Remove Console - LotusTalk - The Lotus Cars Community
post #1 of 3 (permalink) Old 04-24-2019, 12:12 PM Thread Starter
WinterMiles's Avatar
Remove Console
I have a 2013
Exige S Cup that I would like to work on the shifter.
Does anyone know how to remove the console without tearing it up?
Thanks in advance for any advise.
WinterMiles is offline
post #2 of 3 (permalink) Old 04-26-2019, 12:53 PM
henrymfisher's Avatar
well not sure how the cup car's console varies from the Exige S
but undue the two screws on the side, remove shift ball (tiny allen set screw needs to be removed). Remove the e-brake handle (also has tiny allen set screw)
then wiggle the console up allowing the e-brake handle to slide through the opening. Sometimes you need to pull the e-brake handle
up to create the right angle for it to slide through. When the console is free gently raise it enough so the shift boot collapses down into the console
exposing the zip tie securing the boot to the shift upright. Clip the zip tie and the console should come free.
On the reverse I suggest having a friend or spouse hold the console above the shifter with the shift boot inverted so you cam add the zip tie again.
Once the console is lowered down through the e-brake one person can handle it from that point forward.
Good luck.
Henry
'07 Exige S
Henry
'05 Elise
henrymfisher is offline
post #3 of 3 (permalink) Old 04-27-2019, 04:05 AM Thread Starter
Thanks Henry!!!
That worked.
Similar Threads
To remove or not to remove? Jmoses77 Lotus Elise 8 11-08-2014 03:15 PM
How to pull the hand brake lever high enough to remove the centre console? Turtle Maintenance and Repairs. 10 02-23-2012 09:51 AM
How to remove cigarette lighter on upper console/cup holder madden Maintenance and Repairs. 4 07-11-2009 04:44 PM
What bolt/bit do I need to remove the center console? qu1Z Interior/Exterior 20 04-07-2009 04:06 PM
how to remove the center console Stan Interior/Exterior 0 09-30-2004 10:20 AM
