Is it OK to use the front jump point as a 12v and ground source? - LotusTalk - The Lotus Cars Community
post #1 of 6 (permalink) Old 09-13-2018, 07:13 PM Thread Starter
Smoky's Avatar
My car: 07 Exige S
My thoughts are to connect a small amp (100w RMS x 4) mounted in the dash and connected via 10ga 12v and ground to the jump terminals located under the front service panel.
Is it ok to use these terminals for such a purpose?
Is the 12v cable fused between the jump point and the battery?
Am I better off just running my own fused 12v cable the length of the car to the battery in the trunk? It is quite a stretch, dash to front, front to floor, floor to rear wall, up rear wall, over shelf, through to trunk to battery.
Thoughts? Thanks
-Smoky
Smoky is offline
post #2 of 6 (permalink) Old 09-15-2018, 03:26 AM Thread Starter
Smoky's Avatar
Lack of responses... And some more thought has led to me to conclude not to use this terminal and instead just add my own new 12v line from the battt to the dash. That's a long line though so I may even fuse it twice just to feel better about the length of powered lead at any given moment.
The existing remote terminal uses a lead that has too many unknowns. It isn't meant to be used constantly, just like once in the car's lifetime - so I have to assume they designed it and the space it lives in around that requirement. The more I think about it I'm not even sure I like it being part of the car. There is a 12v firework fuse basically just running along the driver's sill, completely obfuscated from our want to maintain and preserve. But no one has ever reported an issue about it I guess? So I won't worry about it.
-Smoky
Smoky is offline
post #3 of 6 (permalink) Old 09-15-2018, 04:02 AM
I don't see a problem
I think the only problem I remember seeing is someone got air horn power from there and it caused the ECU to glitch when they blew the horn.
I cannot see an amp having any similar effect
I used them to power high speed on the heater fan to squeeze that last bit of airflow out of it in my AC rework thread
exigegus is online now
post #4 of 6 (permalink) Old 09-15-2018, 04:22 AM
4380r's Avatar
Originally Posted by Smoky View Post
My car: 07 Exige S
Thoughts? Thanks
That lead back to the battery wouldn't be long at all. The Exige is a very small car. Think about it....would that lead be any longer, or as long, as the leads running from the light switches on the dash back to the tail lights?
Owned, loved, enjoyed, and now gone:
1969 Europa S2 Blue
1970 Europa S2 White
1974 Europa Twin Cam Blue
1984 Turbo Esprit Calypso Red
2005 Elise Starlight Black
2005 Elise Saffron Yellow
2005 Elise Ardent Red
2006 Exige Graphite Grey
2007 Exige Canyon Red
Other:
1970 MGB GT
1970 Datsun 510
1984 Honda CRX Si
1984 Pontiac Fiero
2004 Chrysler Crossfire
2009 Pontiac Solstice Coupe
4380r is offline
post #5 of 6 (permalink) Old 09-15-2018, 04:35 AM Thread Starter
Smoky's Avatar
True. Still, I like to explore all of the options before deciding to add lengths of 12v lead into any scenario.
-Smoky
Smoky is offline
post #6 of 6 (permalink) Old 09-15-2018, 06:11 AM
kfennell's Avatar
The 12v wire to the terminal post is a straight run from the battery to the terminal already. It really only sees the fan and wiper loads
kfennell is online now
