Engine sputters when making right turns. - LotusTalk - The Lotus Cars Community
 1Likes
  • 1 Post By zero1954
post #1 of 6 (permalink) Old 05-09-2019, 11:29 AM Thread Starter
zero1954's Avatar
My engine sputters when making regular slow right turns from a stop. I have the following mods installed: REV400, and BOE surge tank. Any ideas? Turbophil?
zero1954 is offline
post #2 of 6 (permalink) Old 05-09-2019, 11:32 AM
A1 Automotive & Smog
Harix's Avatar
Your traction control might kick-in. Try shut it down.
Harix is online now
post #3 of 6 (permalink) Old 05-09-2019, 12:25 PM Thread Starter
zero1954's Avatar
That worked. Thank you very much.
It must be because I disabled my ABS by unplugging left front wheel sensor, had a loss of braking at the end of a long straight when braking hard and I read somewhere on here that disabling the ABS will fix that problem. I guess I'll only disable the ABS when I go on track.
Thanks again.
Harix likes this.
2006 Laser blue Exige
2005 Starlite black Elise SOLD
1970 TVR Vixen S2
Enjoyed and sold many other British sports cars.
zero1954 is offline
post #4 of 6 (permalink) Old 05-10-2019, 07:16 AM
TedR's Avatar
If you have not figured it out from your searching, you likely encountered ICE mode with the ABS. There are ways to mitigate ICE mode, but the only way to totally prevent it, as you have found, it to disable ABS.
TedR is offline
post #5 of 6 (permalink) Old 05-10-2019, 07:38 AM
Saffron Yellow is Lighter
XtinctElise's Avatar
Arrow ICE
Is ICEing a concern at the track with 2005's since traction control was not an option? I have never had an issue with it on mine.
XtinctElise is offline
post #6 of 6 (permalink) Old 05-10-2019, 08:33 AM
TedR's Avatar
I think ICE mode is a problem on track with all Elige's. Definitely started on 05's. It is not a traction control issue, it is an ABS issue. With that said, I have tracked my 05 and have not experienced ICE mode.
TedR is offline
Similar Threads
J-turns and Rockford turns sleepe General Discussion (Lotus related) 6 04-27-2015 11:20 AM
Engine Sputters at low loaded rpm. Gunpilot Powertrain (Engine, Transmission, etc) 106 09-21-2014 09:30 PM
Exige S making a horrific noise on right-turns damen Lotus Exige 8 09-18-2011 08:39 PM
Flickering parking brake light when making hard left turns... Kareem of WheaTT Suspension (including wheels, tires, brakes) 14 06-25-2011 07:36 PM
Car sputters and dies when entering neighborhood qball General Discussion (Lotus related) 19 01-22-2009 05:43 PM
