[Instrument Cluster Modification] A brief guide to upgrading your needles and LCD - Page 5 - LotusTalk - The Lotus Cars Community
 4Likes
post #81 of 181 (permalink) Old 01-05-2015, 09:04 AM
Riceburner98's Avatar
Darksol - the backlight voltage (when fully on, not dimmed) is around 5v to the LCD. It of course drops as you dim it.
-> Actually disregard that - I just measured one - with the stock orange LCD, I'm measuring 3.5v with the 'headlights' off, and 3.3v with them on but not dimmed. I could swear it was closer to 5v when I was using the white screen yesterday.. Just measured with NO LCD, and it's 12v on the illumination wires. -> Which means there's a current limiting resistor somewhere on the cluster PCB... Interesting.. That'd be why I'm getting different voltages with different colors...
In my case, I like the red backlight since that's what I'm using. But matching the white backlight of the numbers does have something going for it.. Red's better for night vision, right??
2005 Chrome Orange Elise
Mod list: Stainless shift knob.
Riceburner98 is offline
post #82 of 181 (permalink) Old 01-05-2015, 09:35 AM
purveyor of lightness
darkSol's Avatar
Hmmm. 3.3v and not 5.0v?
When I get home I'll tie the backlight power to the 3.3v Netduino pin to see how the illumination changes. I can barely read the black on red text as it is at 5volts... so I might just end up using the white lcd which is PLENTY bright.
Just trying to get all my ducks in a row before tearing into this. I'll be fully removing my dash to replace some pieces with new CF and to also remove the passenger airbag. No need to do THAT teardown/reinstall all over again...
d.a..v...i....d
David Thomas Stewart - [email protected]
2005 Midnight Silver Lotus Elise (www.darksol.com)
388hp (342whp) BOE RevX 1736lbs.
darkSol is offline
post #83 of 181 (permalink) Old 01-05-2015, 12:55 PM
zender's Avatar
The pictures do seem to indicate that the gears are OK. One thing I did run across once - it's possible the pin isn't in exactly the right position - the bottom tip of it acts as a bearing against the bottom plastic case. If it's pressed in too far, or not far enough the big gear will rub against the case, or against the black gear. It's possible you just need to push the pin farther into the big white gear? When installed in the case, it should be just above the black gear, with the teeth engaged but not touching it's face.
When you completely un-plug the cluster, and plug it back in it does a reset - basically it will spin the stepper motor enough turns to cause a full counter-clockwise sweep of the needles. (there is a way to have it do a reset without unplugging - something with the key and the door ajar switch I think? I saw it here once..) So with the motor taken apart and the cluster plugged in, the little brown gear should do a few dozen (hundred?) revolutions thinking that it's spinning the needle around. If you rotate the (working) tachometer needle fully clockwise, you'll see it spin all the way back to zero when you plug the cluster in. (the clicking / crunching sound you normally hear is when the motor is trying to spin the needle counter-clockwise, but it's already fully rotated against its stop)
Without the motor case assembled and holding the shafts in perfect alignment, the gears may slip, but you should still see movement. If the tiny gear turns, then look at the big black gear, if that one turns, then it's probably the white gear with the pin rubbing. Nothing looks damaged, so there's still a good shot at getting it going as-is!
Cool, well I'll give that a shot and try the reset numerous times in different states and let you guys know. Thanks for the help Bob.
zender is offline
post #84 of 181 (permalink) Old 01-06-2015, 02:59 AM
Originally Posted by darkSol View Post
Hmmm. 3.3v and not 5.0v? ..
So I'd forgotten that I'd started to trace out the backlight circuit a while ago.. I never completed it (there is a TON of circuitry for something so simple!) but the basics are that the + side of the LCD backlight more or less goes directly to +12v. I forgot that the LCD does not dim with the EL or HVAC backlight, only a tiny bit when the headlights are turned on.
(To be technically correct, it's really car voltage -.8v when headlights are OFF, car voltage -.85v when headlights are on.. (must be through a diode?) So if the car's electrical system is really 13.6v, the backlight power will be 12.75v)
The - side of the backlight goes through essentially 330 ohm + 22 ohm resistors, and a transistor. These are (3) 1,000 ohm 1206 resistors to the lower left of the tachometer needle motor, and a 22 ohm 0805 resistor directly to the lower left of the motor. The transistor is next to the 0805 resistor. It appears that the OEM orange screen had 0 ohm resistors on it, so Lotus (well, the gauge manufacturer) chose to put the LED resistors on their board, maybe so they could change them if needed easier than having the LCD place do it.
Soooo.... The LCD itself has a built-in resistor since it's backlight is intended to run directly on 5v. The red-on-black LCD I have here uses a 330 ohm resistor. So when plugged into the Lotus cluster, it essentially becomes a 682 ohm resistor instead. I'm not sure what resistor the white LCD uses (they're in the mail..) but you can see it on the back side of the screen - should be R8, near where the LED pins are soldered. The red screen I have here is running @ 4.27v at the pins with all the resistors in place, and the LED itself is getting 1.675v. If I short out the 330 ohm resistors on the Lotus board, that only goes up to 1.680v, so not much change.
If your LCD screen has a 330 ohm resistor on the back of it, you can essentially short it out since the Lotus cluster board has 352 ohms already. BUT, all that said, it might not make much difference unless the screen is really drawing some current. (these things use a single LED though, so not likely..) You could potentially replace the red LED for a brighter one (or a bunch of surface mount ones?), but in my case anyway the red backlight in my car is plenty bright at night.. Since it doesn't dim, you don't want it 'too' bright. Just something to think about.
Whew! Lots of info for 6:30am! LOL
post #85 of 181 (permalink) Old 01-08-2015, 03:09 PM
Ok. I think I've got everything except new needles now. Does anyone know the specs on the needles (I really just need to know the bore size I suppose) or are most needles the same and any will work? Can I just pick some needles that are ~27mm and use them?
