1zz Oil Pan? - LotusTalk - The Lotus Cars Community
post #1 of 11 (permalink) Old 05-24-2019, 10:31 PM Thread Starter
gillam's Avatar
1zz Oil Pan?
I stumbled across a YouTube video that recommended changing the 2zz oil pan that doesn't(?) have baffling to the 1zz pan that has a windage tray. I find it hard to believe a car that's designed for track use would have a problem with oil starvation due to lack of baffling. Say it ain't so.
I have a '07 Exige and have been searching the forum about this baffling issue. I did find a thread that asked the question about baffling, but didn't see an answer.
Does my '07 have baffles? The video that recommended changing the 2zz pan to 1zz showed a modification had to be made to the 1zz tray to fit onto a 2zz motor.
I'm not a track rat so don't want to pay $500+ for a Moroso
I'm baffled. Has anybody figured this out for sure?
Thanks
gillam is offline
post #2 of 11 (permalink) Old 05-24-2019, 11:27 PM
The Enforcer
oldmansan's Avatar
Thanks
You don't need to be a track rat to be concerned about oil starvation during aggressive cornering. The aftermarket pans also increase oil capacity. Cheap insurance IMHO.
San
oldmansan is offline
post #3 of 11 (permalink) Old 05-25-2019, 04:19 AM
Oil starvation seems to be track related.
I might be starting to see a trend in the oil temp thread that the larger alloy pans keep oil temps low, but I cannot confirm that as of yet.
exigegus is online now
post #4 of 11 (permalink) Old 05-29-2019, 11:47 AM Thread Starter
gillam's Avatar
Since readers don't know about baffling in the Lotus 2zz pan, I went back to the YouTube video referenced previously and looked at the comment section. Found this to be somewhat interesting. The YouTube I'm referring to can be found here:
One comment I thought was interesting:
From Toyota "The oil pan itself is without a baffle. This quickens the return of oil into the oil pan, increasing performance. Air suction was minimized by optimally positioning the suction pipe inlet"
The 2ZZ-GE can withstand 1.0G without sucking air."The problem with this is that many of the 2zz cars can pull 1.0G+ with good grip tires. And we know that the 2zz has had numerous issues in the oiling department. Which is why Lotus opted to use Accusump to keep oil pressure constant.
-------------END-------------------------
My "spirited" (Advan tires) driving in mountain canyons probably won't produce g forces over 1g? From what I've read, .9g is typical on the track with standard tires. I guess I shouldn't worry about the baffling. Are my assumptions correct? Of course, you can always fall back to better safe than sorry.
Clearly, keeping the sump topped off is important.....
gillam is offline
post #5 of 11 (permalink) Old 05-29-2019, 12:42 PM
Interesting i wonder if there is a downside to the 1ZZ pan
post #6 of 11 (permalink) Old 05-29-2019, 01:39 PM
The 1ZZ pan looks a lot like the 5S pan. The 1ZZ is a ~6K RPM engine, as is the 5S.
Looking at the pan, I'd guess that pooling on the slosh baffle/windage tray at high RPM was a concern. That, or maybe cylinder windage pumping volume issues. With an installed height limitation (longitudinal mounting crossmember on Toyotas) they couldn't put the sump down any further, so the best option was just to take the welded in windage tray out and hope things stratified. I'd be curious to see what TRD elected to do on their own 'works special' 2zz cars.
In any case, we have our choice of at least two good gated pans for the 2ZZ. I would certainly install one before a track day, and wouldn't dare do track time on R compound tires without.
steelypip is offline
post #7 of 11 (permalink) Old 05-29-2019, 01:58 PM
Addict
LostPawn's Avatar
It looks like the OP is in Colorado, you can hit over 1g at HPR or Pueblo with plenty of tires let alone R compounds.
LostPawn is online now
post #8 of 11 (permalink) Old 05-29-2019, 02:48 PM
henrymfisher's Avatar
I run the Moroso baffled pan on my '07 Exige S
Never gave it a second thought since I think it is cheap insurance against oil starvation.
I found the Moroso unit on ebay for around $400 brand new. Removing the old unit and installing
the new one with some liquid gasket sealant was easy and straight forward.
Henry
'07 Exige S
Henry
'05 Elise
henrymfisher is online now
post #9 of 11 (permalink) Old 05-30-2019, 08:11 AM
This. It's cheap (cost of a good detailing job) and easy. We don't have the cradle crossmember, so you're literally looking up at the entire oil pan once you have removed the engine access panel. BTW, while the pan is off is the easiest time to do something to the oil cooler sandwich plate and fit a pressure sender, too. I got my car with a gPan on it, so not my problem, but given how well a Lotus sticks, you really want a decent pan on the engine if you start cornering it hard.
post #10 of 11 (permalink) Old 06-14-2019, 06:38 PM Thread Starter
gillam's Avatar
Since posting the question about the lack of baffling in the 2zz, I've decided to go with a baffled pan at some point in the future while keeping a close eye on the oil level. Still can't justify $500 for a oil pan when I don't track the car. I'll be watching ebay for a used pan. There are other things I'd like to spend money on before the oil pan.
I decided to pass on the 1zz pan since the 2zz motor already has a windage tray attached to the bottom of the block.
gillam is offline
post #11 of 11 (permalink) Old 06-14-2019, 08:52 PM
The Enforcer
oldmansan's Avatar
How are you going to "keep a close eye on the oil level" during a high G corner? I know you're guessing about you're cornering rates, but this thread isn't about losing oil, it's about oil pickup/starvation during spirited cornering.
Your first post sounded like you had already decided you didn't want to spend any money on a baffled oil pan, and the post I'm quoting says the same thing, almost verbatim.
Normally I'd cue up comments about people buying sports cars and worrying about their fuel economy and what tire will last the longest while hypermiling, but what's the point? Someone will chime in that a Tesla doesn't need a baffled whatever, and that plastic tweels are the future blah, blah, blah.
San
Similar Threads
WTB Moroso Oil pan, or any other aluminum oil pan with a turbo oil return line! ruggedbert Parts Wanted 0 11-26-2012 11:32 AM
Recommended oil/oil filter/oil pan for Sport 260? RedDaisy675 Lotus Exige 10 11-14-2011 12:08 PM
Oil pan and transmission oil craush washers Litfuse Lotus Elise 4 09-17-2011 10:18 AM
New Moroso Oil Pan Made for 1zz & 2zz - No Modifications Needed rolla_dink Parts For Sale 1 07-14-2010 12:00 PM
2zzge Flywheel n Bolts, Redline oil, 1zzfe Oil Pan RSpyder Parts For Sale 0 01-20-2009 05:04 PM
