DIY Side Sills - Page 2 - LotusTalk - The Lotus Cars Community
 3Likes
post #21 of 71 (permalink) Old 08-19-2013, 08:03 AM
LiveToDrive's Avatar
Are you thinking of doing a front splitter too?
LiveToDrive is offline
post #22 of 71 (permalink) Old 08-19-2013, 09:33 AM
monarchydesign's Avatar
Originally Posted by da40flyer View Post
I just installed some edge trim I found at Reid Supply. I think it finished it off nicely.
Item No: ELH-1135 [Gripping-Base PVC Door Edge Protection]
How much of the trim did you need? more than 10'? Im picking up my set that i had made from your template this weekend. Thanks a million for sharing the file!
monarchydesign is offline
post #23 of 71 (permalink) Old 08-19-2013, 09:42 AM Thread Starter
You will need two 10' rolls to wrap as I did.
Did you by chance print out a copy of the .dxf to see how they would fit your model year?
Let me know how they work out...
da40flyer is offline
post #24 of 71 (permalink) Old 08-19-2013, 09:53 AM
Closer than you think
GR82DRV's Avatar
Anyone know if these would fit on a 2005 Elise? I know molded Exige sills won't...
2005 BRP Elise Sport, Hardtop, Stage 2 Exhaust, CF side scoops, CF splitter, Composite Worx seats, gunmetal stripes
GR82DRV is offline
post #25 of 71 (permalink) Old 08-19-2013, 09:59 AM
They didnt change the body of the exige from 06-10 did they?...if they need some altering ill take care of it with some dremel action....ill let you guys know though.
post #26 of 71 (permalink) Old 08-19-2013, 12:04 PM
Such moderate
Doge's Avatar
We need someone to be a test mule!
Doge is offline
post #27 of 71 (permalink) Old 08-19-2013, 12:08 PM
GR82DRV's Avatar
Hey, I'm guessing that I could transfer a photocopy to a piece of cardboard for a mock-up... Would that be possible, and where do you get something that size printed?
GR82DRV is offline
post #28 of 71 (permalink) Old 08-19-2013, 12:21 PM
DealsGapCobra's Avatar
They look really good and thanks for sharing the file! I may have a set cut for my 05 Elise.
Did you figure a weight and would you go with 0.100" if you were making another set?
DealsGapCobra is offline
post #29 of 71 (permalink) Old 08-19-2013, 12:22 PM Thread Starter
For those without access to a CAD tool and want to modify the part to fit your specific vehicle, attached is the file saved in Google Sketchup.
sill-final-sketchup.zip
post #30 of 71 (permalink) Old 08-19-2013, 12:26 PM Thread Starter
Didn't figure the weight, but yes, I think .100" works well.
I suppose if you were concerned about the weight, you could certainly have it water-jetted out of a sheet of carbon fiber.
post #31 of 71 (permalink) Old 09-17-2013, 09:41 AM
I did the same thing, except I also made a splitter. They are steel right now but I will be making them out of Aluminum soon I used Solidworks and a CNC plasma table, glad to see that I'm not the only one!
Exiges24017 is offline
post #32 of 71 (permalink) Old 09-17-2013, 10:07 AM
care to share the splitter file? and does it attach to the bottom of the factor splitter as an extension?
post #33 of 71 (permalink) Old 09-17-2013, 10:31 AM
It does not use the factory splitter, it uses the same holes that the factory one does, but also extends all of the way under the front bumper and bolts up to the crash box. Then I used pieces of PVC pipe to put around the bolts at the front to keep the splitter in place. You can see them if you look closely
post #34 of 71 (permalink) Old 09-18-2013, 04:08 AM
Tomiboy's Avatar
That car looks VERY familiar! Blake I have access to a water jetter also
2005 Elise Ardent Red, sport, touring, hard top, soft top, starshield, Braille battery, Sector 111 shift reinforcer, battery box (w/shutoff), micro mirror, and gPAN3. Stan's clutch mod and shifter re-enforcer. Carbotech XP-8 F/R w/Castrol SRF & SS brake lines.
Tomiboy is offline
post #35 of 71 (permalink) Old 09-18-2013, 04:25 AM
If we were to use a water jet, could I just give you the Solidworks file?
post #36 of 71 (permalink) Old 09-28-2013, 10:43 PM
i'll look at this file and maybe give it a go. i have a plasma table and if i'm lucky, enough 1/8" aluminum.
LenMcC is offline
post #37 of 71 (permalink) Old 09-29-2013, 04:03 AM
Almighty's Avatar
That would be awesome if you did this and shared the results. I'm very interested in these sills.
On a design note...
Has anyone thought about adding an inch or more of a lip than hangs down perpendicular to the ground? This should aid in better aerodynamics.
Almighty is offline
post #38 of 71 (permalink) Old 09-29-2013, 06:42 AM
GR82DRV's Avatar
On a design note...
I was considering cutting a 1X6 board with a saber saw to match the outside edge of the metal sills, and then shaping the edge of the wood patern with a router to a radius edge. I'm thinking that if care was taken to protect the aluminum, I could possibly roll the edge over the radius with a hammer and then finish it off if necessary with abrasives.
GR82DRV is offline
post #39 of 71 (permalink) Old 10-14-2014, 07:41 AM
275 Turbo's Avatar
Hi Guys did anyone ever end up fitting these on an Elise ? I think they look great and would make my life allot easier as shipping to NZ is horrendous
2005 Elise 111R, 2litre, 315hp, FF275 Turbo kit 6lbs. Soon to be 400+
275 Turbo is offline
post #40 of 71 (permalink) Old 03-28-2015, 01:37 PM
Lotusxs's Avatar
Attached is a PDF in actual size of the template. This can be taken to any print shop with a large enough printer. Thank you for setting all of this up.
Lotusxs is offline
