[Instrument Cluster Modification] A brief guide to upgrading your needles and LCD - LotusTalk - The Lotus Cars Community
 4Likes
post #1 of 181 (permalink) Old 09-30-2014, 03:05 PM Thread Starter
Terry
t955152's Avatar
I've received lots of questions regarding how to do the needle/ LCD display mod. There's a thread a while back that was started by riceburner, aka Bob. He contributes a lot of time and effort to make this happen. I have to give him tons of credit for it.
In this thread, I will briefly go thru the modification for those who don't have time to go thru 20 pages worth of information. But again, credit to those people who participated there, they are the ones who came up with these precious information.
I'm not an engineering nor a handy guy, so if I can do this, i believe everyone can do it.
I will go by this order:
1) Instrument cluster Removal
2) LED needle mod
3) LCD display mod
before you start anything, make sure to wear a pair of gloves to prevent shorting anything in the circuit board.
1) Instrument cluster removal
a. pop all the screws indicated in red arrows
b. pull the cover straight into you shown in blue arrows
c. now you have an exposed instrument cluster, loose 4 screws around it and disconnect the 2 wires at the back. (the black plug seems to be hard to unplug, don't worry, just wiggle it left and right as you pull and be patient, it will come out)
d. taduhhh! done!
2) LED needle mod
a. break the adhesive that glues the cover on the cluster
b. pull the needles out "gently"
c. remove the plastic needle trims and the outer plastic trim "gently"
d. remove the cluster sheet
e. now turn around and remove all the screws shown in red arrows
f. pull the cover (you'll have to break the warranty seal, but hey it's over the 7 year warranty anyway so who cares )
g. at this moment you really have to have your gloves on so you don't short the board you are about to see.
h. pop two more screws shown in red and unplug the EL lighting sheet plug shown in blue
i. now you have the main board exposed
j. Here's the detailed info on LED ring soldering provided by riceburner (Bob) http://home.comcast.net/~riceburner9...stallation.pdf
3) LCD display mod
a. pop the 4 screws shown in red
b) remove the stock one and drop in the new one. It's as easy as that! (make sure all the pins sit in perfect buy plugging in the connector to see if all numbers are lit up and shown)
a couple notes:
1. try to plug the board back to the car and see if the LED and LCD work first before you put everything back. It'd be frustrating to find out something doesn't sit right and you'll have to remove all these bolts and screws all over again.
2. always wear gloves, if you short something, you are screwed.
3. soldering can be difficult for the first timers like me, find someone who can solder to solder the LED ring for you if you are not confident doing it.
now put everything back and enjoy the new look of your 10 year old clusters!
before and after differences!
day time
night time
Here are the choices for needles: (I haven't had chance to try anything other than these 4. so there are plenty of other choices I believe)
from top to bottom:
1. Dodge Intrepid needle
2. needles from forum member (I found 100 quantity for $50 on Alibaba, $1 a pair lol)
3. Harley needle
4. Harley needle painted in Fluorescent Red
Personally, I think #4 is the closest or most identical to what Lotus use in 2008+ Elise/Exige clusters.
Useful Resources:
LED needle mod (Approx. $35 +shipping):
You’ll need two things
1) Harley Needles (New Harley Davidson Speedometer Gauge Cluster Pointer Needle Only 16241661 | eBay)
2) Riceburner’s LED needle ring ([email protected]) and his installation guide (http://home.comcast.net/~riceburner9...stallation.pdf)
LCD display mod (Approx. $21 +shipping or $11 if you solder your own pins):
1) go to Newhaven 2x16 LCD page (2 x 16 Characters)
2) Pick a color you like and add “-D6” to the product number. (example: NHD-0216K1Z-NSR-FBW-L-D6)
3) Plug and play
How to paint your cluster needle:
http://revlimiter.net/blog/2013/03/h...gauge-needles/
t955152 is offline
post #2 of 181 (permalink) Old 09-30-2014, 03:09 PM
Bookmarked.
