Cluster Wires - LotusTalk - The Lotus Cars Community
post #1 of 11 (permalink) Old 08-31-2011, 11:52 AM Thread Starter
Cluster Wires
I have just disconnected my cluster(Installing Dash2). I was wondering if anyone had a wiring diagram for the clusters? ie which wire is speed, fuel, etc
my cars are too slow
EnvyMotors is offline
post #2 of 11 (permalink) Old 08-31-2011, 11:58 AM
SirLotus's Avatar
Maybe this could help.
SirLotus is offline
post #3 of 11 (permalink) Old 08-31-2011, 01:02 PM
Plug Whisperer
turbophil's Avatar
Speed and fuel all come through CAN... so does the oil light...
The only thing you're going to tap to with the Dash two behind the cluster is turn signal, high beams, brake warning light (which is backwards, BTW), power, and headlight...
Speed, RPM, fuel, etc will either come via OBD-2 or similar interface, or just going directly to the sensor in question and rob the signal for the Dash 2... I did the dash2 install years ago on my car with parallel sensor robbing. I think RT has a device to make the connection to the OE canbus now. I suggest calling Al at RT to see what he says about that...
Cheers,
Phil
turbophil is offline
post #4 of 11 (permalink) Old 08-31-2011, 02:34 PM Thread Starter
I was told there was a speed sensor wire??? Wondering if any OBD2/CAN cable will work?
post #5 of 11 (permalink) Old 08-31-2011, 02:36 PM Thread Starter
Thanks! is this looking at the plug or the back of the Dash?
post #6 of 11 (permalink) Old 08-31-2011, 02:37 PM
Plug Whisperer
turbophil's Avatar
Oh that's right. There is a speed wire on the later cars for the volume compensating radios... Not sure that it matters. You can use the GPS for speed and it will still drive the ODO on the dash 2... You still need CAN to get any real data...
post #7 of 11 (permalink) Old 08-31-2011, 02:39 PM Thread Starter
Thanks,
In the post below, he mentions tapping the can wire ...to get all of the standard dash functions. Or is this the CAN cable you are talking about
https://www.lotustalk.com/forums/f3/p...install-90452/
post #8 of 11 (permalink) Old 08-31-2011, 02:44 PM
Plug Whisperer
turbophil's Avatar
I can't see the pic, but the Can wires are the twisted pair blue and red wires. Yes you can tap those IF theres a module that can do something with the data...
I'm learning that sometimes the dash can play games with my ability to flash through the OBD-2 port at times though!
post #9 of 11 (permalink) Old 08-31-2011, 04:44 PM Thread Starter
Thanks. So I guess I need to order the cable to get my standard Dash Functions back.
post #10 of 11 (permalink) Old 09-01-2011, 12:13 PM Thread Starter
Spoke with AL and he wasnt sure if I could get the fuel level from the CAN without knowing if it sends a code. I went ahead and ordered the cable.
Can I not just jump the 2 CAN wires for the info?
post #11 of 11 (permalink) Old 01-22-2018, 03:48 PM
Cool elise k swap cluster pin out kprov4
I have 2005 Elise with kswap ,but mo cluster functions Honda says that the can out put is inside the ecu kpro version4
I have cluster off to wire up can l and can h hook up does any one know how to wire up kprov4 can out put to cluster??
greenelise is offline
