Retrofit 08 Instrument Cluster? - Page 5 - LotusTalk - The Lotus Cars Community
 2Likes
post #81 of 211 (permalink) Old 01-29-2009, 06:55 PM
Inactive
dstevens's Avatar
Today:
1. The large connector on the 2005 and 2008 dash is the same.
2. Lotus has the numeral desination for the B connector reversed end to end. eg what they list as B12, 222/BP can be found in B1, not B12. This is consistent from the 2005, 2006 and 2008 manuals.
3. Differences from 2005 to 2008:
- A1 (power) moved to A3
- A3 (power) moved to A5
- C1 (CANH) moved to A7
- C7 (CANL) moved to B7
- C5 (illum) moved to A10
- A10 (alt) moved to A4
This does not quite make sense. For instance CANL on B7 conclicts with the B6 designation of the illumination wire, once the B6 is corrected to B7. I think there are errors in the 2008 wiring diagram posted. Can someone with the original manual check that for me, or if someone has their 2008 dash out, verify the wire colors?
4. The pins are different between the 2005 AB connector and C connector. Since I need to move the wires from the C connector to the AB connector, I'm going to have to track down those terminals.
2005 Elise with Honda engine
dstevens is offline
post #82 of 211 (permalink) Old 01-30-2009, 03:37 PM
Inactive
dstevens's Avatar
I've tested each pin on the 2008 cluster. It seems that Lotus has corrected the pin assignment problem with the 05-06 manual, so the B connector is not reversed. It could be that I was mistaken with the 05 B pin numbers - I'll check again.
1. On Charlie's 2005 wiring diagram, A1 and A3 and transposed.
2. On Charlie's 2008 wiring diagram, B6, A7 and B7 have the wrong wire numbers.
My conversion table now looks like this:
Code:
Pin	2005			2008			Change
A1	29,P	Bat Power
A2	206,B	GND		206,B	GND		-
A3	25,G	Fused Ign	29,P	Bat Power	A1
A4				110,NY	Alternator	A10
A5				25,G	Gauge Power	A3
A6				179,PK	Alarm Light	B6
A7				430,U	CANH		C1
A8	76,RY	Rear Fog	76,RY
A9	86,UW	Main Beam	86,UW	Main Beam	-
A10	110,NY	Alternator	402,RO	Illum		C5
A11	51,GR	Indicator	51,GR	Indicator	-
A12	45,GW	Indicator	45,GW	Indicator	-
B1	222,BP	SRS		113,BW	Brake		B12
B2	342,PW	Doors
B3				138,BY	ABS		B10
B4	105,RW	Trip switch	167,BP	Seatbelt	B9
B5	118,GR	Fuse C3
B6	179,PK	Alarm		98,R0	Lights		B7
B7	98,RO	Lights		430,U	CANL		C7
B8				118,GR	Backlight	B5
B9	167,BP	Seatbelt	105,RW	Trip switch	B4
B10	138,BY	ABS
B11				342,PW	Doors		B2
B12	113,BW	Brake		222,BP	SRS		B1
C1	428,R	CANH
C5	402,RO	Illum
C7	430,U	CANL
dstevens is offline
post #83 of 211 (permalink) Old 01-30-2009, 07:40 PM
Inactive
dstevens's Avatar
Re-pinned the connector apart from the C connector, and everything works so far. Next step is to wire up the CAN and illumination signal from the C connector.
The Lotus manual was correct - I had the B pin numbering incorrect. Ignore those points in the posts above.
Code:
A1	29,P	Bat Power
A6				179,PK	Alarm Light	B7
A7				430,U	CANH		C1
B1	113,BW	Brake		113,BW	Brake		-
B2
B3	138,BY	ABS		138,BY	ABS		-
B4	167,BP	Seatbelt	167,BP	Seatbelt	-
B5
B6	98,RO	Lights		98,R0	Lights		-
B7	179,PK	Alarm		430,U	CANL		C7
B8	118,GR	Fuse C3		118,GR	Backlight	-
B9	105,RW	Trip switch	105,RW	Trip switch	-
B10
B11	342,PW	Doors		342,PW	Doors		-
B12	222,BP	SRS		222,BP	SRS		-
C1	428,R	CANH
C5	402,RO	Illum
C7	430,U	CANL
dstevens is offline
post #84 of 211 (permalink) Old 02-02-2009, 06:39 PM
Inactive
dstevens's Avatar
Finished wiring the connectors tonight. Next step is to calibrate the speedo and odometer with GPS.
