someone want to give some mechanical help in colorado springs - LotusTalk - The Lotus Cars Community
post #1 of 7 (permalink) Old 07-12-2015, 07:40 AM Thread Starter
Hi
I could use some help with bleeding my brakes. I seem to keep getting it wrong. i can provide a six pack of good beer or some cash in return
thanks
Ed
Colorado springs
lotus90 is offline
post #2 of 7 (permalink) Old 07-12-2015, 08:13 AM
Nein Kinder
Glen's Avatar
Check your PMs.
Glen
2011 Lotus Elise SC
Glen is offline
post #3 of 7 (permalink) Old 07-12-2015, 08:13 AM
sturgeongeneral's Avatar
I would help if Iwas close. It would be a one person job if you pick up a power bleeder. Sirlotus here on the site sells EZbleed. Since it is at least a yearly pm to bleed the clutch and brakes it is worth it. Good luck to you!
05 Elise
56 VW Dune Buggy
[email protected]
sturgeongeneral is offline
post #4 of 7 (permalink) Old 07-12-2015, 09:18 AM
glb
glb's Avatar
How to Bleed Brakes:
Note that many people disagree with my method, so judge for yourself.
Taught to me by semi-famous Toyota engineer, who built championship winning cars and bikes.
1. Get Sears brake bleed kit (canister, hoses, adaptors for bleed valves) and their hand vacuum pump. Kits there have both components. Inexpensive.
2. Pour a little b/f in canister, hook up hoses and use the tightest adaptor you can.
3. Pump vacuum to 20-25Ē with bleeder valve closed.
4. Tap caliper with small hammer or similar. This releases the air bubbles clinging to the caliper into the stream. WHATEVER method you use, DONíT skip this step.
5. Open bleed valve.
6. When vacuum is almost gone, close bleed valve.
7. Check level in master cylinder. Do this often.
8. Repeat as needed.
Benefits:
*Never got a firmer pedal using any other method.
*Requires only one person. Your wife/so will thank us both.
*You will not be pushing the piston in m/c into the rough area normally unused, thereby not prematurely wearing that seal. (Clutch m/cs are always used to full range.)
Note: On my Elise, I neednít even remove the wheels.
Yeah, yeah, people use pressure bleeders, but my racecar mechanic friends donít like these.
Yeah, I know about speed bleeders.
The above is my opinion. No responsibility for screw ups, injuries, maiming or deaths.
Take it, leave it. OK with me.
glb is offline
post #5 of 7 (permalink) Old 07-12-2015, 06:28 PM
Addict
LostPawn's Avatar
Happy to help if we can find a time that works for boh of us, have a power bleeder. If you do not already have it sorted with someone else let me know.
LostPawn is offline
post #6 of 7 (permalink) Old 07-25-2015, 08:48 AM Thread Starter
Glen help me get the brake bleeding correct. thanks for offers. I ordered a pressure bleeder as my vacuum bleeder just does not work.
lotus90 is offline
post #7 of 7 (permalink) Old 08-03-2015, 06:24 PM
Jasonmiller's Avatar
OK, now that the brakes are resolved who wants to help to a timing belt change on an esprit ? ;-)
1985 Lotus Turbo Esprit
1991 Lotus Elan M100
Jasonmiller is offline
  LotusTalk - The Lotus Cars Community > Community > Regions > Rocky Mountain Region
