Switch pack module: any problems? - LotusTalk - The Lotus Cars Community
 1Likes
post #1 of 37 (permalink) Old 01-28-2008, 08:12 PM Thread Starter
sleepe's Avatar
Has anybody replaced their switch pack module and for what reason?
My headlights are both out and I believe the switch pack is at fault.
-Robert
PROBLEM SOLVED: It was my mistake. I had some wires mixed up.
2006 Elise ST (someone else has it now . . . )
2008 Exige S240 ST
sleepe is offline
post #2 of 37 (permalink) Old 01-29-2008, 02:52 AM
I had a problem with my switchpack on my 05 Elise. Heard it was pretty common and an absolute PITA to replace. It controls a lot of things too, so a bad one can present with numerous symptoms.
scottyb is offline
post #3 of 37 (permalink) Old 01-29-2008, 03:34 AM
SirLotus's Avatar
Seemingly, although the Switch Pack Module is shown as being 6 relays, it does in fact incorportate soild state electronics. An interesting point is that if you look at wiring diagram #7 the high beam headlights are not depicted as being controlled by the headlight switch and we all know they are.
SirLotus is offline
post #4 of 37 (permalink) Old 01-29-2008, 05:53 AM
xtn
xtn's Avatar
I thought the high-beams were controlled by the column-mounted switch (blinkers). No?
2006 McLareghini Bugatterrari, Storm Titanium... installed: air horn, Scroth 4-point ASM harnesses, Sector111 halon extinguisher and mounting bracket, Von Hep exhaust and rear panel delete, Pagid brake pads, red Volks CE28n wheels, Toyo RA-1 tires, Nitron SA coilovers, Sector111 (WorksBell) quick-disconnect steering wheel kit. awaiting installation: Scroth "pull-up" lap belts, Sector111 RTD Brace, Tony's heater bypass mod, and dropped steering rack mounting plates.
xtn is offline
post #5 of 37 (permalink) Old 01-29-2008, 06:36 AM
SirLotus's Avatar
Yes they are, however the headlight switch has to be on first. Try it, put your high beams on, then turn off the headlight switch, they will go off.
The so called column mounted dip switch does not actually switch between high and low beams because low is always on with the headlight switch. The dip/flasher switch actually just additionally turns on the high beams.
If you look at the wiring diagram the high beams are not shown as being controlled by the headlight switch but they are. Lotus informed me that it could not be shown on the diagram
SirLotus is offline
post #6 of 37 (permalink) Old 01-29-2008, 07:42 AM
gtlotus's Avatar
Both my low beam were out? I tracked it down and believe it or not it was the bulbs. I spoke with the dealer and he said that they have had problems with the switch pack module and they carry the part in stock.
gtlotus is offline
post #7 of 37 (permalink) Old 01-29-2008, 07:47 AM
chotto's Avatar
The switch pack module was the cause of one of my low beams being out.
2005 SY-REV310 Supercharger, clam hinge, 2bular 8" single tip exhaust, 2bular header, Ohlin Double Adjustables, RTDbrace, Custom Kirkey 58 Series seats, Schroth 6 pt. harnesses, Multivex mirrors, Race battery, Micromirror, HID's, V2arms, Sparco removeable steering wheel, Volk CE28N's with Hoosier R7's, Pagid RS 14 pads, Cup airbox, catch cans, Ultradiscs, gPan, splitter, canards, Reverie wing, 6 element diffuser, proRad
chotto is offline
post #8 of 37 (permalink) Old 01-29-2008, 07:59 AM
How much of a pig is it to remove? One of my low beams is flaky (flickers on and off when going over a bump) and dealer says it is the module and not the beam itself. I replaced the same beam about 2 years ago and wanted to try again before taking it in to dealer for the warranty work.
Toad is offline
post #9 of 37 (permalink) Old 01-29-2008, 08:08 AM Thread Starter
sleepe's Avatar
Did both your low beams go out simultaneously?
This is what happened to my 06 Elise: after startup I pushed the headlight button and both low beams slowly faded until completely going out. -Robert
2008 Exige S240 ST
sleepe is offline
post #10 of 37 (permalink) Old 01-29-2008, 08:10 AM Thread Starter
sleepe's Avatar
Did you draw this conclusion on your own?
Did you have the bulb and switch pack replaced?
-Robert
2008 Exige S240 ST
sleepe is offline
post #11 of 37 (permalink) Old 01-29-2008, 08:11 AM Thread Starter
sleepe's Avatar
Are the headlight relays housed in the switch pack module?
What is a RELAY?
-Robert
2008 Exige S240 ST
sleepe is offline
post #12 of 37 (permalink) Old 01-29-2008, 08:26 AM
SirLotus's Avatar
http://sector111spyder.blogspot.com/...h-removal.html
A relay is a switching device that from a low current input is able to switch a higher current or mulitible outputs on isolated circuits. The Switch Pack Module has no relays, it uses electronic switching, even though the wiring diagram shows relays. The switching for the headlights is in this module.
SirLotus is offline
post #13 of 37 (permalink) Old 01-29-2008, 08:27 AM
MidasHands's Avatar
I have had one headlight low beam problem for a while too on my '06.
This might be a silly question, but does this switch pack also have anything to do with the A/C Relay Switch that can cause a power drop out during acceleration? I think I have this problem too.
- Mike
2006 KG Elise, Magnolia Interior
MidasHands is offline
post #14 of 37 (permalink) Old 01-29-2008, 08:37 AM
SirLotus's Avatar
The Switch Pack has outputs to the A/C Switch, Recirculating Switch, Recirculting Actuator & Fan Speed Switch
SirLotus is offline
post #15 of 37 (permalink) Old 01-29-2008, 04:26 PM
TimMullen's Avatar
The Switch Pack has outputs to the A/C Switch, Recirculating Switch, Recirculating Actuator & Fan Speed Switch
But those should be the back light to light up the switches/buttons at night, not the actual electronics of the switches circuits.
94 Miata R Package - Black
TimMullen is offline
post #16 of 37 (permalink) Old 01-29-2008, 04:48 PM
SirLotus's Avatar
Not true, circuit 380 & 384 go to the switch contacts.
SirLotus is offline
post #17 of 37 (permalink) Old 01-29-2008, 05:02 PM
TimMullen's Avatar
I stand corrected. good to know.
post #18 of 37 (permalink) Old 01-29-2008, 05:04 PM
SirLotus's Avatar
Apparently Tim, a lot of different functions go on within the module that are not shown in the diagrams.
SirLotus is offline
post #19 of 37 (permalink) Old 02-03-2008, 12:09 AM
Westrock's Avatar
I had the SPM go on the fritz a couple times over the last year. I went driving one night for about 2 hours and when I got about 10 minutes from my destination my headlights started going on and off everytime I hit a bump (which is alot in this car!). After letting the car sit a while they worked fine on the way back except when I got about 10 minutes from home the lights started doing the same thing. So I figured the relays were getting hot and then they can't hold. So I did the DRL mod to reduce the strain on the SPM so the headlights aren't always on.
Heres a picture of the SPM circuit board
Westrock is offline
post #20 of 37 (permalink) Old 02-03-2008, 04:07 AM
SirLotus's Avatar
David, thanks for posting these photo's of the mysterious SPM, and it is more complex than shown in the wiring diagram.
I keep my headlights on during the day to make me more visible even though I don't have DRL.
SirLotus is offline
