2007 Exige Alternator Removal - LotusTalk - The Lotus Cars Community
post #1 of 6 (permalink) Old 03-25-2019, 07:37 AM Thread Starter
henrymfisher's Avatar
Hi guys,
I need to remove the alternator on my '07 Exige S
The thermostat is wonky and needs to be replaced.
I have done this job on an Elise (not exactly an enjoyable job!!) before
but with the supercharger and other material present inside the passenger rear wheel well
I was hoping someone could provide some support or a DYI.
I do not plan on rear clam removal.
So far all I find online are references to Elise not Exige.
Thanks much.
Henry
'07 Exige S
'05 Elise
Henry
'05 Elise
henrymfisher is offline
post #2 of 6 (permalink) Old 03-25-2019, 08:01 AM
Hmmm, Just had the supercharger out, have to look in there
You might have to remover or at least rotate the supercharger/alternator bracket
exigegus is offline
post #3 of 6 (permalink) Old 03-25-2019, 08:01 AM
thebuzzard's Avatar
Do you have the Service Notes? The supercharged supplement is where to look.
What is concerning you?
The alternator is pivoted towards the firewall relative to the NA cars which actually makes the top bolt easier to reach. You might be able to replace the thermostat by simply swinging the alternator back onto the firewall. I don't have an AC any longer and cannot recall the degree to which the compressor gets in the way.
Removing the belt requires a low-profile 19mm socket and breaker-bar. I always have to scratch my head when I come to refitting the belt, so I'd make a good drawing
I have long since decided that getting the clam off is easier than people claim and easier than trying to work through the wheel-arch, but I am pretty ham-fisted.
Good luck!
thebuzzard is online now
post #4 of 6 (permalink) Old 03-25-2019, 08:05 AM
thebuzzard's Avatar
exigegus: The alternator sets the supercharger bracket location, so effectively comes off first. In short, if there is enough space with the alternator off, the supercharger bracket should not be moved.
post #5 of 6 (permalink) Old 03-25-2019, 08:10 AM
The bracket might be in the way to get the alternator out since you cannot, I think go straight up
exigegus is offline
post #6 of 6 (permalink) Old 03-25-2019, 08:24 AM
kfennell's Avatar
I have done this a few times. You can do it with the clam on etc it isn't hard.
Disconnect the battery!
Disconnect the alternator and set it down below being careful not to get the wires caught up or pinched. There are just the two bolts.
Drain the coolant somewhere else so it doesn't all come out on the alternator!
EZ!
kfennell is offline
Similar Threads
07 Elise: front headlight removal for clam removal? Jack FFR1846 Lotus Elise 10 11-21-2014 08:15 AM
Alternator issue on 06 supercharged exige. HELP! jwwither Lotus Exige 3 08-16-2011 07:05 AM
Supercharger install help - alternator removal dgl Forced Induction 3 01-18-2010 07:51 PM
Exige Battery Alternator Problem ACE51 Batteries, Brackets and Chargers 50 07-13-2009 12:58 PM
Better Alternator for Lotus Exige S1 lotustown123 Lotus Exige 1 01-05-2009 03:35 AM
