Plugs Fouling 71 s2 europa - LotusTalk - The Lotus Cars Community
post #1 of 10 (permalink) Old 05-03-2015, 01:35 AM Thread Starter
exarkun1178's Avatar
Hello all,
So, i got my car back after three years in the shop. I picked it up Friday and later Friday brought it back because of the car back firing and running terribly.
Saturday they re did the timing and changed the plugs which were fouled.
Saturday afternoon I pick up the car again and its great (new plugs and timing is good)
Saturday night ~70 miles later the car is running bad and the plugs are fouled again. Thoughts?
[Ovarian Odorist] 11:12 pm: why did you ever get into your business rob...you have such great potential in the adult porn industry..
exarkun1178 is offline
post #2 of 10 (permalink) Old 05-03-2015, 03:59 AM
4380r's Avatar
If you haven't already check in with the guys at Lotus Europa Community, and take a look at the EXTENSIVE Europa knowledge base at Lotus Europa Central.
Lotus Europa Community - Index
Lotus Europa Central -- Home Page
Owned, loved, enjoyed, and now gone:
1969 Europa S2 Blue
1970 Europa S2 White
1974 Europa Twin Cam Blue
1984 Turbo Esprit Calypso Red
2005 Elise Starlight Black
2005 Elise Saffron Yellow
2005 Elise Ardent Red
2006 Exige Graphite Grey
2007 Exige Canyon Red
Other:
1970 MGB GT
1970 Datsun 510
1984 Honda CRX Si
1984 Pontiac Fiero
2004 Chrysler Crossfire
2009 Pontiac Solstice Coupe
4380r is offline
post #3 of 10 (permalink) Old 05-03-2015, 04:55 AM
Wingless Wonder
carbuff's Avatar
Got a pic of the fouled plugs? Are they all the same or just SOME fouled?
Here's some clues:
PS, look carefully at the causes for carbon fouling (middle, bottom row)
Atwell Haines
'88 Esprit
Succasunna, NJ USA
carbuff is offline
post #4 of 10 (permalink) Old 05-03-2015, 06:17 AM Thread Starter
definitely carbon fouled.
post #5 of 10 (permalink) Old 05-03-2015, 09:44 AM
Wingless Wonder
carbuff's Avatar
Sounds as if you have carb problems then. (too rich) <--- assuming they are ALL fouled.
What is status of carb? If recently rebuilt and jetted, could be old floats. (They are not buoyant if old, and they "sink", not closing the needle valve, allowing too much gas in.)
New floats are not part of most carb rebuild kits.
Atwell Haines
'88 Esprit
Succasunna, NJ USA
carbuff is offline
post #6 of 10 (permalink) Old 05-03-2015, 10:00 AM Thread Starter
I agree it feels like a carb issue. It is a new carb. It is jetted the same as the stock carb. Clearly there needs to be some tuning.
At idle its fantastic, and with new plugs I can run an easy 50 or 60 miles and it works perfectly. its after that it starts to act up. and the long it goes acting up, the worse it gets.
post #7 of 10 (permalink) Old 05-03-2015, 12:08 PM
glb
glb's Avatar
Did you check what I listed on BS?
Driving Tips-https://www.lotustalk.com/forums/f100...art-1-a-49665/
Moss Emergency Line-https://www.lotustalk.com/forums/f100...cy-line-36631/
Safely Piercing Wires-https://www.lotustalk.com/forums/f129...esting-106438/
Bleeding Brakes- https://www.lotustalk.com/forums/f101...-brakes-241138
glb is offline
post #8 of 10 (permalink) Old 05-03-2015, 06:02 PM
glb
glb's Avatar
New wrinkle.
The shop installed a fuel regulator. While I learned the newer side-draft Webers need less fuel pressure than the old ones, not sure if that's true about new down-drafts.
Told owner to mark the knob where it is now, then turn down at least 1/2 turn.
glb is offline
post #9 of 10 (permalink) Old 06-18-2015, 02:37 PM
I recently replaced a needle valve in my '73 Europa with the Stromberg carbs and noticed the needles sent me were a tad longer than what was previously in the rear carb. Sure enough it was actually too lean and was not starting as it should a litle adjustment for richer solved the problem. In your case it would be opposite and check the length of the needles could be shorter than originals,thus too rich.
bobbythejudge is offline
post #10 of 10 (permalink) Old 06-18-2015, 03:48 PM
glb
glb's Avatar
His is a single carb Renault engine.
I never liked Strombergs and got Webers for my Elan.
glb is offline
