How to replace your 12v DC outlet for a better one - LotusTalk - The Lotus Cars Community
post #1 of 41 (permalink) Old 08-16-2008, 09:13 PM Thread Starter
lotusfan2's Avatar
The 12v DC outlet in the Elise doesn't hold a 12v plug very well. The plug just wiggles in there and contact is spotty. Upgrading it to a more solid outlet for my '06 Elise was easy, and cheap. You'll need this:
SOURCE UPDATED see Post 40: https://www.lotustalk.com/forums/f129...9/#post5595234
RadioShack product 2062272 link dead see linked post above
Plus some electrical tape, and a small flat head screwdriver.
1) Remove the black cover, labeled "1" in the picture below. This takes one screw
2) Inside, remove two more screws (don't drop them!) so that you can lift the grey holder up that holds the outlet.
3) Remove the plug with the black and purple wire from the back of the outlet (just pull).
4) Now remove the whole grey housing, #2 in the picture, then pry the old outlet out of it.
5) Take the Radioshack outlet and push it back in there. It should fit without any modification to the housing or the outlet itself.
6) This is the trickiest part, and really not that hard. Take the small screw driver and push both pins out of the plug, which you removed in step #3. This takes a little wiggling, but it can be done without damaging the plug or the pins. Be careful, the +12v line is still hot even with the car off. It is easy to short, and then you'll have to put a new fuse in. You probably should just take the fuse out or disconnect the battery when you do this.
7) Put the grey housing back, and attach the now loose wires to the radio shack outlet. The connectors on the wires should fit the new outlet perfectly. IMPORTANT Take care to attach the 12v wire (the purple) to the correct plug on the outlet. It has to go to the plug that connects to the inside of the outlet.
8) To prevent shorting when you put it all back together, wrap some electrical take around the +12v connector. For me, this was absolutely necessary. The back of the outlet sits really close to the metal frame that you screw the grey housing to. You can see this in the picture on the right.
9) Put the whole thing back together.
10) Test it with some cheap device first. I'm not responsible if you connected the +12v to the wrong plug of the outlet and blow up your V1, or so.
You're done!
'06 Elise, Canyon Red
Last edited by Keeper; 10-25-2017 at 06:02 AM. Reason: Updated source / broken link
lotusfan2 is offline
post #2 of 41 (permalink) Old 08-17-2008, 08:20 PM
peck555's Avatar
short and concise, nice write up.
Laser blue,biscuit, micro mirror, "Blue knob" ,HID lights,Euro LED rear lights,LED headlight rings,rear badge,blue starter button, replaced speakers,perma grin,
Club111 The Sith lord of the LB's loyal henchman
peck555 is offline
post #3 of 41 (permalink) Old 12-07-2008, 01:08 PM
Probably Lurking
Keeper's Avatar
added to uberpost.
-Shawn (2005 Elise) || New England Members of Lotus Ltd. (NEMOLL) - PM me to join local info list or NEMOLL || UberPost - Elise/Exige info: common problems/fixes, etc.
Keeper is offline
post #4 of 41 (permalink) Old 12-13-2008, 11:54 AM
Anx
Hey Lotusfan2, great post - I just got done doing it to my car this morning... A couple things I would add - on step 6, it should be pointed out that I think you mean pull the pins out the pack of the plug (where the cables come in).
Also, I had the center pieces replaced with the leather option, so I had to remove the little rubber ring that holds the cover over the 12v plug - if I didn't it didn't seat in enough, probably due to the extra space from the leather. Either way, super simple to do and now I can actually use my lighter adapters!
Cyan '18 Evora 400
(sold) Persian Blue '11 Evora S 2+0, Plack Exhaust
(sold) Ardent Red '06 Elise, Harness Bar, ClamHinge, VF S/C, BLP-1, Fumoto, Mesh bits, LETSLA
Anx is offline
post #5 of 41 (permalink) Old 12-14-2008, 03:44 AM
Yeti's Avatar
Any reason not to remove the fuse while doing this to avoid shorting it out?
Yeti is offline
post #6 of 41 (permalink) Old 12-14-2008, 01:35 PM
xceed's Avatar
No risk of electrocution, less fun!
xceed is offline
post #7 of 41 (permalink) Old 12-14-2008, 03:00 PM
Have you GYLO'd?
rcollum's Avatar
Problem With Garmin GPS
Just FYI - I had problems with my Garmin GPS plug in the receptacle, from day one. I got the 'sleeve' from Escort, but it really didn't quite fix my problem - the Garmin plug is still loose enough that contact is intermittent.
Luckily, my Battery Minder fits perfectly.
I'll probably do this receptacle replacement early next year.
Northern Virginia Lotus Club. Contact me to get on the mailing list!
rcollum is offline
post #8 of 41 (permalink) Old 12-14-2008, 03:39 PM
Ender's Avatar
+1 Replacing with the Radioshack unit worked well for me.
Just FYI, comparing the Radioshack receptacle with the Lotus OEM one, the Radioshack one (I'm guessing follows some "standard" US spec) is not only a bit tighter, but is also deeper. Hence, any device's plug will actually "snap" inside the receptacle. I found that with the Lotus one, the plug will still stick out more and easily fall out, even if you manage to make it tighter.
