ECU Connector Pin Out - LotusTalk - The Lotus Cars Community
post #1 of 17 (permalink) Old 04-26-2006, 05:54 PM Thread Starter
Forum Founder
Randy Chase's Avatar
So I am looking at the connector.
Figured out how to remove it, pull the retention tab thingie. Cover snaps off. Got it. Very short service loop on the harness makes dealing with the connector more difficult.
A large number of wires. How do I know which pin is which number? Does anyone have a diagram?
Thanks
#somethingwickedthiswaycomes... the new Origin Noble M and the Origin 7
Zenos E10S for Sale! www.zenosforsale.com
There are some very shady dealers in the Lotus business.
2005 Lotus Elise, 1993 MR2, 1995 MR2, 125cc Shifter Kart, Toniq (in build), 2018 Origin 7 (waiting), 2018 Origin Noble M (waiting)
Randy Chase is offline
post #2 of 17 (permalink) Old 04-26-2006, 06:01 PM
Originally Posted by Randy Chase
So I am looking at the connector. Figured out how to remove it, pull the retention tab thingie. Cover snaps off. Got it. Very short service loop on the harness makes dealing with the connector more difficult. A large number of wires. How do I know which pin is which number? Does anyone have a diagram? Thanks
Check moremonkey, but you must register.
Stan is offline
post #3 of 17 (permalink) Old 04-27-2006, 03:47 AM
Evl
Evl's Avatar
Once you have the connectors off the ECU, remove the 3 nuts that hold the ECU in place, and pull the ECU from the vehicle. With a good light, you'll be able to see little numbers in the plastic on the connectors on the ECU side, those are the pin numbers.
At least I remember seeing the numbers on one side or the other, but I can't possibly imagine how I would have seen them on the harness side, due to the short service loop you mentioned.
Evl is offline
post #4 of 17 (permalink) Old 04-27-2006, 05:10 AM
kverges's Avatar
Randy, email me and I will send you the pin diagram; I'd post it but it is in excel and I can't get the pin layout to format correctly. Also, I recommend double-checking pin function against the service manual.
kverges is offline
post #5 of 17 (permalink) Old 04-27-2006, 05:25 AM
newman's Avatar
AND FROM: http://www.elisetalk.com/forums/show...8&postcount=73
Originally Posted by aletes
1 Pre O2 Sensor - HT. Ground
3 Post O2 Sensor - Signal
4 Crank Sensor
6 SAI Pressure Sensor - Ground
7 Coolant Temperature
8 TP Sensor - 5v Reference
9 VSV (Canister Vent Close Valve)
11 VSV (ACIS) Airbox
12 Oil Control Valve VVL
13 Knock Sensor
14 Injector 3
15 Pre O2 Sensor - Signal
18 TMAF Sensor - IAT Ground
19 Knock Sensor
20 TP Sensor - Signal
21 Oil Pressure Switch - Block
22 Ignition Coil 1, 2, 3, & 4
24 Oil Pressure Switch (VVTIL)
25 Injector 1
26 Ignition Coil 2
27 Post O2 Sensor - HT. Ground
29 Post O2 Sensor - Ground
30 Crank Sensor
31 TMAF Sensor - MAF Ground
33 Coolant Temperature
34 TP Sensor - Ground
35 IAC Valve - Signal
36 SAI Pressure Sensor - 5v Reference
38 VSV (Purge Valve)
40 Injector 4
41 Pre O2 Sensor - Ground
43 Knock Sensor
44 TMAF Sensor - IAT Signal
45 TMAF Sensor - MAF Signal
47 Ignition Coil 3
48 Ignition Coil 4
49 Oil Control Valve - VVT
50 SAI Pressure Sensor - Signal
51 Injector 2
52 Ignition Coil 1
55 Fuel Tank Sender
76 Fuel Tank Sender
78 Fuel Tank Sender
ECU Bus
SPL CAN_L: Pin 79
SPL CAN_N: Pin 80
Diagnostic Connector
SPL CAN_N: Pin 6
SPL CAN_L: Pin 14
SPL U (GND): Pin 4 & 5
16-15-14-13-12-11-10-9
8--7--6--5--4--3--2--1
AND:
2008 Aspen White Exige S240: SOLD
E30GTR: 500WHP/400FTLB Open to offers...
http://www.onyxsyndicate.com/newman
newman is offline
post #6 of 17 (permalink) Old 04-27-2006, 05:59 AM
kverges's Avatar
nevermind - Neeeeeeeeeeeewman got it ;-)
And jay Hassinger deserves credit for the emanage splicing part of this, I am pretty sure
kverges is offline
post #7 of 17 (permalink) Old 04-27-2006, 06:04 AM
newman's Avatar
good call. added the info.
newman is offline
post #8 of 17 (permalink) Old 04-27-2006, 07:42 AM Thread Starter
Forum Founder
Thanks guys!
Good info, specially about unbolting the ECU. Duh!
post #9 of 17 (permalink) Old 04-27-2006, 08:24 AM
OSX Black hat
charliex's Avatar
i see at least one wrong pinout on that diagram so i'd double check it
Black Exige S / Elan M100. Don't run a smaller pulley without an upgraded fuel pump! http://www.goth.am ecu stuff.. New reflash box coming soon!
charliex is offline
post #10 of 17 (permalink) Old 04-27-2006, 08:26 AM
newman's Avatar
care to share?
newman is offline
post #11 of 17 (permalink) Old 04-27-2006, 08:30 AM
Originally Posted by newman
care to share?
Guys, register and look at all the stuff at www.moremonkey.com ...especially if you are interested in the Lotus ECU...go there. Charlie is a supercat. You have to register to view all of the forums.
Stan is offline
post #12 of 17 (permalink) Old 04-27-2006, 10:16 AM
choi0706's Avatar
Originally Posted by Stan
Charlie is a supercat. .
gezz.. I wish I understood even half the stuff he posts under there..
Jay-05' ST, HT, Touring Red
choi0706 is offline
post #13 of 17 (permalink) Old 04-28-2006, 03:04 PM
sandsmuseum's Avatar
have schematic, will scan
Randy,
I have a paper copy of the schematic that I can contribute if the pdf of the same thing is difficult to read. I confirmed portions to charliex already and can do the same here if needed.
If others want the same information, I can high resolution scan and add here.
www.sandsmuseum.com
antique coin op repair
sandsmuseum is offline
post #14 of 17 (permalink) Old 05-10-2006, 07:34 AM
Zoomie's Avatar
Please do!
Zoomie is offline
post #15 of 17 (permalink) Old 09-22-2017, 09:51 AM
My ECU didnt get power due to a bad GND cable (pin 78)
PS! this is for a 2005 2ZZ engine ECU.
Stig Olav Kasin is offline
post #16 of 17 (permalink) Old 01-20-2019, 03:58 PM
JulianM's Avatar
Much better / more complete pinout here (attaching excerpt in case the link expires):
http://data.radiumauto.com/PublicDocs/19-0046.PDF
JulianM is offline
post #17 of 17 (permalink) Old 04-02-2019, 12:51 PM
Thanks
Hi Randy,
How do you get the cover off the wire harness connector after you remove it from the ECU?
jhowar is offline
