Need help ID'ing power sources for 12v constant, switched, and accessory switched - LotusTalk - The Lotus Cars Community
 1Likes
  • 1 Post By helicopter12
post #1 of 3 (permalink) Old 09-09-2018, 03:53 AM Thread Starter
Smoky's Avatar
My car: 07 Exige S
I may not be calling these things by the correct name...
I have three gauges. One is a clock and needs constant 12v. The other two are AFR and Boost and require some initialization time and need to be connected to a switched 12v source that STAYS ON while the motor is cranking.
Right now my car is apart and no battery connected, so I can't do that fun wire-hopping exercise with a voltmeter at the moment.
I am hoping someone can tell me the behavior of our switched 12v sources. If I am reading this diagram correctly, can I use my head-unit's 12v power as a safe constant from the battery (is this the equivalent to fuse F15 in the front box??) while using cabin Fuse C2 as a source for the AFR and Boost gauges that need power DURING startup?
Looks like I just need to avoid fuses C1-C2 but I am not sure if I am translating "ignition", "battery", and "start drop out" correctly.
Or do I need to wire my own new fused constant from the POS+ tap in the front?
Thanks!
-Smoky
Smoky is offline
post #2 of 3 (permalink) Old 09-09-2018, 06:10 AM
Logically, the AUX power socket it always on in this car and is labeled as "BATTERY" which implies anything that is labeled "BATTERY" will be on constantly. This means that for your F15 fuse should work for your constant power. I would honestly tap into the AUX power socket F1 just because it already has a larger fuse, and most people don't use it that much so its as if your gauges are on their own circuit in a way.
For the AFR and Boost gauges I would go off of the radio key-in C3 fuse as the radio does not turn off while cranking the car. This one I am not too sure about as I am not sure if the radio ignition wire is directly connected to that fuse or not. Anyone else know this better?
Hopefully this helps a little?
Smoky likes this.
helicopter12 is offline
post #3 of 3 (permalink) Old 09-09-2018, 06:26 AM Thread Starter
Smoky's Avatar
Thanks I've got it sorted out now
-Smoky
Smoky is offline
