Help Ssc Cables - LotusTalk - The Lotus Cars Community
post #1 of 10 (permalink) Old 08-15-2019, 02:53 AM Thread Starter
Ptl92600's Avatar
Help Ssc Cables
Hi guys, I’ve been working on upgrading to SSC shifter cables on my MY2007 Exige S, which turns out to be the most teadious job I’ve ever attempted... I finally manage to get the old cables out, 2 hours of bleeding knuckles to get the clips out😭
New cables in and I’m now facing a spacer problem.
The amount of room on the cable heads is ginormous leaving me with the solution of placing 6 spacers on each one to avoid any wiggling and that really doesn’t look any good.
Do any of you know what I’m doing wring here?
Thanks for the support!!
Ptl92600 is offline
post #2 of 10 (permalink) Old 08-15-2019, 06:21 AM
kfennell's Avatar
I drilled out the holes in the shifter and used larger hardware when I put mine together. There are still some spacers involved though.
kfennell is offline
post #3 of 10 (permalink) Old 08-15-2019, 06:33 AM
Addict
LostPawn's Avatar
Can you simply use shorter bolts? The hardware store may have metal tubes you can cut to length to use as a spacer instead of a few washers, I've been able to find these in metric sizes that fit very well over bolts almost like a sleeve.
LostPawn is online now
post #4 of 10 (permalink) Old 08-15-2019, 09:12 AM Thread Starter
Ptl92600's Avatar
Thanks for your imput! I’m not in a harderwarr friendly place right now, so I’ll go with the washers for now and will upgrade to more appropriate stuff later.
Ptl92600 is offline
post #5 of 10 (permalink) Old 08-15-2019, 11:23 AM
mattjk's Avatar
you can order sleeves from mcmaster carr or amazon.
something like this: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
you'll need to find the right size.
https://www.mcmaster.com/spacers
2008 Lotus Exige S240 Aspen WhiteYellow Star shield
2008 Mercedes G500 Black
2014 BMW i3 Rex White
mattjk is offline
post #6 of 10 (permalink) Old 08-15-2019, 07:03 PM
There does appear to be something wrong in your assembly.
Should only require 3 of 1/4" ID washers and 1 of 3/16" ID washer.
Plate on gear shift lever should be drilled out so that the 1/4" dia shoulder bolt can slide right through the plate.
If this has been done then check that the length of the shoulder bolt shoulder is 5/8".
Assembly is 1/4" washer under shoulder bolt head, then through the cable rod end, another 1/4" washer, then through the gear lever plate, another 1/4" washer and a 3/16" washer, then nyloc nut.
Installation instructions are in a PDF on this page:
https://www.simplysportscars.com/sho...ossgate-cables
Vale Mr Chip 1998-2015
iana is offline
post #7 of 10 (permalink) Old 08-15-2019, 10:00 PM
forkmeupscotty's Avatar
a little hard to tell from the angle of the photos, but I'm pretty sure the rose joint of the gear cable gets attached to the gear level with a bolt and a NYLOC NUT.
The nut has a nylon insert so it doesn't come loose. In your case, the nut looks like it's barely threaded. I think you should remove the excess 'spacers' as you call them and only use the supplied amount of 'washers'.
Then thread the bolt ALL THE WAY THROUGH the nyloc. There will be increased resistance when you have to overcome the nylon insert initially.
2001 2JZ-GE
2008 N54B30
2008 2ZZ-GZE
2015 N63B44O1
http://www.youtube.com/forkmeupscotty
forkmeupscotty is offline
post #8 of 10 (permalink) Old 08-22-2019, 12:52 AM Thread Starter
Ptl92600's Avatar
Haha, dismentles half a car but isn’t able to find pdf instructions on a website, so typical! Thanks for your help! shifter is working a treat with extra washers for now so I’m not going to fiddle with it for the time being. Plus I’ve added gregs race parts gated grill which is phenomenal!
Ptl92600 is offline
post #9 of 10 (permalink) Old 08-22-2019, 12:56 AM Thread Starter
Ptl92600's Avatar
I checked, it’s a Nyloc nut and it’s nice and snug. ’ll check everything is still in order and nicelly torked down in a couple hundred miles before I decide what to do.
Ptl92600 is offline
post #10 of 10 (permalink) Old 08-22-2019, 04:05 AM
instead of adding weight with the gated bling bling shifter i would throw the complete cheap looking plastic part out of the car.
ManuelG1986 is offline