I had the center console out for painting, so I had the receptacle changed out as well. $7 for the Radioshack unit, and $5 for the Krylon Fusion for Plastic black satin paint. Cheap mods
2006 Lotus Elise - Solar Yellow
2002 Audi A4 Avant - Dolphin Gray
2006 Suzuki SV650 - Blue
2008 Ahrens Custom Road Bicycle - Sprint Blue
2013 Ahrens Custom SS Bicycle - Naked Steel Finish
Ender is offline
post #9 of 41 (permalink) Old 12-14-2008, 08:22 PM Thread Starter
lotusfan2's Avatar
Yes, exactly. The plug doesn't fit onto the back of the Radioshack outlet. Thus you need to get the two metal connectors out of the plastic plug. A bit of wiggling with a screwdriver and pulling on the wires will do it. Once out, you can push the metal connectors onto the Radioshack plug.
It sounds hard, but really it isn't. I should have taken a picture to illustrate....
post #10 of 41 (permalink) Old 12-14-2008, 08:23 PM Thread Starter
lotusfan2's Avatar
Because I was lazy You're right though, the proper way is to pull the fuse, or disconnect the battery.
post #11 of 41 (permalink) Old 03-08-2009, 04:17 PM
Z-dculus's Avatar
bumpy...this is the last piece of the puzzle for my console install. I have to get the pins out of the plastic plug...any new and innovative tricks for doing this? with my luck i'll probably break it LOL
2011 PB Lotus Evora
2014 RAM 1500 Express - Black Express Package (DD)
2006 KG Elise - SOLD
Z-dculus is offline
post #12 of 41 (permalink) Old 04-19-2009, 10:23 AM
www.theapexinn.com
kestrel74's Avatar
I took a large pair of ChannelLocks .....squeezed both sides in at the same time & the old one came right out....... Also used a small pair of needlenose pliers to take out the connectors from the back of the old plug....no problem.
Elise #2292 (SOLD) / CO / Starshield / Nitron Sport SA / RTDbrace / Uprights machined / Down Low rails / DBA 4000 Wiper Slot Rotors/ V1 / SS lines w/Pagid Black / G-Pan / Odyssey PC680 with RLS Bracket / Difflow 5 Element diffuser / Stebel Nautilus horn
www.theapexinn.com
kestrel74 is offline
post #13 of 41 (permalink) Old 05-27-2009, 02:59 PM
jmiesse's Avatar
Just did this mod. Went right to RS and they had it in stock. I installed it and, of course, as usual with this car....... Blood has to be drawn.
Sold:05 Arctic Silver Elise.
jmiesse is offline
post #14 of 41 (permalink) Old 05-27-2009, 08:01 PM
RichS's Avatar
Wow. Missed this the first time around, will be visiting Radio Shack tomorrow!
My DL1 falls out of the current receptacle about every 10th time. Usually when I've had a record breaking session...
"Against logic there is no armor like ignorance."
-- Laurence J. Peter
RichS is offline
post #15 of 41 (permalink) Old 09-27-2009, 04:13 PM
FalconerHK's Avatar
Minor Change...
FYI I went to Da Shack™ today and the part number has changed. It's now branded as "enercell" (whatev) and the part number is 270-0046.
Great mod btw, thank you to the original poster. The 12v outlet apparently came fully engineered with fail from the factory, unless of course the lads from Old Blighty have slightly larger plugs than we Yanks do. (Guess I'll have to ask the missus about that one.)
Pip pip, cheerio, carry on and all that harrumphness.
"We're not happy 'til YOU'RE not happy!"
FalconerHK is offline
post #16 of 41 (permalink) Old 09-27-2009, 04:15 PM
FalconerHK's Avatar
So did you just forgo the original instructions and get busy with the channel locks sans liner removal? Cause I'm all about the shortcuts, unless it'll end up costing me more than the $7.50 I dropped at Da Sheezack™...
post #17 of 41 (permalink) Old 05-31-2010, 01:59 PM
stockysnail's Avatar
I just threw mine in. I could only get it to fit if I took the cover off as it spaced it too much for the unit to stay in place with my leather wrapped console. I cut the cover of the 12v and now if I need to take it off I just put it in the 'glove box' aka our metal passenger tray. I also had to bend the metal plugs on the Radio Shack model to get them to line up with the existing plug since I didn't want to cut and attach the included wires.
Thanks for posting this! Now I can charge my mobile in the car again.
2004 Deep Blue Volkswagen R32 - Purchased 11-15-2010
2005 Graphite Grey Elise - Sold 12-7-2010
stockysnail is offline
post #18 of 41 (permalink) Old 05-31-2010, 09:52 PM
xxxotic's Avatar
I did a search and found out that their is a European plug, and an American plug. Looks like they are sending the cars with the Euro plugs.
12-volt cigar lighter receptacle and plug, size A:
Receptacle inside diameter: 20.93 - 21.01 mm (median 20.97 mm)
Plug body diameter: 20.73 - 20.88 mm (median 20.805 mm)
Most often used in American automobiles.
12-volt cigar lighter receptacle and plug, size B:
Receptacle inside diameter: 21.41 - 21.51 mm (median 21.455 mm)
Plug body diameter: 21.13 - 21.33 mm (median 21.18 mm)
Most often used in European automobiles, and sometimes as a second socket in American automobiles expressly for DC power connections
xxxotic is offline
post #19 of 41 (permalink) Old 06-01-2010, 06:33 AM
Hobbit's Avatar
Great post, going to do mine next Sunday. I am from England and I never knew they had different sized plugs! At least now I can use my GPS.... And charge my phone!
Phil
05 Yellow Elise, Stage 2.
Hobbit is offline
post #20 of 41 (permalink) Old 03-18-2011, 10:13 AM
bman6074's Avatar
It seems radioshack doesn't have the lighter anymore. Is there another place to get this?
bman6074 is offline
