Retrofit 08 Instrument Cluster? - Page 2 - LotusTalk - The Lotus Cars Community
 2Likes
post #21 of 208 (permalink) Old 01-02-2009, 08:56 PM
British_Marques's Avatar
Hi Rob, Any updates on getting the donor 2008 for testing purposes. I know I PM'ed and am still interested in the conversion. Charlie, is it possible you could weigh in again on this project?
2005 Elise Starlight Black
1991 Elan Monaco White
1973 Triumph Stag, second owner.
1975 XJ12C Jaguar pillarless coupe.
1960 Daimler Limo, drives great look like hell, project in the works.
British_Marques is offline
post #22 of 208 (permalink) Old 01-04-2009, 06:01 PM Thread Starter
Noel's Avatar
Location: 33.87S 151.21E Car: ロータス MKII エキシージ Type: Komo-Tec S300
+1 | Would love to see this become reality.
Noel is offline
post #23 of 208 (permalink) Old 01-04-2009, 09:48 PM
OSX Black hat
charliex's Avatar
rob apologies, i got sidetracked, i'll post up the can data,
its pretty much the same as it was, just that the c/f mph/kph is a config byte now included in the stream, otherwise its 512 kbps, i don't think anything else has been added i'll upgrade my bench ecu to 2008 spec and post it.
i have the 07 plugs i think the 08s are probably similar, i'd like to get hold of an actual 08 cluster to test out.
it shouldn't be hard, i've added variable tc to my 07 S and i'd like to do the cluster too i think, though i do like the orange, i dig the new one too,
RoHo likes this.
Black Exige S / Elan M100. Don't run a smaller pulley without an upgraded fuel pump! http://www.goth.am ecu stuff.. New reflash box coming soon!
charliex is offline
post #24 of 208 (permalink) Old 01-04-2009, 10:07 PM
FLuXeXigeS's Avatar
how about an OEM retrofit trac and launch control LOL
RoHo likes this.
-Coi- 2010 Evo X MR w/ some extra powahhh
currently having Lotus withdrawals
www.CTDesigns.us
FLuXeXigeS is offline
post #25 of 208 (permalink) Old 01-04-2009, 10:19 PM
Charlie I was keen on the variable 2-11 style tc as well. How did you do this genuine lotus or racelogic hardware?
ozracer is offline
post #26 of 208 (permalink) Old 01-04-2009, 11:00 PM
xceed's Avatar
I'd jump on this the very second it's available! Get working people!
2009 Solar Yellow Fed. Lotus Elise
[BoE TVS Rev400 Charge Cooled, ACT HDSS Cluth, Comp Cluth 7.5lbs Flywheel, PPE Cermic Coated SC Header w/ Testpipe, BoE QuarterStick Exhaust, BoE RaceLinks] - [Currently @ ? Miles]
xceed is offline
post #27 of 208 (permalink) Old 01-14-2009, 03:43 AM
ads_green's Avatar
I think that you can retrofit the 08 dash but you'll need an 08 ecu too (unless you have a can converter like teh one above). I don't think the wiring harness is that different but I could be wrong.
ads_green is offline
post #28 of 208 (permalink) Old 01-14-2009, 06:02 AM
Inactive
dstevens's Avatar
Does anyone have a part number and cost for the 08 cluster?
2005 Elise with Honda engine
Please don't PM me - this forum is no longer usable and I do not monitor it.