I kinda like the white ones below, anyone know the source?
allectrebek is offline
post #86 of 181 (permalink) Old 01-08-2015, 03:30 PM
Nope. It's pretty specific. You need to get one that is shallow enough and not too long The bore size is around 0.90
mm to 0.95mm. Mine was a hair over 0.95.
Nessal is offline
post #87 of 181 (permalink) Old 01-08-2015, 04:14 PM
Figured they were specific. Thanks for the size!
post #88 of 181 (permalink) Old 01-08-2015, 04:27 PM
Arch. Project Manager
surferpkt's Avatar
The Harley needles can have their shaft trimmed down and bored out to the proper size hole using a micro drill bit set.
"This car is more fun than the entire french air force crashing into a firework factory." - Jeremy Clarkson
2005 BRP ELISE:
Sport Pack, Hard Top, Black Mesh Grills, Cup Air Box, TitanQR, Difflow diffuser, Larini Club Sport Exaust, Rear Panel Delete, RTD Brace w/Nitron Toe Pins, Mono-ball bushings, PRORAD, Reverie CF Side Scoops & CF Splitter, CF door pulls, Odyssey PC680. Filled seams including a custom one piece front paint protection film.
surferpkt is offline
post #89 of 181 (permalink) Old 01-10-2015, 02:46 PM
Some more pictures of different LCD screens
Here's a shot from today with a white-on-black odometer LCD. There seems to be a missing / bright pixel next to the '9' on the odometer; I need to pull it apart and see if I somehow caused that or if it's just a bad screen. This is an early 'Sugeray' black speedometer faceplate (the Lotus logo is a bit high on the EL sheet, so the top edge is dark..), with white LED rings, Harley needles and the white EL sheet.
I did a blue-on-black LCD screen too, and proved that my Samsung Galaxy camera, my Canon PowerShot G7 camera and my wife's iPhone5 (and iPad mini) are all REALLY sensitive to blue... The black background of the LCD looks really blue, and the blue text looks pretty much white. It has got to be something to do with how they turn black and white sensors by covering them with an RGGB (Bayer) filter.. Maybe the blue of the filter just lets too much through? Or maybe the blue is close to the wavelength of the green filters (there's 2x as many) and picks up extra; but that would make it too green.. I dunno... Anyway, the LCD screen looks almost right with the flash on in the 2nd picture.
Here it is.. I was trying the scraped OEM EL sheet to see if the blue worked with the LCD screen.. The OEM sheet is a little too blue-green for my liking. Probably better with white EL.
post #90 of 181 (permalink) Old 01-11-2015, 03:56 PM
Testing an orange-on-black LCD.. Black speedo faceplate, white needle LEDs, stock 'orange' EL (er, not very orange without the orange tint of the OEM speedo faceplate). It's actually pretty orange, but of course the camera doesn't do nice things to color lately...
I might build some orange needle LED rings tomorrow and see what that looks like.
post #91 of 181 (permalink) Old 01-12-2015, 01:59 AM
KWYK's Avatar
stop teasing Bob and mod my '05 dash cluster for me,could be the start of a new business venture for you
05' EXIGE , SAFFRON YELLOW
KWYK is offline
post #92 of 181 (permalink) Old 01-13-2015, 04:58 PM
Ok.... One more picture. The orange LED needle rings look GREAT with the Harley needles.. They wash out with any front (sun) lighting and turn white since that's what they're painted on the bottom, but in the dark they look very nice.
This is black faceplate, white EL sheet, orange-on-black LCD screen, and orange LED needle rings with Harley Davidson needles.
post #93 of 181 (permalink) Old 01-13-2015, 05:56 PM
Looks really good!
Nessal is offline
post #94 of 181 (permalink) Old 01-23-2015, 01:52 AM
Here is my new LCD, pic is not that good though... (with a special thanks to Riceburner98).
2006 Elise Magnetic Blue | BOE REV300tvs SC kit with 85mm pulley, ITG airbox, Exedy Sport Clutch, 2bular Headers, 2bular Silenced Decat, 2bular 8x22 Oval Tip Exhaust, Black Exige Rear Diffuser, Black Forged 7spoke wheels, BOE Uprated Rear Engine Mount, Exige V6 Mirror Plinths, etc... (SOLD)
stekki is offline
post #95 of 181 (permalink) Old 01-23-2015, 12:33 PM
That's cool, thanks for the pic!
Yellow looks really great.
2006 Black Exige
Chimera R.B.S./ITB airfilter/Composite Worx
Kimgt is offline
post #96 of 181 (permalink) Old 01-24-2015, 04:14 PM
Pics of mine, before and after
Just had mine done. Love it. Name:  IMG_0525.jpg
johnpatrickcrumley is offline
post #97 of 181 (permalink) Old 01-24-2015, 04:36 PM
Wow that's a high idle!
Looks incredible..
post #98 of 181 (permalink) Old 01-24-2015, 10:28 PM
shay2nak
shay2nak's Avatar
I do like the black & blue corner display. Unfortunately, my eyes cannot really focus on blue lights & signs for some reason. ...and I do like the white stock gauges.
'07 Lotus Exige S310
WTC 2
shay2nak is offline
post #99 of 181 (permalink) Old 01-25-2015, 06:55 PM
Looks incredible..
Yeah, I was just chilling in my garage. My neighbor's love it! Haha. Nahhh, the dam thing it stuck. Going to have to take it apart and fix that...
post #100 of 181 (permalink) Old 02-20-2015, 08:03 AM
I'm sure I missed it in one of these threads, but where are people sourcing these updated speedo faceplates?
OddManOut is offline
