New synthetic oils in a TwinCam? - LotusTalk - The Lotus Cars Community
post #1 of 19 (permalink) Old 06-26-2011, 07:56 PM Thread Starter
EuropaFan's Avatar
Does anybody know if the new synthetic oils like Royal Purple will work in a Lotus TwinCam? Are the older style engines and seals able to hold the new super slippery oils? Same question for trans fluid?
EuropaFan is offline
post #2 of 19 (permalink) Old 06-26-2011, 08:17 PM
A1 Automotive & Smog
Harix's Avatar
I used RP exclusively for almost 2 yr now and everything is ok. It feels great on track and on regular dinner meet.
Harix is offline
post #3 of 19 (permalink) Old 06-26-2011, 08:33 PM
re: Synthetic oil
Synthetic oil for the engine is better then conventional. Do NOT use synthetic to break in an engine, especially an old one. It will not.
The myth about leaking seals is just that. Maybe less wax (bad for the engine) in the oil caused oil leaks from looser tolerances.
Always use oil grade and spec recommended by manufacturer or engine builder. This makes trans fluid trickier as the specs are less well defined.
Anton
ageshelin is offline
post #4 of 19 (permalink) Old 06-27-2011, 05:22 AM Thread Starter
EuropaFan's Avatar
This is good to know and what I was hoping to see! I run RP in my Camaro and Toyota and ran it in my Mazda RX8 when I had it. I've used it for years.
Anton
Yes I know about synthetics and breaking in an engine. Thanks guys!
post #5 of 19 (permalink) Old 06-27-2011, 04:09 PM
KazeSpec's Avatar
i prefer Amsoil over Royal Purple.
19-- Europa S2 62 Replica/Track Car Build
02 Suzuki GSX-R750 (daily/track) - current
03 Acura RSX Type S (daily/track) - sold
KazeSpec is offline
post #6 of 19 (permalink) Old 06-27-2011, 04:32 PM
DeanG's Avatar
I switched to Mobile 1 over a decade ago. No problems. The car gets light usage.
DeanG is offline
post #7 of 19 (permalink) Old 06-28-2011, 05:10 PM
BDA
BDA's Avatar
You need to make sure the oil you use is formulated for flat tappet engines which usually means it is high in zddp (zinc, manganese, and phosphates). Levels of these were reduced to enhance the life of catalytic converters and for modern engines this is fine, but there is higher pressure on older flat tappet engines like the twin cam (interesting link: ZDDP Oil Issues).
A couple of data points:
A lot of people use oils designated for diesel engines.
I was told by a guy at Red Line that they recommend their 10w40.
I started using Mobil 1 15w50.
I don't know how Amsoil or Royal Purple are in this regard. They may be fine.
You can also get a zddp additive at r.d. enterprises.
BDA is offline
post #8 of 19 (permalink) Old 06-28-2011, 06:06 PM
exarkun1178's Avatar
would the mobile 15 50 be good in the standard Renault unit in an s2?
[Ovarian Odorist] 11:12 pm: why did you ever get into your business rob...you have such great potential in the adult porn industry..
exarkun1178 is offline
post #9 of 19 (permalink) Old 06-28-2011, 07:45 PM
tvacc's Avatar
I can tell you that I have tried using synthetic in my Caterham with a crossflow and my Elan Twin Cam. That is early Elan twincam, not the 91 with the Isuzu motor.
My cars pissed the stuff out from places I did not know had leaks.
When back to Castrol 20/50, leaks stopped
You can also use the Castrol blend, or you can just put a can of synthetic in with your regualar oil. Now I know somebody is going to tell me that is wrong but my research shows it is not.
Tony Vaccaro
2005 Elise Ardent Red, www.lotusowners.com LOONY (Lotus Owners of New York) and the Church of the HolyLotus, Drive Fast Take Chances, 93 Caterham 7, 71 Elan, 70 Elan GTS, 1991 M100, 1999 Sport 190 Elise, 1974 Europa TC, 1973 Europa JPS #15 TwinCam.
tvacc is offline
post #10 of 19 (permalink) Old 06-28-2011, 08:32 PM
Moderator Extraordinaire!
tesprit's Avatar
FWIW, I concur with this and YMMV, but I turned a dry Jaguar XK engine into the Exxon Valdez within 100 miles after switching it over to synthetic oil. It actually took a couple of oil changes with conventional Castrol again to get it to stop leaking.
tesprit is offline
post #11 of 19 (permalink) Old 07-30-2011, 10:31 AM
The standard tune Twin-Cam engine doesn't require high ZDDP levels; 900 ppm of phosphorus (the actual boundary anti-wear element in the ZDDP molecule) is plenty. Since the engine requires heavy oil you'll get at least that amount of phosphorus in any oil you choose.
