SC stopped building boost & occasional Surging Idle - LotusTalk - The Lotus Cars Community
 1Likes
  • 1 Post By Kadam
post #1 of 7 (permalink) Old 07-16-2017, 03:29 AM Thread Starter
05 elise
vision function SC kit
(was driving home on a 2 hour trip. it pulled just fine initially)
all of a sudden the car will not build boost.
it also sporadically surged rpms at idle.
Eventually right before i got home it threw a p0507 idle air control system RPM higher than expected
any thoughts would be appreciated
Kadam is offline
post #2 of 7 (permalink) Old 07-17-2017, 08:17 AM
evansp60's Avatar
Check for leaks, sounds like a hose popped somewhere
Stay Tuned.....
evansp60 is offline
post #3 of 7 (permalink) Old 07-17-2017, 04:21 PM Thread Starter
update: found the problem. its fixed
http://imgur.com/a/EGQs0
forkmeupscotty likes this.
Kadam is offline
post #4 of 7 (permalink) Old 07-17-2017, 07:30 PM
evansp60's Avatar
That would be a leak.....
Stay Tuned.....
evansp60 is offline
post #5 of 7 (permalink) Old 04-06-2019, 03:47 AM
Need-4-Speed's Avatar
Hello, I’m new to the Elise car scene and noticed your post, Kadam. I too have a VF on my 05. Recently I received the P0507 check engine light and noticed higher RPMs along with a loss of pulling when hitting the throttle. I was hoping you could provide some guidance on how to remove the housing you have pictured the link below?
https://m.imgur.com/a/EGQs0
Thanks for your time,
Ryan
Need-4-Speed is offline
post #6 of 7 (permalink) Old 04-14-2019, 04:19 PM
That housing attaches the throttle body to the inlet of the supercharger.
You will likely need to pull both the charge pipes on top to get access to the throttle body.
Sent from my SM-G950U using Tapatalk
ScottH83 is offline
post #7 of 7 (permalink) Old 04-15-2019, 04:20 PM
Thanks, Scott!
  LotusTalk - The Lotus Cars Community > Lotus Discussions > Powertrain (Engine, Transmission, etc) > Forced Induction
