Electric accessory adaptor - LotusTalk - The Lotus Cars Community
post #1 of 9 (permalink) Old 07-14-2010, 04:33 PM Thread Starter
XHILR8N!'s Avatar
OK I've searched.....
Seems the Exise 12 volt electrical accessory outlet is a bit larger than the US version. Makes things rattle about, come loose.
Can anyone direct me to the mythical adaptor to tighten this up?
2005 Elise LRG, track prepped ,
2016 370Z Nismo
2013 Bentley Continental GT Speed 2019 Lexus LC500
XHILR8N! is offline
post #2 of 9 (permalink) Old 07-14-2010, 04:51 PM
111Geek's Avatar
Radio Shack 270-0046 is part number I have seen in the past. I haven't done it so can't say for sure.
111Geek is offline
post #3 of 9 (permalink) Old 07-14-2010, 05:01 PM
stockysnail's Avatar
I've done the conversion and my stuff works great now. I can charge my mobile again! It only takes about 20mins to do it. I don't remember the Radio Shack part number off hand but I got the number off of here somewhere.
2004 Deep Blue Volkswagen R32 - Purchased 11-15-2010
2005 Graphite Grey Elise - Sold 12-7-2010
stockysnail is offline
post #4 of 9 (permalink) Old 07-14-2010, 05:12 PM
Stilling doing God's work
comptalk's Avatar
Always wondered why all the plugs vibrated out of the DC unit. Isn't there just a converter you can buy to put into the euro unit for a better fit?
comptalk is offline
post #5 of 9 (permalink) Old 07-14-2010, 05:47 PM
apk919's Avatar
I've seen a rubber sleeve with slots cut out for the ground contacts. I think it came with my Valentine One, so I'm not sure it's available separately...
apk919 is offline
post #6 of 9 (permalink) Old 07-16-2010, 07:07 PM Thread Starter
XHILR8N!'s Avatar
Here are the specs for the two sizes:
12-volt cigar lighter receptacle and plug, size A:
* Receptacle inside diameter: 20.93 - 21.01 mm (median 20.97 mm)
* Plug body diameter: 20.73 - 20.88 mm (median 20.805 mm)
* Most often used in American automobiles.
12-volt cigar lighter receptacle and plug, size B:
* Receptacle inside diameter: 21.41 - 21.51 mm (median 21.455 mm)
* Plug body diameter: 21.13 - 21.33 mm (median 21.18 mm)
* Most often used in European automobiles, and sometimes as a second socket in American automobiles expressly for DC power connections.
Radioshack does not show an adapter in their online catalog. I found no mention of it in the Valentine on-line manual. Still looking......
2016 370Z Nismo
XHILR8N! is offline
post #7 of 9 (permalink) Old 12-11-2011, 06:32 AM Thread Starter
XHILR8N!'s Avatar
Finally saw to fixing the loose rattling accessory adapter in the Elise.
$7.49 at RadioShack. Snaps in very securely. Had to graft in a couple of blade connectors. Most of the stuff that comes with the adapter are not needed.
Enercell 12VDC Vehicle Power Accessory Outlet : Car Adapters | RadioShack.com
2016 370Z Nismo
XHILR8N! is offline
post #8 of 9 (permalink) Old 12-11-2011, 07:35 AM
Exiged's Avatar
I love little fixes like this!
Sent from my Autoguide iPhone app
DIY 2007 Exige S K20A2 C38 Rotrex
Www.onetonracing.com
Exiged is offline
post #9 of 9 (permalink) Old 10-26-2018, 02:24 PM
ARISE FROM YOUR GRAVE
I found a good solution for people who don't want to install a US socket.
Dr. Bulczynski 3.2 Cigarette Lighter MOD $5.99 - Pelican Parts Forums
I personally decided to use a zip tie to make the clips more solid but I don't know how well this will work with the heat. As said before in other threads, a metal tie would probably work best.
Supernaut is offline