It was fun while it lasted.
dstevens is offline
post #29 of 208 (permalink) Old 01-14-2009, 01:45 PM
Inactive
dstevens's Avatar
All 08+ cars has the same mph dash, part # A1216001F, retail $750
dstevens is offline
post #30 of 208 (permalink) Old 01-14-2009, 02:11 PM
OSX Black hat
charliex's Avatar
the wiring harness is different, different CAN bus speeds, slightly different data stream
the cluster is setup to handle c/f kph/mph switches
charliex is offline
post #31 of 208 (permalink) Old 01-14-2009, 02:12 PM
OSX Black hat
charliex's Avatar
I added launch control and VTC to my 07's ecu software its all the lotus stuff, and the harnesses etc.
charliex is offline
post #32 of 208 (permalink) Old 01-14-2009, 02:17 PM
OSX Black hat
charliex's Avatar
the data stream is posted here
https://www.lotustalk.com/forums/f171...y-asked-66970/
charliex is offline
post #33 of 208 (permalink) Old 01-14-2009, 02:29 PM Thread Starter
Noel's Avatar
So back to the question, who is local to Rob with an 08 whom is willing to help out in this?
Noel is offline
post #34 of 208 (permalink) Old 01-14-2009, 02:40 PM
OSX Black hat
charliex's Avatar
I figured out already with a reflash, but you need to make changes to the harness, unfortunately its the main harness that runs from the back of the car into the cluster, its not terrifically hard to replace but its time consuming.
You might be able to patch the old one, but its going to be a PITA.
without an ecu path rob has to drop the 07 CAN speed from 1mbps to 500kbps then translate the data thats different, which is just the tc/mil/oil/shift light etc, but not all the information the 08 cluster wants is in that can data, the extra text won't work either, but that could be handled with a man in the middle box too, just no TPMS.
the ecu spits out different standards now instead of the cluster figuring it out, ie the kph/mph switch is in the ecu.
charliex is offline
post #35 of 208 (permalink) Old 01-14-2009, 09:08 PM
Inactive
dstevens's Avatar
I think I will swap the 05 for the 08 cluster. Remember that I had to add a CAN output to the Honda ECU for the 05 cluster, so this won't be any more difficult for the 08 cluster other than working out the new packet format. Now I'm tempted to add messages to the dash using the 401 ID... It would be nice to get the temp display to show something under 158 degrees too. Still, it's better than the S1 dash fuel gauge which would give up and say 'FILL' once you get below 9 litres.
dstevens is offline
post #36 of 208 (permalink) Old 01-14-2009, 09:45 PM
OSX Black hat
charliex's Avatar
I'm going to have mine write in lower case with l337speak
Just drop it to 500Kbps the main stuff will work.
charliex is offline
post #37 of 208 (permalink) Old 01-15-2009, 07:27 AM
rob13572468's Avatar
The text line is actually perfect for a V1 interface. I already manufacture the interface here:
YouTube - Valentine One Interface for 2008 Mercedes ML
and the CAN gateway board is in full production already so there are really zero hardware development costs to do this other than just programming the software to translate the frames.
SO basically you could have the new cluster in an old vehicle with the added totally cool functionality of having your V1 put its alerts directly on the cluster instead of having to do one of those ugly chop jobs where the outboard display gets hacked into the dash. Additionally if anyone has an 08 and wants the V1 display on their dash they could have this as well...
rob13572468 is offline
post #38 of 208 (permalink) Old 01-15-2009, 08:06 AM
purveyor of lightness
darkSol's Avatar
Well that's worth it to get the 08' cluster just for THAT feature... seriously!
Sooo Rob... how much for da little black box?
d.a..v...i....d
David Thomas Stewart - [email protected]
2005 Midnight Silver Lotus Elise (www.darksol.com)
388hp (342whp) BOE RevX 1676lbs.
darkSol is online now
post #39 of 208 (permalink) Old 01-15-2009, 08:47 AM
OSX Black hat
charliex's Avatar
Rob, i think you've got everything you need to get it going then, i'll work on the remaining bitfield for the status lights.
Yep i've been using the text for all sorts of things, didn't think about the V1, but i don't have one
charliex is offline
post #40 of 208 (permalink) Old 01-16-2009, 02:32 AM
thats pretty cool for what your doing because you can use the text display for a menu/feature and use the traction control button for selection (e.g. like hold the traction control button to enter menu mode. then press to select which tune you want to run, then hold again to use that tune.
