One signal blinks faster than the other - LotusTalk - The Lotus Cars Community
 5Likes
  • 1 Post By AZelise
  • 1 Post By mrfunstuff
  • 1 Post By GR82DRV
  • 1 Post By BondoRobert
post #1 of 12 (permalink) Old 02-19-2017, 11:38 PM Thread Starter
death2lois's Avatar
Question One signal blinks faster than the other
My 06 Exige has two different speeds of turn signals. The right signal is about 1/3 the speed as the left. Does anyone know why this is? How to fix it? I know in other cars this happens when one bulb is out. Usually on the faster blinking side, but I checked the side that blinks more quickly and both the front and rear blinkers are good.
death2lois is offline
post #2 of 12 (permalink) Old 02-20-2017, 03:37 AM
congrats on the purchase
I am thinking a weak ground may to blame
watch them in the dark and see if you can see any difference in brightness
exigegus is offline
post #3 of 12 (permalink) Old 02-20-2017, 05:21 AM
2006 Exige
AZelise's Avatar
There are other things it could be, but I'm 90% sure this relay is all you need to replace: #CF13GL-02. It is under the dash near the middle.
They are available at superbrightleds, amazon, ebay, etc.
death2lois likes this.
AZelise is online now
post #4 of 12 (permalink) Old 02-20-2017, 04:11 PM
mrfunstuff's Avatar
Yes replacing the relay works!!! I tried everything up until somebody posted this in another thread. Got mine from superbrightleds.com
mrfunstuff is offline
post #5 of 12 (permalink) Old 02-20-2017, 06:19 PM
Closer than you think
GR82DRV's Avatar
Blinker Fluid - $18.95 : KaleCoAuto.com, Your home for the rare, unusual, and hard to find auto parts.
You're welcome!
2005 BRP Elise Sport, Hardtop, Stage 2 Exhaust, CF side scoops, CF splitter, Composite Worx seats, gunmetal stripes
GR82DRV is offline
post #6 of 12 (permalink) Old 02-20-2017, 07:13 PM
jumpman1975's Avatar
When replacing the relay, do you simply just pull it out or is there a tab that needs to be pressed? I need to replace mine too.
jumpman1975 is offline
post #7 of 12 (permalink) Old 02-21-2017, 02:42 AM
Had the same issue w/passenger side. Turned out it was the bulb for the front directional had slipped partially out of the socket. Odd, maybe I was lucky....
Kamsden likes this.
BondoRobert is offline
post #8 of 12 (permalink) Old 02-24-2017, 04:37 PM
mrfunstuff's Avatar
Yup pull out the old one and put the new one in. No tab that I recall. Just need to contort your body to get under the dash
post #9 of 12 (permalink) Old 02-26-2017, 12:32 AM Thread Starter
death2lois's Avatar
Bookmarked it...
I found the relay on superbrightleds and bookmarked it. I'm going to check the brightness of the flashers to see if it's the other issue before I buy the relay. Thanks for the info! This will likely be the fix. Much appreciated!
post #10 of 12 (permalink) Old 02-26-2017, 06:00 AM
Thanks for the info. I have a simliar issue but only at times. Usually a bump will cause the issue with my left turn blinker going fast, then another bump will return it back to normal.
I haven't checked the relay or bulb for looseness yet as it 'fixes' itself...and when it doesn't, I feel like a 'racer' with fast flashing blinker :-)
jhentr is offline
post #11 of 12 (permalink) Old 03-11-2017, 01:21 PM
ERDoc74's Avatar
I have this same issue on my 06 Elise... started a few months ago. ordered the part number listed above from superbrightleds and will see if it resolves the issue.
Thanks for the part number AZElise!
2006 Graphite Grey Lotus Elise: BOE Fully built Long Rod Race motor with Solid Ferrea rockers, REV400 SC, Custom mounted BOE Front HEX.. Penske SA's , BOE CF Rear clam, Exige front clam + LOTS of other mods
ERDoc74 is offline
post #12 of 12 (permalink) Old 04-03-2019, 12:58 PM
Relay swap worked like a charm on my ‘06 Exige. My left turn signal was solid and my right was fast flashing. I checked my hazard button connections and fuses. Nothing. I then checked the connections at the relay base. Nothing. After I swapped the relay, everything works great.
I ordered CF14JL-02 off of Amazon for $10. Just pay attention to the polarity of the spades when you order a three prong led flasher and you’ll be fine. (The CF13JL-02 is wrong, the polarity is reversed).
It takes a bit of wiggling to get under the dash to pull the relay. But it is roughly behind the radio in the passenger footwell. You can wiggle it out without tools.
rexwinter is offline
