Regarding GCC spec, I believe this only involves the dual AC and standard window-tint-reflective. There is an additional AC unit behind the seats. Interestingly the standard (front) AC unit seems to give up after an hour or 2, but the back one happily boosts along. In full on sun and 40+ (Celcius) you can't have the AC on max because it would freeze your knuckles (and other bits).
I will check if there are any other differences for the GCC. I could imagine another type of air-filter but not sure.
Number plate was mounted a day after I took the pictures. I figured having a long plate with sharp edges in the cabin ...... not the best idea ever
Having no dealer in the country means no (or very little) cars to choose from, so the color isnt much of a choice..... But if I did have a choice I would have still chosen a black one anyway ... its the car and color I've always wanted.
Black isn't too bad if you have shaded parking at home and office and that double AC cools things down extremely quickly! Literally 2 minutes on highest-fan-setting and you have to switch it to the lowest fan-speed and after 5 minutes you have to switch off the extra AC behind the seats because it gets way too cold for comfort!
Will get the windows tinted (slightly) at some point in time, but really havent needed it yet.
Maybe I've just acclimatized after leaving Holland 12 years ago
Related Threads
The Lotus Cars Community
2.7M posts
51.5K members
Since 2002
