2005 Elise Windshield Wiper Not Working - Fuse OK and Wiper Stalk Replaced - LotusTalk - The Lotus Cars Community
 1Likes
  • 1 Post By countryboyshane
post #1 of 12 (permalink) Old 03-26-2018, 09:44 AM Thread Starter
countryboyshane's Avatar
The windshield wiper on my 2005 Lotus Elise has mysteriously stopped working. After I found the issue, I checked the fuse in the interior, and it checked OK. From there, I replaced the wiper stalk with a new part from Blackwatch Racing. Still nothing.
Before I go "gung-ho" taking the front clam off to potentially diagnose the wiper motor, are there any obvious things I am missing that could be a simple fix? I see something called a wiper module in the wiring diagram, but what exactly is this?
I always like to ask these things as the knowledge base is deep on LT.com!
BTW, this was a really fun issue to have competing at NCM motorsports park this weekend in a downpour. Thank you RAIN-X!
2005 Lotus Elise, naturally aspirated and always at redline!
2018 NASA Great Lakes Region TT4 Champion
countryboyshane is offline
post #2 of 12 (permalink) Old 03-26-2018, 09:58 AM
cyow5's Avatar
Have you checked the connector at the wiper motor? You can reach it through the access panel without having to do any major surgery
cyow5 is offline
post #3 of 12 (permalink) Old 03-26-2018, 10:00 AM Thread Starter
What am I looking for on the connector, besides cleaning the contacts and giving it a good snug fit?
post #4 of 12 (permalink) Old 03-26-2018, 10:17 AM
BigHair's Avatar
The wiper module is a relay under the dash and it could very well be your problem. I replaced mine with another type that allows you to program the delay interval using the wiper stalk. I can provide the info after I get home.
Here is a link to the relay write-up:
https://www.lotustalk.com/forums/f129...ay-hack-22036/
Here is a link to the part:
https://www.ecstuning.com/b-kaehler-...3b0955531~kah/
If you search around I imagine you can find the part for a cheaper price
06 Lotus Elise: Ardent Red, Sport+Touring, ShiftR111, S111 TransCables, LETSLA, Driving lights
02 Honda S2000: Spa yellow, Berk Hi-flow Cat, Alpine head unit, Focal speakers
09 Honda Civic EX Coupe: Stock winter bomber
BigHair is offline
post #5 of 12 (permalink) Old 03-26-2018, 10:28 AM Thread Starter
Ah, I see where it is thanks to Sir Lotus:
post #6 of 12 (permalink) Old 03-26-2018, 10:53 AM
cyow5's Avatar
It can simply disconnect way too easily. Just a couple weeks ago another user had the same problem, and I have had it happen a couple times before. Usually it is from working near it, but my previous owner had it ziptied, haha. It'll be the connect right at the wiper motor.
cyow5 is offline
post #7 of 12 (permalink) Old 03-26-2018, 11:52 AM
BigHair's Avatar
Did a quick look at the electrical diagram for the wiper. If you donít have wipers in any position then it points to a wiring/connector issue or a wiper motor assembly failure.
BigHair is offline
post #8 of 12 (permalink) Old 04-14-2018, 03:41 PM Thread Starter
Took another look at this today and first thing I wanted to rule out, was the wiper motor assembly. Thanks to my trusty Power Probe, I sent 12V to the hot side of the wiper motor, and it's working perfectly.
I'm a little confused with how the wiper module functions. I'm assuming this relay is like any other 4-contact version, where 2 contacts are for the low current coil, which switches a switch for high current applied across the other 2 contacts.
When I applied 12V across the "-" and "+" contacts of the relay, no audible switching sound was heard. There is continuity across the contacts. What was weird, was that I measured ~4V across "L" and "W/L" contacts. I wish I knew what these letters meant!
Then this gets weird, I applied 12V to contact "L" and proceeded to switch on the relay, and I can hear and physically feel the relay operating now, and I'm measuring ~11V across contacts "L" and "W/L".
What's even more confusing is the '05 Elise wiring diagram, shows 6 connection points to the wiper module, yet there are physically only 4 contacts on the module?
Does anyone have a better understanding of how to diagnose if this wiper module relay is truly defective or operational?
post #9 of 12 (permalink) Old 04-15-2018, 03:41 PM
BigHair's Avatar
The relay has some electronics inside to provide a delay function for the intermittent position of the wiper stalk. The relay that I replaced has 6 pins and the pin identifiers molded into the relay base are consistent with the wiring diagram. (I, 15, 53C, 31, 31B, 53E)
Does the relay you pulled have 6 pins?
The wiper does not use the relay at all for the high speed.
So if the motor assembly is good it could still be a wire issue or power not getting to the wiper stalk.
Another questions:
Does your wiper washer pump work
If it doesn't then it points to a problem with power not getting to the wiper stalk.
BigHair is offline
post #10 of 12 (permalink) Old 04-16-2018, 04:29 AM Thread Starter
Oh my gosh I'm feeling stupid now. It has to be the wrong relay that I pulled. Guessing I was holding the flasher relay the whole time
Kubera likes this.
post #11 of 12 (permalink) Old 04-16-2018, 05:38 AM
Race & Pamper
Kubera's Avatar
It's all good, we know that going under the dash to check on a relay is not the easiest thing to do!
Kubera is offline
post #12 of 12 (permalink) Old 04-16-2018, 10:22 AM Thread Starter
Right-o, so much fun contorting my body and using small mirrors to guide my hands. I'm positive that being in good physical shape, and shorter than 5'10" tall, is a Lotus requirement for all service technicians!
