961 VW Dune Buggy
Twizzstyle is offline
post #14 of 23 (permalink) Old 01-23-2014, 04:42 PM
Stealthy Blackmobile
freshyip's Avatar
Anymore updates and feedbacks? Want to buy it now!!! Where to buy???
"...Make Every Road Your Own....."
2007 Lotus Exige S
freshyip is offline
post #15 of 23 (permalink) Old 01-23-2014, 04:52 PM
Monkeywrench
post #16 of 23 (permalink) Old 01-23-2014, 05:36 PM
Exiged's Avatar
I have a used one for sale
Sent from AutoGuide.com App
DIY 2007 Exige S K20A2 C38 Rotrex
Www.onetonracing.com
Exiged is offline
post #17 of 23 (permalink) Old 01-23-2014, 05:56 PM
freshyip's Avatar
Hi exiged!
I have a 2007 Exige s too, how do u like it? Very interested in your sale, how much u want for it? Thx!
2007 Lotus Exige S
freshyip is offline
post #18 of 23 (permalink) Old 01-23-2014, 06:09 PM
tomrev's Avatar
It's the first thing I did after getting my '05 five years ago. I made my own stiffener for the shifter, which fixed a lot of the slop, added the engine mounts, then got the LETSLA, and installed in the positions it came set with. It is a well made piece, and I'v been happy with it, zero issues. I couldn't believe how crappy the stock '05 shifted, but now the car is much improved.
tomrev is offline
post #19 of 23 (permalink) Old 01-23-2014, 06:12 PM
freshyip's Avatar
I always feel that the stock shifter feels like its about to to dismember on its own and shatter in pieces due to its tinny noise lol, so what u saying is that the short shift kit, also took this away??
2007 Lotus Exige S
freshyip is offline
post #20 of 23 (permalink) Old 01-23-2014, 06:14 PM
ErictheBastard's Avatar
I've done 80K miles on mine with ZERO issues. The cable adjustment was easy (only had to make an adjustment on the crossgate at the shifter side to properly affect the reverse lockout and 1-2 alignment. No binding, no cable failure, HUGE improvement over the factory vagueness and slop. Go for it.
I removed my Manley Mount inserts. As I use the car for more touring than track, I found the vibration and noise transference of the mounts absolutely intolerable.
Eric the Bastard, Esq.
Sylmar, CA
2005 Chrome Orange Buzzbomb
Larini SE Exhaust LETSLA shift kit Exige Seats LSS Wheels
Lift Point Kit and Jack Helper
Difflow 5-Element Diffusor
ErictheBastard is offline
  LotusTalk - The Lotus Cars Community > Community > Regions > Northwest Region
