Rear Tie-Rod End Torque - LotusTalk - The Lotus Cars Community
post #1 of 17 (permalink) Old 03-28-2019, 06:22 PM Thread Starter
gillam's Avatar
I was preparing for my first oil change on my '07 Exige S (8k miles). I watched a YouTube video that cautioned to check the tie-rod end(inner) that attaches to the engine sub-frame. The guy cautioned its been known that this bolt has come loose and caused accidents. He recommended checking that it is torqued to 45 ft. lbs every time the oil is changed.
I checked mine and one side was less than 45 ft lbs. Glad I checked.
Is this really something people have experienced? Is 45 ft. lbs correct?
Thanks,
Larry
gillam is offline
post #2 of 17 (permalink) Old 03-28-2019, 06:27 PM
linwozzle's Avatar
A lot of people replace them. There are some stronger options out there from inokinetic and Boe.
Sent from my SM-N960U using Tapatalk
linwozzle is offline
post #3 of 17 (permalink) Old 03-28-2019, 07:47 PM
glb
glb's Avatar
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
https://www.inokinetic.com/lotus/re-...y=Transmission
For street cars, consider removing one or both oil coolers. Some cover them.
(Mark the fasteners so to check if there is movement.)
https://www.lotustalk.com/forums/f31...-u-tube-47232/
https://www.lotustalk.com/forums/f32...ramming-70940/
14. Visit the Uber Thread
https://www.lotustalk.com/forums/f3/...ow-here-25131/
Plus, “How to bleed brakes”:
https://www.lotustalk.com/forums/f10...brakes-241138/
How to Search:
glb is offline
post #4 of 17 (permalink) Old 03-28-2019, 09:06 PM Thread Starter
gillam's Avatar
Thanks GLB.......
Great suggestions. Since this car doesn't see the track and lives a pampered life, I'll go with the Nord-Lock washers. $350 for the links plus re-alignment doesn't make sense for me. The stock setup on my car has NO washers which puts more stress on a small area. The washers will prevent loosening AND disperse the stress. I'm surprised Lotus would go with this design.
The other suggestion that jumped out is the fender rivet/plastic screw fastener. When I removed it to install a decat pipe, I thought that was sketchy. I'll pick up some well nuts.
gillam is offline
post #5 of 17 (permalink) Old 03-29-2019, 07:22 AM
He's on fire!
jds62f's Avatar
I've got some good experience with this - the nordlocks work. I was a little bit concerned when first installed because it leaves very few threads coming out of the nut. I am religious about checking them though, and can verify that I haven't had toe links back off at all with the nordlocks in place.
And smart call staying OEM. I've found there's not much reason to go aftermarket - IF you have the OEM double sheer setup. The thing I *would* do if I were you - my 07 inner joints were bare, not booted. I did proactively replace them with new OEM, and those came with boots. The good news is, I'm pretty sure you can just buy boots if you don't already have them and put them on.
bootie:
jds62f is offline
post #6 of 17 (permalink) Old 03-31-2019, 05:38 PM Thread Starter
gillam's Avatar
Update - I looked for the Nord Lock washers locally and was only able to find some at my local Fastenal store.
They had 40 pairs for $63. Say what! I moved on and purchased 10 pairs of 10MM for $13 on Amazon.
I didn't want to wait 3 days to get the car back on the road so applied Lock-Tite in the meantime. That could be a long term solution, but the Nord-Locks look interesting. I'll install them on the next oil change.
Still don't know if 45 ft-lbs torque is correct, but seems reasonable. If any body knows for sure, let know.
BTW, in my original post, I pointed out my car didn't have a washer on the nut end of the tie-rod. When I applied the Lock-Tite, I noticed there is a washer welded to the subframe. You can't see it because it was coated after welding so it disappeared unless using a flash light.
gillam is offline
post #7 of 17 (permalink) Old 04-03-2019, 04:32 PM
thebuzzard's Avatar
You're probably fine with locktite. I'm not a fan of repeatedly torquing anything. It is such an error prone way to load a bolt to start with. I prefer to paint-mark everything and watch to make sure nothing moves.
Sent from my Pixel 3 XL using Tapatalk
2007 Exige S
Stripped down and turned into a track animal
thebuzzard is offline
post #8 of 17 (permalink) Old 04-03-2019, 04:40 PM
thebuzzard's Avatar
Oh, yes 45 ft-lbs is what I use, without locktite. You will have really loaded that bolt if you wetted the threads with locktite!
