2ZZ MRS! - Where should I go next? - LotusTalk - The Lotus Cars Community
 1Likes
  • 1 Post By machine.gun.kelly
post #1 of 8 (permalink) Old 03-05-2017, 08:48 AM Thread Starter
00 MRS - 2ZZ NA
GTsRasta's Avatar
Cool 2ZZ MRS! - Where should I go next?
Hello all! I used to troll a lot & made the Supercharger FAQ on newcelica.org, but graduate school & medical school got in the way._ Now I'm back, & I'd like to share my current project and post up a baseline dyno here by the end of Summer, after school.
My 03 Celica GTS bit the dust when someone blew a stop sign & took her out, so I pulled the GTS 2zz, stored it in my garage, and I'm working on this project I bought from an owner in California._ After fixing almost all the faults of this swap...I built up the suspension first...pretty much to the MAX._ Later, I'm looking to max out the stock MRS 2zz with a emanage ultimate + vmanage tune and add flex fuel. And even later, I'd like to build the GTS 2zz for a stroker, GTX35R, standalone, etc._ Here's what I'm working with:
2000 Toyota MR2 Spyder (Solar Yellow)
2ZZ-GE Swap (Matrix XRS)
2000 Toyota Celica GTS Stock ECU
C60 6 Speed Transmission *(Matrix XRS)
Monkeywrench Racing 2zz Swap Header
CHE (Topspeed) Performance Down Pipe*
Apex'i N1 Evo Exhaust
PPE 2zz Swap Intake
Injen Air Filter Heat Shield
AEM Dryflow Bruteforce Air Filter
Exedy OEM Replacement Clutch
Speed Source Extended Clutch Pushrod
Fidanza Flywheel
Toyota MR2 Spyder Helical LSD*
Tein Super Street Coilovers
TRD Front Tower Brace
Seibon Carbon Fiber Hood
Lotus OEM Spark Plug Cover
Toyota Supra Clear Corners
eBay Lip Spoiler
eBay Drilled & Slotted Rotors
15' Enkei RPF1 Rims (Black)
195/50/15 &*205/50/15 Bridgestone Potenza RE-11A Tires
MWR Alternator Underdrive Pulley
MWR Water Pump Underdrive Pulley
Gates Pulley (for MWR UD Pulleys)
Apex'i Mounted Tach Pod*
Apex'i Grounding Kit
MRS JDM Navpod
TWM Desert Eagle Shift Knob (Gunmetal)
2003+ MRS Side Vents
2003+ MRS Front Air Dam
Monkeywrench Racing Cruise Control Kit V2 (Not Installed)
Monkeywrench Racing Short Shifter*
Monkeywrench Racing Shifter Base Bushings
Speed Source Cable Bushings
Moroso Baffled Oil Pan
Monkeywrench Racing MRS Oil Cooler Kit
Twosrus Front Outer Tie Rod Ends
Twosrus Front "Beefy Bar" End Links
Stoptech Front Stainless Steel Brake Lines
Stoptech Rear Stainless Steel Brake Lines
Motul RBF 600 Brake Fluid
Redline MT-90 Synthetic Gear Oil
Speed Source Stainless Braided Clutch Line*
Che Front Lower Brace
Che Rear Lower Brace (Not Installed)
Corky Breast Plate
Ultra Racing 3 Point Fender Braces (Not Installed)
Ultra Racing Front Member Brace
Ultra Racing Middle Member Brace
Ultra Racing Rear Member Brace
Ultra Racing Rear Lower Member Brace (Not installed - Need 04-05 Rear Chassis Subframe)
Ultra Racing Rear Tower Bar
Whiteline Front Sway Bar (22 mm)
CHÉ Rear Sway Bar
Whiteline*Front Control Arm Lower Inner Front Bushings
Whiteline*Front Control Arm Lower Inner Rear Bushings*(Stock Caster Spec- Not Installed)
Megan Racing Rear Lower Control Arms
Megan Racing Rear Toe Control Arms
Megan Racing Rear Trailing Arms
Toyota Delrin Shifter Linkage Cover (Transmission Side)
DDPR Rear Motor Mount Heat Shield
DDPR Flywheel Cover
PHILIPS HID Slim Canbus - H4 H/L 6000K
I'll post up more pics later. Where should I go next with my project?
GTsRasta is offline
post #2 of 8 (permalink) Old 03-05-2017, 09:17 AM
Sig
machine.gun.kelly's Avatar
It looks like it's time for you to graduate to a Lotus...
Motard likes this.
Whoever said that island life is great was never committed to Alcatraz...
machine.gun.kelly is offline
post #3 of 8 (permalink) Old 03-05-2017, 09:20 AM
Sig
BTW...What was the original engine? And the PPE intake is just a cold air intake for the engine swap?
post #4 of 8 (permalink) Old 03-05-2017, 10:05 AM
kfennell's Avatar
Harness, real tires and go to the track!
kfennell is offline
post #5 of 8 (permalink) Old 03-05-2017, 01:10 PM
Spirit_R's Avatar
^Exactly!
These are fantastic cars, I cannot understand why they are not more popular. Even with the 1zz, they still have just enough grunt to be a blast for a street car. Toyota reliability, well balanced mid engine chassis, cheap parts, and a decent aftermarket. I imagine a 2zz must make these things perfect!
This is a financially logical alternative to a lotus, imo. No worrying about accidents or hitting something and dealing with replacing clams and crash boxes and waiting for parts. If it gets written off, easy enough to quickly find another and transfer your parts over to it.
But... You are on a Lotus forum, so of course I must say, your next step is to get a Lotus as a garage mate to this!
'05 Lotus Elise Touring Hardtop-REV400+Track mods
'94 Mazda RX-7 Twin Turbo-Reliability mods
'09 Dodge Viper VOIX edition-no mods
Spirit_R is offline
post #6 of 8 (permalink) Old 03-05-2017, 01:27 PM
gstomp06's Avatar
Not too long ago I was in the market for one of these. It was either a 2zz mr2 spyder or a turbo miata. I test drive one of these with a stiffened frame and a turbo miata on the same day. I ended up buying the miata because it was the smarter purchase. One-owner, better maintained, and fully documented. But throughout my whole ownership of that miata, I couldn't get the feel of the mr2 spyder out of my mind. No matter what modifications I made to my miata, it couldn't compare.
Ended up selling my miata for the elise.
2007 Chrome Orange Lotus Elise
gstomp06 is offline
post #7 of 8 (permalink) Old 03-05-2017, 01:41 PM
jasonious's Avatar
My biggest complaint with this iteration of the MR2 was the blatant, and I mean blatant, Porsche Boxster styling influence. And they didn't even pull it off very well. Really a shame too, because I'm sure the underpinnings are great. The gen before this had a funky vibe, but this one just reeks poor mans Boxster. I't like the mid 80's Japanese Harley clones with 4 wheels.
jasonious is offline
post #8 of 8 (permalink) Old 03-05-2017, 06:54 PM Thread Starter
00 MRS - 2ZZ NA
GTsRasta's Avatar
Yea the PPE intake are for MRS's with a 2zz Swap. I got it clocked to the left Air opening.
And I wish I could invest in a good pair of seats & harnesses & a roll bar...but I'm only half way through Med school. Still got to refresh & upgrade some stuff before I invest in those. It would help. I was pinned to my door on some turns in my last autocross.
GTsRasta is offline
  LotusTalk - The Lotus Cars Community > Community > Other Cars and Comparisons
