Traded my sparco wheel for.... - LotusTalk - The Lotus Cars Community
 1Likes
  • 1 Post By kfennell
post #1 of 8 (permalink) Old 04-10-2019, 11:07 AM Thread Starter
RyanDanger's Avatar
I finally got my new AIM Formula 3 wheel in!!! This is complete overkill for cruising backroads but its pretty awesome!!! I fell in love with their products when I integrated their technology into my FFR Daytona Coupe, so it was only fitting to add this to my Elise. I will post up more pics to this thread once I get it installed.
RyanDanger is offline
post #2 of 8 (permalink) Old 04-10-2019, 01:08 PM
@RyanDanger How are you driving the lcd screen? Does that require an EVO logger or direct connect into ODB/CAN?
Do you have an AIM dash display as well?
mwehnes is online now
post #3 of 8 (permalink) Old 04-10-2019, 01:20 PM
kfennell's Avatar
Yes it requires an Evo4s/5 I use a 4s, I don't know why you would need a dash display as well but you could.
Formula Wheel 3 is awesome...
kfennell is offline
post #4 of 8 (permalink) Old 04-11-2019, 11:39 AM Thread Starter
RyanDanger's Avatar
Here is the ecu bridge that connects into the OBDII
post #5 of 8 (permalink) Old 04-11-2019, 12:33 PM
Addict
LostPawn's Avatar
I want one of those wheels too, looking forward to installed pics. I seen a few cars with this but few pictures of the actual install or what is all involved.
Edit: Does this work well with the stock steering ratios or does it need a quicker ratio?
LostPawn is offline
post #6 of 8 (permalink) Old 04-11-2019, 12:39 PM
kfennell's Avatar
What is involved in the install depends. Do you want more then the following info?
ECU_1 CU_SPEED Speed value
ECU_2 CU_RPM Engine speed
ECU_3 CU_FUEL_IST Fuel level
ECU_4 CU_FUEL_AVE Fuel average
ECU_5 CU_ENGT Engine coolant temperature
ECU_6 CU_SF_LIGHT Shift light
ECU_7 CU_MIL_LIGHT Malfunction Indicator limiter light
ECU_8 CU_OIL_LIGHT Oil light
ECU_9 CU_TC_LIGHT Traction control light
If so you have to add the sensors, then the difficulty can get higher and higher.
If you are OK with that then it is just a matter of powering the main unit, feeding it an ECU signal from the ECU bridge and then getting an adapter made up for the wheel. I had BOE make me one that bolts to the factory 6? bolts and then has a welded on spline. I then use a FIA quick disconnect for formula cars to the 3 bolts in the back of the formula wheel. EZ.
LostPawn likes this.
kfennell is offline
post #7 of 8 (permalink) Old 04-17-2019, 06:22 AM Thread Starter
RyanDanger's Avatar
Okay the spacer (adapter) needed just came in as specified by AIM . They recommend using Comprent Motorsports out of Georgia since they are pretty much exclusive to AIM products etc. and have one off adapters and spacers. They shipped me the spacer which was 45 bucks.
post #8 of 8 (permalink) Old 04-17-2019, 06:27 AM Thread Starter
RyanDanger's Avatar
Now I mounted the OMP QUICK RELASE to the wheel and car. Got this part from OG Racing for 400 bucks
  LotusTalk - The Lotus Cars Community > Community > Regions > MidAtlantic Region
Similar Threads
WTB: elise/Exige Steering wheel Hub to fit Sparco wheel keinayo Parts Wanted 0 09-12-2014 10:26 AM
Traded my elise on... newman General Discussion (Lotus related) 75 01-05-2008 03:12 PM
Traded my DeLorean for an Exige Iggy Lotus Exige 17 09-26-2007 10:01 PM
Traded my car, think I got taken . . . mark.r General Discussion (Lotus related) 13 12-26-2006 09:51 AM
Traded in my Elise for an Exige pkrehbiel Lotus Exige 23 07-19-2006 10:34 AM