2007 Exige S
post #9 of 17 (permalink) Old 04-04-2019, 09:10 AM Thread Starter
gillam's Avatar
Thanks.......
Not familiar with the term 'loading the bolt'. Does that mean over tightening because you're temporarily lubricating the threads?
The paint idea is good, I'll do that
gillam is offline
post #10 of 17 (permalink) Old 04-04-2019, 09:20 AM
cyow5's Avatar
Give it a good visual, too. My bolt was torqued down fine BUT the nut on the engine side was nearly about to fall off. The threads from the bolt were against the subframe and held tight. Having the aftermarket brace makes no difference if the bolts ain't right.
cyow5 is offline
post #11 of 17 (permalink) Old 04-04-2019, 10:01 AM
thebuzzard's Avatar
My understanding is that we are using torque as a proxy measure for setting a clamp load (down the axis of the bolt) but there are a lot of variables in that translation. You want to avoid stretching the bolt beyond it's elastic limit.
I usually look up charts online and if I can't find anything specific to my exact situation, I just reduce the torque by about 30% if lubricated.
Here is an example of an info page (I don't know this site to be for-sure reliable, so buyer beware). I usually check several sites to get a majority vote .
Metric Bolt Torque Table - CNCexpo.com
2007 Exige S
post #12 of 17 (permalink) Old 04-04-2019, 11:35 AM
He's on fire!
jds62f's Avatar
Originally Posted by thebuzzard View Post
... I'm not a fan of repeatedly torquing anything. It is such an error prone way to load a bolt to start with.
Please explain this comment. To my knowledge nearly everything manufactured is put together with tightness determined by torque values. Excepting cases where the bolt stretches under torque, I should be able to reliably/repeatably get the same load on a bolt by tightening it to the same torque value.
jds62f is offline
post #13 of 17 (permalink) Old 04-04-2019, 01:00 PM
paulhastings's Avatar
I believe there was a modification to the torque spec suggesting a slightly higher torque. I have it written down, just not with me. I think it's either 50 or 60.
paulhastings is offline
post #14 of 17 (permalink) Old 04-04-2019, 01:09 PM
thebuzzard's Avatar
I'd describe it as a personal preference to not repeatedly torque bolts as a way of ensuring security. Looking at a paint mark is faster.
We stretch bolts when we torque them (a good thing and intended) but the translation between torque and tension involves friction. Once a nut or bolt is in place, the friction changes (typically starting friction is higher than moving friction. If the nut does not move when test torquing, I'd say that's the same as a paint mark check? If it does move, I'm not sure what happened? Did it back out? Did the temperature or friction change? Did the torque wrench change?
Anyway, these are all just my preferences and opinions and I'd not regard them as gold-standard
2007 Exige S
post #15 of 17 (permalink) Old 04-04-2019, 01:12 PM
He's on fire!
jds62f's Avatar
You have your units confused. 45 ft lb is correct.
jds62f is offline
post #16 of 17 (permalink) Old 04-04-2019, 01:23 PM
thebuzzard's Avatar
@paulhastings I think you might be remembering the change in bolt grade for the plinth bolts (pinching the camber shims)? The 8.8 grade bolts were 33ftlbs and the 10.9 grade bolts are 50ftlbs.
2007 Exige S
post #17 of 17 (permalink) Old 04-05-2019, 08:05 AM
thebuzzard's Avatar
Risking beating this one to death, I went to the garage and looked in my trusty EMP press guide.
My bolt is 10.9 M10x1.5.
For a clamp load of 8,115lbs:
Plain: 53 ft-lb
Zinc Plating: 59 ft-lb
Phosphate and Oil: 40 ft-lb
Lubricated: 27 ft-lb
I use phosphate and oil in the front and zinc plated in the rear (the long nut and bolt).
I'm conservative on the front (don't feel like drilling out the captive nut ever).
2007 Exige S
Similar Threads
Need source for ball joint and tie rod end boots ChrisH Suspension (including wheels, tires, brakes) 9 03-27-2013 06:09 AM
Tie rod bolt torque?? killcraft Lotus Exige 2 02-15-2013 06:33 AM
Tie rod end autopsy report...and answer to why they fail MikeW Suspension (including wheels, tires, brakes) 45 12-03-2009 05:48 AM
Leaking tie rod end - how serious is this? mgreenbl Maintenance and Repairs. 9 02-21-2009 07:29 PM
Tie rod end bushings xeeeejme Suspension (including wheels, tires, brakes) 8 05-26-2008 05:17 PM
