DYI 06 LED Tails on 05 Elise Step by Step?? - LotusTalk - The Lotus Cars Community
post #1 of 8 (permalink) Old 07-11-2018, 04:58 PM Thread Starter
2005 LB Lotus Elise
SkinnyThiago's Avatar
I have seen many threads about this, but still have not found a step by step clear DYI. Anybody willing to write one up? I am looking to install 06 LED tails from an 06 Exige on my 05 Elise and wanted to double check on the exact steps and what I needed. Is it plug and play? I know Theres also a Flasher relay. Can anyone help me with the exact steps?
Thanks in advance!
2005 Laser Blue Lotus Elise
SkinnyThiago is offline
post #2 of 8 (permalink) Old 07-11-2018, 08:07 PM
Saffron Yellow is Lighter
XtinctElise's Avatar
Be sure to get the new $100 solid state relay flasher per the updated bulletin.
XtinctElise is online now
post #3 of 8 (permalink) Old 07-12-2018, 06:30 AM
InfernoLotus's Avatar
Wow, you really need a $100 relay? I put LED lights in my 05' and used a CF13-GL02 LED Flasher Relay off of EBay for $8.95 and it works great. Please make sure you get a CF13-GL02 and not a CF13-JL02. The JL will not work on our cars even though some sites state they will. The difference is + and - pins are swapped. Good luck on the LEDs!
Central Florida
InfernoLotus is online now
post #4 of 8 (permalink) Old 07-12-2018, 07:12 AM Thread Starter
2005 LB Lotus Elise
So Im getting the LEDs from an 06 EXIGE. DO I have to buy this flasher relay or can I just use the stock one being used on the 06 Exige on my 05 Elise? @InfernoLotus @XtinctElise
post #5 of 8 (permalink) Old 07-12-2018, 07:44 AM
The alternate relay worked for few months then the common fast flashing issue appeared. Lotus has acknowledged this and this is their offical fix, it has lower resistance and does not affect the load like the stock relay. You loose the clicking sound though.
post #6 of 8 (permalink) Old 07-12-2018, 08:13 AM
cyow5's Avatar
Get the relay off of superbrightleds for $10. I've been using it for five years. You will have to either update the relay or add a resistor, but the relay is easier and far more correct.
cyow5 is offline
post #7 of 8 (permalink) Old 07-12-2018, 02:51 PM
Is that $10 relay a solid state relay?
post #8 of 8 (permalink) Old 07-13-2018, 03:53 AM
cyow5's Avatar
You don't need a solid state relay. My guess is that the SSR fixes a different problem - electrical behavior shouldn't change with time with analog pieces like a relay and lights. If it works for a month and then stops working, something else happened.
cyow5 is offline
