Cooling fans 88 Excel - LotusTalk - The Lotus Cars Community
post #1 of 3 (permalink) Old 03-02-2017, 09:43 PM Thread Starter
Pezzer's Avatar
Well slowly working through the car i found a cooling fan not working i took it out and run it on a battery was fine. does not come on with other fan although does indicate power to fan...tried various things using different earths etc but to no avail..
Pezzer is offline
post #2 of 3 (permalink) Old 03-04-2017, 04:49 AM
Wingless Wonder
carbuff's Avatar
Perhaps the 12V you are seeing is 'back-feeding' into the fan connector?
I'd disconnect the fan connector and it's relay (it DOES use a relay, right???) and test continuity in the circuit. Be aware that Lotus' electrical connectors are not very robust. A loose terminal in a relay SOCKET is a possibility.
Also: inspect the sockets for signs of excess current (melted plastic).
Atwell Haines
'88 Esprit
Succasunna, NJ USA
carbuff is offline
post #3 of 3 (permalink) Old 03-04-2017, 10:44 PM Thread Starter
Pezzer's Avatar
Thanks went back to it today just went through the fuse box removing and refitting fuse and taraaaa its working again so tried to make it fail but seems sorted...
Pezzer is offline