<object width="640" height="505"><param name="movie" value="http://www.youtube.com/v/EfCr1H1VBkw&hl=en&fs=1&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/EfCr1H1VBkw&hl=en&fs=1&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="505"></embed></object>
dstevens is offline
post #85 of 211 (permalink) Old 02-02-2009, 07:12 PM
British_Marques's Avatar
That is just awesome, Congratulations. What is next, really?
2005 Elise Starlight Black
1991 Elan Monaco White
1973 Triumph Stag, second owner.
1975 XJ12C Jaguar pillarless coupe.
1960 Daimler Limo, drives great look like hell, project in the works.
British_Marques is offline
post #86 of 211 (permalink) Old 02-04-2009, 12:38 PM
xceed's Avatar
Total pimp! Come hook me up, airfare is covered, and so is your first meal! ;p
2009 Solar Yellow Fed. Lotus Elise
[BoE TVS Rev400 Charge Cooled, ACT HDSS Cluth, Comp Cluth 7.5lbs Flywheel, PPE Cermic Coated SC Header w/ Testpipe, BoE QuarterStick Exhaust, BoE RaceLinks] - [Currently @ ? Miles]
xceed is offline
post #87 of 211 (permalink) Old 02-11-2009, 12:15 PM
MTribe's Avatar
I may need to get my 06 cluster replaced under warranty soon--maybe I can get them to replace it with an 08 instead, and then I can do this conversion?
Anyone game to give a status report?
Thanks so much for taking the time to do this--very much appreciated by people like me!
Lotus Sport Elise #24
71 TR6
MTribe is offline
post #88 of 211 (permalink) Old 02-11-2009, 12:36 PM
chris heath's Avatar
i am in. lets here the price and who can do it. lol. i wish i was smart enough to do it.
chris heath is offline
post #89 of 211 (permalink) Old 02-11-2009, 06:39 PM
Inactive
dstevens's Avatar
My conversion will only work with the Honda ECU. For the stock ECU you need to get an update from rob13572468 - hopefully some of the work I did will help him out.
dstevens is offline
post #90 of 211 (permalink) Old 02-11-2009, 06:48 PM
thanks D
i cant wait until this is an option to get done. im saving my pennies now
post #91 of 211 (permalink) Old 02-11-2009, 08:33 PM
rob13572468's Avatar
i have the software basically done.. i need to do a little bit of testing with the actual cluster and i hope to have some time to do that in the next few weeks..
rob13572468 is offline
post #92 of 211 (permalink) Old 02-11-2009, 09:19 PM
rob that is awesome. you guys are so smart. i wish i knew half of what you did
post #93 of 211 (permalink) Old 02-12-2009, 04:26 AM Thread Starter
Noel's Avatar
Location: 33.87S 151.21E Car: ロータス MKII エキシージ Type: Komo-Tec S300
Thank you for the update Rob, awaiting to hear your good news.
Noel is offline
post #94 of 211 (permalink) Old 02-12-2009, 06:24 AM
im like a kid in a candy store waiting for this. lol
post #95 of 211 (permalink) Old 03-29-2009, 11:35 PM
looney's Avatar
any updates?
looney is offline
post #96 of 211 (permalink) Old 03-31-2009, 04:00 PM
i would pay to retrofit an 08 cluster to my 05. Looking for an update too.
danielg is offline
post #97 of 211 (permalink) Old 03-31-2009, 04:24 PM
OSX Black hat
charliex's Avatar
i dunno whats going on with the others, i'm waiting on my black cluster to arrive so i'm done, i'll post up pics when i get it in.
Black Exige S / Elan M100. Don't run a smaller pulley without an upgraded fuel pump! http://www.goth.am ecu stuff.. New reflash box coming soon!
charliex is offline
post #98 of 211 (permalink) Old 04-01-2009, 01:20 AM
Ive been busy with our mercedes benz remote starter project which has been insanely popular and as a result has taken up all the work time in the past 2 months. Fortunately now remote start season is coming to a close so I have time to work on other projects like the cluster converter.
I would expect to have some boards ready to go in the next few weeks...
post #99 of 211 (permalink) Old 04-04-2009, 01:33 AM
Trendy Exige's Avatar
Thumbs up
I am interested in this retrofit speedometer conversion upgrade once everything is finalized. I've been wanting this for quite some time now.
Trendy Exige is offline
post #100 of 211 (permalink) Old 04-04-2009, 01:43 AM
Hopefully charlie will have an update soon. Is the information that was available when scrolled standard or is there some sort of obd interface that will allow the assesment of further information
ozracer is offline
