stage 3 cams and N/A - LotusTalk - The Lotus Cars Community
post #1 of 5 (permalink) Old 09-15-2011, 03:02 PM Thread Starter
Cicero's Avatar
Hello all,
I'v got an 06 elise thats NA and I'm going to get the monkey wrench racing stage 3 cams,aswell as the valves,valve springs,everything to do it.
But I want to stay NA for now then supercharged later on, the question is has anyone done this before? I'll also be installing the blackwatch light weight flywheel and the blackwatch clutch and the bigger oil pan aswell as a better oil pump gear while im at it
what do I do about the ecu? The car now has larini 8'' exhaust
I know I'll need a retune or a new ecu but I have no idea what to do about it.
Is their a way to modify the stock ecu or do I need to buy and after market one? If so which one?...
I'll be doing all this at once with the clam off.
Cicero is offline
post #2 of 5 (permalink) Old 09-15-2011, 03:56 PM
halcyon's Avatar
Stand-alone ECU or reflash. Use the search function, and you'll find answers to your questions.
amber
06'CO Exige
If in doubt....flat out!!!
halcyon is offline
post #3 of 5 (permalink) Old 09-15-2011, 08:01 PM
glb
glb's Avatar
Make sure those cams, of which i have no knowledge, work well both NA and blown. Often that's not the case.
glb is offline
post #4 of 5 (permalink) Old 09-16-2011, 07:46 AM Thread Starter
Cicero's Avatar
Thank you, and yes I beleive they'll work with both, Says it in the description anyways.
Cicero is offline
post #5 of 5 (permalink) Old 09-16-2011, 09:14 AM
attila85's Avatar
If you do it properly, you won't want to supercharge it later, but forget reflashes, you need a good standalone ecu.
You should check this out too, before you drop the hammer:
https://www.lotustalk.com/forums/f25/...-power-105672/
attila85 is offline
  LotusTalk - The Lotus Cars Community > Lotus Discussions > Powertrain (Engine, Transmission, etc) > Intake and Exhausts
