ABS light comes on only in the afternoon - LotusTalk - The Lotus Cars Community
 4Likes
  • 1 Post By glb
  • 1 Post By kjcst20
  • 2 Post By glb
post #1 of 14 (permalink) Old 07-25-2016, 11:34 AM Thread Starter
2005 Elise with 58k miles.
When I drive to work in the morning, the ABS light comes on at start up, then after a few seconds turns off with the rest of the tell tale lights, and does not come on for the rest of the drive (about 25 min). In the afternoon, the light comes on at start up and does not turn off for the entire drive. No other tell tale lights are on.
This happens every day, regardless of the weather, for the last few weeks.
Has anyone ever had this type of intermittent problem? Does this error code get logged, in case the dealer scans the car and the light isn't on?
kjcst20 is offline
post #2 of 14 (permalink) Old 07-25-2016, 11:48 AM
TachItUp's Avatar
Is the reservoir low?
TachItUp is offline
post #3 of 14 (permalink) Old 07-25-2016, 11:58 AM
Arch. Project Manager
surferpkt's Avatar
Yes, it was very random as in not everyday and over the corse of a year it would come on more consistently. Would throw a bunch of codes that could only be read by the official Lotus scan tool. I'm having to replace my abs control unit and possibly the lower portion as well. I'll know more once the car is up and running again. My unit looked flawless and all coils were in good condition, so I'm wondering if in fact it's lower portion that went bad. Time will tell.
"This car is more fun than the entire french air force crashing into a firework factory." - Jeremy Clarkson
2005 BRP ELISE:
Sport Pack, Hard Top, Black Mesh Grills, Cup Air Box, TitanQR, Difflow diffuser, Larini Club Sport Exaust, Rear Panel Delete, RTD Brace w/Nitron Toe Pins, Mono-ball bushings, PRORAD, Reverie CF Side Scoops & CF Splitter, CF door pulls, Odyssey PC680. Filled seams including a custom one piece front paint protection film.
surferpkt is offline
post #4 of 14 (permalink) Old 07-25-2016, 12:00 PM
surferpkt's Avatar
Oh,
BTW check your sensor wires and connections and get the codes read before taking the +\- $1400 dollar plunge.
2005 BRP ELISE:
post #5 of 14 (permalink) Old 07-25-2016, 01:52 PM
glb
glb's Avatar
The ABS fault light is not the same as brake fault light. Only the latter should come one with low fluid.
I had ABS light once. Cleaned the connectors behind the wheels with Deoxit. Light went out and not returned in 2 yrs or so.
surferpkt likes this.
Driving Tips-https://www.lotustalk.com/forums/f100...art-1-a-49665/
Moss Emergency Line-https://www.lotustalk.com/forums/f100...cy-line-36631/
Safely Piercing Wires-https://www.lotustalk.com/forums/f129...esting-106438/
Bleeding Brakes- https://www.lotustalk.com/forums/f101...-brakes-241138
glb is offline
post #6 of 14 (permalink) Old 07-26-2016, 03:27 AM
David Craig's Avatar
glb,
Which wheel or wheels did you clean? Do you need the wheels off to get at those connectors?
David Craig is offline
post #7 of 14 (permalink) Old 07-26-2016, 03:44 AM Thread Starter
thanks glb, i'll give that area a good cleaning and let you know
kjcst20 is offline
post #8 of 14 (permalink) Old 07-26-2016, 06:56 AM
glb
glb's Avatar
Originally Posted by David Craig View Post
glb,
There is a connector at each wheel, which you access by removing the wheels.
glb is offline
post #9 of 14 (permalink) Old 07-28-2016, 12:04 PM
I noticed today that for both back wheels I could access the ABS connectors with the wheels still on. So I opened them and applied some electrical contact cleaner.
I plan to remove the front wheels when I get a chance to clean those connectors.
2009 Saffron Elise
post #10 of 14 (permalink) Old 08-08-2016, 05:35 PM
I was about the remove the front wheels but then I noticed that those ABS connectors could also be accessed without removing the wheels. I just needed to angle the front wheels sharply forward and to the left for the driver's side or to the right for the passenger side.
2009 Saffron Elise
post #11 of 14 (permalink) Old 08-08-2016, 06:02 PM
glb
glb's Avatar
Fine, David. But, I recommend pulling the wheels anyway, so all the wires and areas can be inspected.
glb is offline
post #12 of 14 (permalink) Old 08-09-2016, 03:17 AM
Thanks. I'll probably do that in the Fall when I put on the winter tires.
2009 Saffron Elise
post #13 of 14 (permalink) Old 02-02-2017, 07:31 AM Thread Starter
just a follow up.
bought some deoxit and have been cleaning the abs sensor area with every car wash.
light has not returned since (about 2k miles so far).
2005 AR Elise
kjcst20 is offline
post #14 of 14 (permalink) Old 02-02-2017, 12:42 PM
glb
glb's Avatar
Good.
I am right on rare occasions.
darkSol and surferpkt like this.
glb is offline