Nessal is offline
post #3 of 181 (permalink) Old 09-30-2014, 03:16 PM Thread Starter
Terry
t955152's Avatar
Originally Posted by Nessal View Post
Bookmarked.
t955152 is offline
post #4 of 181 (permalink) Old 09-30-2014, 03:33 PM
Thanks for the info!
pray4mojo is offline
post #5 of 181 (permalink) Old 09-30-2014, 03:34 PM Thread Starter
Terry
t955152's Avatar
fosho perry!
t955152 is offline
post #6 of 181 (permalink) Old 09-30-2014, 03:35 PM Thread Starter
Terry
t955152's Avatar
maybe we can do a SoCal DIY day and gather everyone to do this together, it'll be fun!
t955152 is offline
post #7 of 181 (permalink) Old 09-30-2014, 03:56 PM
zender's Avatar
Awesome thanks. Any chance u have the link to riceburner's post #theMoreUKnow
zender is offline
post #8 of 181 (permalink) Old 09-30-2014, 04:13 PM Thread Starter
Terry
t955152's Avatar
he made a pdf file regarding detail installation. perhaps try email him?
t955152 is offline
post #9 of 181 (permalink) Old 09-30-2014, 04:49 PM
donaldking's Avatar
Where did the other thread go? I need to see more photos before I can decide.
donaldking is offline
post #10 of 181 (permalink) Old 09-30-2014, 05:25 PM
xxxotic's Avatar
Looks good. Wish I had done this a few months ago when I had my dashboard apart to replace the switch pak module.
Does the gas display bar type indicator appear different? In the picture with the 105.9 odometer reading it appears that their is a black line in part of the display.
xxxotic is offline
post #11 of 181 (permalink) Old 09-30-2014, 05:26 PM
gooberschnot's Avatar
Hows the lcd at night i dont see it. Plus the original night time version is different than your day time version! The increments and dash lights are different
2005 Magnetic Blue Elise, Factory twin oil coolers, Sport pack with LSS wheels with 6.5 fronts, and touring pack with matching hardtop and insulated soft top. OEM stage II exhaust, carbon fiber intake, HID's, 5.25 and 6.5 Polks with JL Stealthbox and Alpine PDX-5 amp, Sony DSX-S310BTX head unit with Bluetooth, sector111 bootie and aluminum carpet buttons, OEM embellisher rings, shower cap and outdoor cover, factory painted console and AC shroud, battery cut off switch, factory starshield.
gooberschnot is offline
post #12 of 181 (permalink) Old 09-30-2014, 05:41 PM Thread Starter
Terry
t955152's Avatar
oh i posted two versions just to show people the choice of colors they can get from New Haven, but of course they have way more choices than just 2. So yeah those are two different dashes in my photos.
t955152 is offline
post #13 of 181 (permalink) Old 09-30-2014, 05:42 PM Thread Starter
Terry
t955152's Avatar
the display bar looks the same, the font and everything looks just like the stock. I think the black line is caused by the iPhone camera, sorry for the bad quality shot.
t955152 is offline
post #14 of 181 (permalink) Old 10-02-2014, 10:10 AM
Giantmcm's Avatar
Thanks Terry for a great write up!!! Very clear and concise.
It is on my to do list this winter.
Maverick ML8 - Other daily
Giantmcm is offline
post #15 of 181 (permalink) Old 10-02-2014, 11:46 AM Thread Starter
Terry
t955152's Avatar
probably one of the best mods to do! don't forget to wear gloves
t955152 is offline
post #16 of 181 (permalink) Old 10-02-2014, 01:49 PM
what needles are in the after shot? They don't look like the harley ones
formfollowsfunction is offline
post #17 of 181 (permalink) Old 10-02-2014, 02:25 PM Thread Starter
Terry
t955152's Avatar
Im also curious what these are and im looking really hard into it. I got them from a member Kandstem (not sure how to spell) and i asked him where he got it but never hear back. i will try my best to find out.
t955152 is offline
post #18 of 181 (permalink) Old 10-02-2014, 02:37 PM Thread Starter
Terry
t955152's Avatar
I found some pretty cool and useful stuff for the mod, hopefully it'll benefit some people here.
Fluorescent red paint and orange paint
Flourescent Red 1oz Needle Paint for Instrument Cluster Gauges | eBay
Fluorescent Orange 1oz Needle Paint for Instrument Cluster Gauges | eBay
also, my buddy uses the needles from Doge Intrepid. He got the entire used dash for $30 or less and took the needle apart and it fits perfectly. For those who don't wanna use the Harley needles or don't want to paint them red/orange, this is another solution to it.
98 03 Dodge Intrepid Instrument Cluster Speedometer Panel P04760402AF | eBay
t955152 is offline
post #19 of 181 (permalink) Old 10-02-2014, 02:56 PM
Giantmcm's Avatar
If I recall correctly Kamsden used the needles from a Pontiac GTO (newer body style).
I plan on using the needles from a GMC Yukon/Chevy Tahoe, liked the looks better and on ebay you can get them for $15 shipped.
Giantmcm is offline
post #20 of 181 (permalink) Old 10-02-2014, 02:57 PM
Kamsden's Avatar
Sugeray is now selling these.
Kamsden is offline
