Front Clam removal - LotusTalk - The Lotus Cars Community
 3Likes
  • 2 Post By exlondoner
  • 1 Post By exlondoner
post #1 of 14 (permalink) Old 12-20-2015, 06:38 PM Thread Starter
UK Exile
exlondoner's Avatar
Front Clam removal
Planning to remove the front clam this week to perform some additional clam modifications and remove the remaining AC.
Is there anything else that is highly encouraged while the clam is off?
exlondoner is offline
post #2 of 14 (permalink) Old 12-20-2015, 06:43 PM
TachItUp's Avatar
With the front clam off, consider an aluminum radiator, upgrade the horn, add stainless brake lines, and blower motor resistor pack R&R (probably not applicable to you)
TachItUp is offline
post #3 of 14 (permalink) Old 12-20-2015, 06:46 PM Thread Starter
UK Exile
exlondoner's Avatar
Thanks. I should have mentioned in my opening thread that there are already SS brake lines in place.
I'll post up pics as I proceed and the finished work.
post #4 of 14 (permalink) Old 12-21-2015, 06:12 AM
EpRAnGia's Avatar
I barely use AC and was thinking of taking it out, too.
How hard is removing AC?
Any detailed DIY thread you are following?
2016 MK7 Golf R
2007 Exige S
2013 Mini Cooper S -SOLD
2011 Porsche Boxster Spyder
2009 BB S2000 - SOLD
2008 AW Exige S240 - SOLD
2004 ChilliRed Mini Cooper - SOLD
EpRAnGia is offline
post #5 of 14 (permalink) Old 12-21-2015, 07:21 AM
I have taken the clam off now a couple of times to fix the blower resistor pack that blew. It really isn't that difficult just be patient and take your time. I am thinking about writing up a detailed post about things I encountered as well as problems and other tidbits of knowledge.
06 Elise is offline
post #6 of 14 (permalink) Old 12-21-2015, 11:06 AM
countryboyshane's Avatar
If would at least pressure test the cooling system if you don't plan replacing the radiator to a 100% aluminum aftermarket setup. The stock radiator end tanks are made of plastic and can leak over the long-term. If there is any leak there, would be nice to know as the clam is off.
I figured out my stock radiator was bad after pressure testing my cooling system two winters ago. It can't hurt to check.
2005 Lotus Elise, naturally aspirated and always at redline!
2018 NASA Great Lakes Region TT4 Champion
countryboyshane is offline
post #7 of 14 (permalink) Old 12-21-2015, 12:14 PM Thread Starter
UK Exile
exlondoner's Avatar
Great suggestions.
I'll put together the instructions on my website under the Tech section with pictures. While I'm at it I'll be installing my newly constructed front brake cooling kit.
EpRAnGia and S_Monaco like this.
post #8 of 14 (permalink) Old 12-21-2015, 04:37 PM
Formulabob's Avatar
That would give you room to mount your battery and washer bottle up front.
Don't forget to protect the lower corners of the windshield when removing and installing the front clam.
Cheers,
Bob L
2008 Solar Yellow Exige S240 (Torque 300)
1991 Elan M100
2015 Cayman GTS
2016 Ford Flex--Tow Vehicle
Formulabob is offline
post #9 of 14 (permalink) Old 12-23-2015, 06:19 PM Thread Starter
UK Exile
exlondoner's Avatar
Cheers Mate - work starts tomorrow, will keep you all posted.
Cheers,
Bob L
post #10 of 14 (permalink) Old 12-24-2015, 04:52 AM
glagola1's Avatar
It's easier to remove the front clam than it is the rear since you don't have to take your entire interior apart.
AC removal isn't really worth the weight savings and especially not worth it when you consider that reinstallation is much more difficult with contaminated lines (you can't remove the lines). Think about resale and residual value.
glagola1 is offline
post #11 of 14 (permalink) Old 12-24-2015, 05:31 AM Thread Starter
UK Exile
exlondoner's Avatar
No selling here.
The compressed was removed about a year ago so may as well just wrap it up.
post #12 of 14 (permalink) Old 12-24-2015, 09:09 AM
This is great to know as I always thought the front would be much harder. I want to replace my radiator as a preventative measure.
Nessal is offline
post #13 of 14 (permalink) Old 12-29-2015, 07:17 PM Thread Starter
UK Exile
exlondoner's Avatar
Just a small update for those interested, the front clam removal took approx 2 hours - first time. The most time consuming part was the loosening of the two bolts within the door hinge area.
No drama and on to removing the condenser which is proving to be a challenge.
Clam is undergoing updates and will post up pics when it's done.
S_Monaco likes this.
post #14 of 14 (permalink) Old 02-12-2019, 01:12 PM
Yes I'm bumping this from the dead. I need to get the condenser replaced, curious what issues you were seeing that were proving to be a challenge? Any additional thoughts now that the job is (presumably) done?
Snowphun is offline
