Need help for Shift-i light installation - LotusTalk - The Lotus Cars Community
 1Likes
  • 1 Post By LionZoo
post #1 of 14 (permalink) Old 03-04-2013, 06:13 AM Thread Starter
swd
I ordered a Shift-i light.
My mechanical knowledge are limited so i would like to know where and how i should tap the 3 wires (tacho-ignition-ground). I saw a pic with the MSD pickup signal module, but if i could avoid buying this part (60$), i would appreciate.
BTW, my radio/stereo (Alpine) is out right now, so if there is a possibility to use some wire there, let me know.
Thanks
swd is offline
post #2 of 14 (permalink) Old 03-04-2013, 07:13 AM
andy7777's Avatar
You know our cars come with a shift light, right? I'm assuming you're talking Elige, otherwise nevermind...
andy7777 is offline
post #3 of 14 (permalink) Old 03-04-2013, 07:16 AM Thread Starter
swd
I knew this was coming...
I know that red shift light, but i wanted something that i CAN see when it's time to shift...
swd is offline
post #4 of 14 (permalink) Old 03-04-2013, 07:56 AM
Apex_in_sno's Avatar
Ground, well anywhere, ignition you can pull of the radio harness.
Tach signal, you can take from the red-black lead from coil pack on cylinder # 1.
Now if reading that makes you weak in the knees, then get the MSD.
There is no tack signal anywhere in the dash that your shift light will understand.
VFII, Eliseparts Sequential, Geartronics Paddle shift.
You name it, I've probably got that installed too...
1864lbs, full tank
Otherwise, it's bone stock....
Apex_in_sno is offline
post #5 of 14 (permalink) Old 03-04-2013, 08:06 AM Thread Starter
swd
What is the difference between the red/black wire and the green one on this pic?
And what is the advantage other than not cutting the wire with the MSD?
swd is offline
post #6 of 14 (permalink) Old 03-04-2013, 09:07 AM
Green (for all coils) goes to fuse R7, which then goes to the battery, it's always hot, if the MSD works on that lead it's a fluke.
The red-black is the trigger for that coil from the ecu.
If you're good with wiring, there is no advantage.
Be sure to get the wiring diagram and understand how to read it if you're going to modify the stock harness.
1864lbs, full tank
post #7 of 14 (permalink) Old 03-04-2013, 09:53 AM Thread Starter
swd
Thanks!
Would it be okay to use a T-Tap to connect on the red/black wire?
MSD look like a pricey T-Tap to me...?
Or maybe i should just strip, twist and sold the wires together?
[QUOTE=Apex_in_sno;1852779]Green (for all coils) goes to fuse R7, which then goes to the battery, it's always hot, if the MSD works on that lead it's a fluke.
swd is offline
post #8 of 14 (permalink) Old 03-19-2013, 06:36 PM Thread Starter
swd
I received my Shift-i.
I've readed a lot regarding the installation and i can't find anyone who installed this without the MSD...
And they all taped it on the green wire not the red/black...
I've been told by ecliptech that i should not run 3 wires from the coil cause i will pick up a lot of noise...
swd is offline
post #9 of 14 (permalink) Old 03-20-2013, 06:51 AM
The only wire that needs to come off the coil pack is the trigger itself, red/black. Ground and power you can get off the radio harness or several other places in the dash.
I can guarentee that your shift light (without the msd) will not work off the green wire.
Find some temp power and ground for the light (aux power outlet is good), drag a temp wire from the coilpack red/black, fire the dang thing up see if it works.
Then commit to the final wireing.
I could go on for a good long bit about the different and then proper ways of modifiying auto wireing, however a proper barrel crimp tool, crimps and adhesive shrink are going to cost you more than the MSD in the first place.
So I'm just going to look away while you twist, solder and vinyl tape this thing back together.
I guess giving you current level of understanding in the electrical department,
I would recomend that you get the MSD for your application, it will be the lease amount of hastle and install risk.
You've invested a decent ammount of time in modifying the pod for the display itself, so don't cheese out the remainder of the install with a Hello Kitty splice job.
1864lbs, full tank
post #10 of 14 (permalink) Old 10-25-2016, 01:21 PM
I use with website for my mod advice and I installed PZ racing sequential shift light.
First i connected tach meter wire but the light did not pick up tach signal.
And I took advice hear from Apex_in_sno and bought MSD tach signal and clipped on red/black wire from coilpack 1.
I did worked!!
So, I would like to say thank you for your information!
exigeams is offline
post #11 of 14 (permalink) Old 10-25-2016, 03:09 PM
lobuzz311's Avatar
I was not aware of the PZ racing shift light. The only issue I have is that you have to free rev the engine to the max rpm?!? I really don't want to bring the car to 8k without load! Is that how you had to set yours up?
2005 Elise - Storm Titanium
lobuzz311 is offline
post #12 of 14 (permalink) Old 10-25-2016, 04:25 PM
LionZoo's Avatar
I like your setup. Very similar to mine!
exigeams likes this.
2011 Lotus Elise SC Final Edition 15 of 15 - Ardent Red
LionZoo is offline
post #13 of 14 (permalink) Old 10-26-2016, 05:53 AM
I dont understand your question, my English is second language.
I just set low, both sides Green LED comes on at 6500rpm and center red LED comes on at 8000 rpm and all LED flashes at aprox 8100rpm = my optimum shift up sign.
this set up is easy and did it at park parking place (no residential houses around).
you can set any rpm low and max like 3000rpm and 5000rpm.
was this your question?
exigeams is offline
post #14 of 14 (permalink) Old 10-26-2016, 01:37 PM
lobuzz311's Avatar
Yeah, that answers it. Thanks
