Diameter Oil & Water Lines - LotusTalk - The Lotus Cars Community
post #1 of 2 (permalink) Old 08-15-2019, 06:35 AM Thread Starter
Does anyone have a short info how big the Oil & Water Lines are that go through the side sills?
And maybe the OEM used fittings? are they BSP or JIC (DASH) ?
I want to upgrade my cooling system and get all the right fittings before i remove the old ones
ManuelG1986 is offline
post #2 of 2 (permalink) Old 08-15-2019, 08:17 AM
CRG53's Avatar
The oil lines for the coolers are 5/8", or 16mm. The water hoses that feed the radiator are 32mm, but through the sills, it's an aluminum tube. . Then there are the water lines that feed the heater core, can't help you there.
Boe REV 300 Supercharger.
Boe DMC Ultimate header.
Boe Clam Hinge.
Boe Pro Alloy Radiator.
Boe TOC wet sump oil pan.
Boe Fuel surge tank.
Boe Oil catch can.
Boe HP fixed rotors with Ferodo DS 2500 pads.
BWR Larini Group B Muffler.
BWR Street/Track Anti roll bar.
Mocal rear mounted oil cooler.
V2 steering arms,
Nitron Singles 425/550.
InoKinetic DS rear toe links.
CRG53 is offline
