Airbag Fault 31 Driver Airbag Squib Circuit High Resistance - LotusTalk - The Lotus Cars Community
 2Likes
  • 1 Post By Partsfinder
  • 1 Post By oldmansan
post #1 of 3 (permalink) Old 05-10-2019, 12:08 PM Thread Starter
Hello All, I just recently purchased an 07 Exige S and love that car so far but since I purchased its had an airbag light on the whole time. I purchased the op com ebay airbag reader and managed to get the drivers installed and working with the ECU.
The fault comes up as Airbag Fault 31 Driver Airbag Squib Circuit High Resistance. When I try to clear it, it wont go away. I've read that this could be due to a bad clock spring? The car only has 21k miles on it. Any way the connector could just be loose?
Any input would be greatly appreciated. Seeing the light lit up on the dash is very annoying.
Beasters is offline
post #2 of 3 (permalink) Old 05-11-2019, 04:13 PM
Parts Finder
Partsfinder's Avatar
Air bag comes off pretty easily. Remove the two bolt and pull from wheel. Look at plug going into back of see if it looks melted. Also look down inside column to see if wires pulled lose from clock spring. If all looks good then very well could be bad clock spring. If someone had rack out of car and installed with wheel turned to far one way. Next time a full turn of wheel is done clock spring breaks.
Cory Sharpe likes this.
Past favorites
99 Esprit
02 Eurovan Weekender
62 Falcon 450hp under 2000lbs
(My first power to weight car)
Partsfinder is offline
post #3 of 3 (permalink) Old 05-11-2019, 05:44 PM
The Enforcer
oldmansan's Avatar
Disconnect your battery first.
San
oldmansan is offline
Similar Threads
B1048 Front passenger airbag Sporadic High Resistance p0verty Lotus Evora 6 05-13-2017 12:37 PM
What went wrong? Clutch pedal goes to floor, no resistance, after fluid change Subarubrat Maintenance and Repairs. 16 06-08-2012 08:38 PM
What is the Seat-belt Solenoid Resistance on an Elise? am33r007 Check Engine Codes 4 12-09-2011 11:28 AM
Resistance 2 Nawambo Other 13 11-18-2008 07:20 PM
Resistance: Fall of man Team?? Gojira Other 1 12-29-2006 11:08 AM