There is nothing wrong with synthetic oils per se, but due to their higher viscosity index they will be much be lighter in normal operation. This will translate into lower oil pressure and increased oil consumption.
For example, in my Twin-Cam Europa a switch to Mobil 1 15W-50 from the typical 20W-50 mineral oil resulted in my hot oil pressure dropping from 38 psi at elivated rev's to 34 psi and mt oil consumption from 750 miles /L to 500 miles/L.
In rebuilt Twin-Cams with valve guide seals installed, a higher pressure oil pump and tight modern clearances you can run even a 30 weight synthetic without issue but not in the original engine.
73 Europa Special
94 Caterham Cosworth VX HPC
73 Europa Special
94 Caterham VX Cosworth HPC
petermarie is offline
post #12 of 19 (permalink) Old 07-30-2011, 11:35 AM
glb
glb's Avatar
Engine oil:
When I tried the Castrol synthetic in the 90s, same as above: Many leaks.
I was able to use Mobil 1 after the engine rebuild, also as noted above.
Back then, Castrol synthetic was terrible stuff. A C&D columnist wrote a scathing column about it, based on an interview w/an oil engineer. For legal reasons, the next month a disclaimer/apology was printed. But, he was right the 1st time.
Do NOT use Redline in Elan trans: It is too slippery for synchros to work. Moreover, when I opened up the trans, having used petroleum lube, it was in great, clean shape.
Note: There is a way to get the t-c cam cover to:
a) not leak
b) be removable/replaceable without a new gasket.
this requires a bit of patience, but little more.
Driving Tips-https://www.lotustalk.com/forums/f100...art-1-a-49665/
Moss Emergency Line-https://www.lotustalk.com/forums/f100...cy-line-36631/
Safely Piercing Wires-https://www.lotustalk.com/forums/f129...esting-106438/
Bleeding Brakes- https://www.lotustalk.com/forums/f101...-brakes-241138
glb is offline
post #13 of 19 (permalink) Old 08-09-2011, 04:33 PM
CrewChief-TWR's Avatar
We use a special racing 40 weight blend synthetic not available to the general public. If you contact Castrol directly, and you race the car, they may send you some. But DEFINATELY, do not use synthetic to break in your engine after rebuild. It will not wear in properly as synthetic is much more slippery than conventional. We have also noticed our engine rebuilds last 3-4 times longer with synthetic.
CrewChief-TWR is offline
post #14 of 19 (permalink) Old 01-29-2016, 10:03 AM
I have a '73 Europa Twin cam that was stored for 5 years before I bought it and was filled with synthetic oil recommended by the sellers dealer. Well the reason was that oil tends to get acidic from sitting and was the reason for the synthetic oil, Castrol Syntec. After I started driving it, after I changed the oil with fresh Castrol Syntec, it started to leak and has gotten worse and found out that the seals in these older cars will get eaten up by the synthetic oil. I will be replacing all the seals shortly. I was told by members that this is typical of synthetic oils in older cars, Bobbythejuge
bobbythejudge is offline
post #15 of 19 (permalink) Old 01-29-2016, 10:22 AM
glb
glb's Avatar
As per post #12, I believe the Castrol to be a poor oil.
glb is offline
post #16 of 19 (permalink) Old 01-29-2016, 07:35 PM
fitfan's Avatar
jay ivy's oil is used in all sorts of twinks and bd's lents and so on. i believe, but no sure - it very similar to joe gibbs. id just call jay and ask - based on the build, time, and state of your engine.
"I really started paying attention to cars was when they came out with the Nissan Z, the first body. Then I seen the Cherokees, the old square ones, and I was like, Wow, thats cool. Then I seen the Isuzu jeeps and I seen the Wranglers."
fitfan is offline
post #17 of 19 (permalink) Old 02-03-2016, 08:28 AM
Some of the older cars are temperamental about what blood flows their veins....my rides love Rotella oil straight up!
Poorichard is online now
post #18 of 19 (permalink) Old 02-03-2016, 09:05 AM
Have you ever used Castrol R as an UCL smells great when burning
Watership Down is offline
post #19 of 19 (permalink) Old 02-03-2016, 09:31 AM
4380r's Avatar
When I bought my last Europa I swapped out the mineral oil for Royal Purple in the trans. What I thought what a tight transmission started leaking all over the place.
Owned, loved, enjoyed, and now gone:
1969 Europa S2 Blue
1970 Europa S2 White
1974 Europa Twin Cam Blue
1984 Turbo Esprit Calypso Red
2005 Elise Starlight Black
2005 Elise Saffron Yellow
2006 Exige Graphite Grey
2007 Exige Canyon Red
Other:
1970 MGB GT
1970 Datsun 510
1984 Honda CRX Si
1984 Pontiac Fiero
2004 Chrysler Crossfire
2009 Pontiac Solstice Coupe
4380r is online now
