'07 Exige S Thermostat - LotusTalk - The Lotus Cars Community
post #1 of 7 (permalink) Old 04-14-2019, 04:34 AM Thread Starter
henrymfisher's Avatar
Hi guys,
I need to change the dreaded thermostat in my Exige.
I have done this job before in my Elise but add a SC in the way and what PITA.
I have the alternator removed (well moved off to the side as best as possible) and I cannot for the life of me find/locate/or see the water line/thermostat housing.
Crazy question - did they relocate it elsewhere in the Exile or is it so buried under the SC?
Do I have to remove the SC (please tell me NO!!!).
Thanks,
Henry
'07 Exige S
Henry
'05 Elise
henrymfisher is offline
post #2 of 7 (permalink) Old 04-14-2019, 05:22 AM
The thermostat is in the same location but it is a pain to get to. I have a Rev400 and had to largely remove the SC nose support bracket and then use a wobble and extension to get to the nut closest to the passenger rear wheel. The inboard nut I had to reach around and under the SC, which was the easier to remove. A bit of a frustrating job but doable without SC removal.
Zink is offline
post #3 of 7 (permalink) Old 04-14-2019, 09:32 AM
thebuzzard's Avatar
There is also the matter of vent tube no.1. @Zink do you have one in place or is it blanked off? It is possible to remove the top half of the tube to make some space.
@henrymfisher are you working with clam on or off? If the clam is off, I'd recommend just taking that supercharger off. Have you replaced the SC oil recently? If the clam is on, removing the nose bracket may be the way to go I guess, recalling that the bracket location is defined by the alternator.
Good luck!
Sent from my Pixel 3 XL using Tapatalk
2007 Exige S
Stripped down and turned into a track animal
thebuzzard is offline
post #4 of 7 (permalink) Old 04-14-2019, 11:03 AM
Good point @thebuzzard I have blanking plates over the vent tube but I gained access from underneath the engine, so not sure whether the tube would have created an access problem or not.
Zink is offline
post #5 of 7 (permalink) Old 04-14-2019, 11:48 AM
kfennell's Avatar
OHH good point, not sure how much of an access problem the vent adds, I don't have one in FYI (we have been talking via PM).
kfennell is offline
post #6 of 7 (permalink) Old 04-15-2019, 05:46 AM
InfernoLotus's Avatar
I changed my thermostat out, and I have a BWR supercharger, a few months ago. I pulled the right rear wheel, then the wheel well liner, and was able to go in that way under the SC. Very tight and tedious but it works. Saved pulling the clam or SC so it was worth the extra effort. Put in an ALL Metal thermostat and all is good now. My car would not warm up due to the dreaded rubber ring coming off and lodging the plate open. Good luck!
Central Florida
InfernoLotus is offline
post #7 of 7 (permalink) Old 04-15-2019, 02:16 PM Thread Starter
First of all thanks for all of the suggestions and especially to KFennel.
The job was a serious PITA, but it is complete.
My car is an '07 Exige with AC. Passenger rear wheel liner out, motor mount out, bracket that supports motor mount out,
belt off, alternator out, vent tube unbolted off of motor and moved out of the way.
Now I finally had a hole large enough for my right arm to go through and bend and with a 1/4" 10mm socket, undid the two 10mm nuts.
One of the biggest issues was there are parts of the wiring harness that sits literally on top of the t-stat housing, but I finagled the housing off.
The last kick in the pants was the old t-stat (rubber center) was not torn or pulled off of the center steel section. I tested it and my new one on the stove. Both
opened up at 180 degrees. But now I have an new all steel unit in.
Waiting on my new front radiator GRP hoses while calm is off, then new rad goes in along with other bits up front and re-coolant the car.
It was a long day, but this part is done. Thanks again guys. Lotus Talk rules!!
Henry
'07 Exige S
Henry
'05 Elise
Similar Threads
What All-Metal Thermostat is Recommended for the Elise / Exige? Nickshu Lotus Elise 4 10-16-2016 06:51 PM
FS: Thermostat for Elise Exige 2ZZ Dave Parts For Sale 2 12-29-2012 04:39 AM
Trade 07 Exige S CO for 06-07 Elise C Orange orangespyder Lotus Cars For Sale 4 05-25-2008 07:50 PM
exige S's made after jan. 07 not same as b4 jan. 07, READ B4 U BUY PARTS THAT DNT FIT shadowgts24 Lotus Exige 16 08-14-2007 03:49 PM
07.07.07 AgentTripleX Other 16 07-09-2007 09:12 PM
