Custom box truck ramp design wanted for elise - LotusTalk - The Lotus Cars Community
 6Likes
post #1 of 30 (permalink) Old 12-19-2017, 05:09 PM Thread Starter
I have a dock high box truck and I'm looking for a qualified person to design a ramp / winch system. The truck has a 20ft box, 8ft wide door, and 48" from the ground. It also has a 3000lb fold out lift gate system.
If you can do this, or know someone who might please send over some info.
redcar9 is offline
post #2 of 30 (permalink) Old 12-19-2017, 05:41 PM
centerpunch's Avatar
centerpunch is offline
post #3 of 30 (permalink) Old 12-19-2017, 06:05 PM Thread Starter
That sure looks like it would work! I will looking the details on approach /depart angles.
redcar9 is offline
post #4 of 30 (permalink) Old 12-21-2017, 10:47 AM
310tmac's Avatar
Securing the car in the truck bed may be a challenge. Unless you have E-track or D-rings mounted into the floor of the box.
310tmac is offline
post #5 of 30 (permalink) Old 12-21-2017, 12:40 PM
Just raise that center support to cut the ground clearance requirement in half. I have a CAD file of the Elise if you need some geometry checked.
Washburn is offline
post #6 of 30 (permalink) Old 12-21-2017, 04:37 PM Thread Starter
I have e-track on the side. Do you know of a specific d-ring that works well for floor mounting? Ideally I would like to keep the truck floor flat.
redcar9 is offline
post #7 of 30 (permalink) Old 12-21-2017, 04:42 PM Thread Starter
Yes, if you could send over the CAD file that would really help. Do you know how much higher the center should be increased?
Here is a drawing of the ramp.
http://www.discountramps.com/images/...-06-M-High.pdf
redcar9 is offline
post #8 of 30 (permalink) Old 12-21-2017, 05:17 PM
2006 Exige
AZelise's Avatar
Something like this?
redcar9 likes this.
AZelise is offline
post #9 of 30 (permalink) Old 12-21-2017, 05:26 PM Thread Starter
LOL! That is some gold right there. I can only hope these ramps are half that good.
AZelise likes this.
redcar9 is offline
post #10 of 30 (permalink) Old 12-22-2017, 07:33 AM
TedR's Avatar
You are going to have clearance problems with any ramps to get into the back of a 48" high truck bed. Getting onto the ramps will scrape the front and getting into the truck will scrape the bottom.
You need some extensions fabricated for the lift gate to lift the car horizontally up to the truck bed.
TedR is offline
post #11 of 30 (permalink) Old 12-22-2017, 08:12 AM
TedR's Avatar
Two of these ramps bolted to a laft gate might work.
Guardian Aluminum Grit Coat Walk Ramps | Discount Ramps
TedR is offline
post #12 of 30 (permalink) Old 12-22-2017, 09:08 AM
310tmac's Avatar
There are plenty of recessed D-Ring options, you may want to check etrailer. I have had good luck with these: https://www.etrailer.com/Tie-Down-An...ophy/RR06.html
Adding support mounts under the truck floor going across the floor cross beams will do the should make them very secure.
redcar9 likes this.
310tmac is offline
post #13 of 30 (permalink) Old 12-22-2017, 09:29 AM
LiveToDrive's Avatar
You can use the lift gate to support your ramps. I did something similar to load my micro van into the bed of my tommy-gate equipped dually.
redcar9 likes this.
LiveToDrive is offline
post #14 of 30 (permalink) Old 12-22-2017, 09:31 AM
I mounted a winch in the bed and used it to pull the van onto the bed. I had D rings welded to the bed floor to secure it.
post #15 of 30 (permalink) Old 12-22-2017, 12:17 PM
2011 chrome orange's Avatar
Is that a Honda Motocompo in the back of your Subaru?
2011 chrome orange is online now
post #16 of 30 (permalink) Old 12-25-2017, 10:06 AM
I can a quick mock up and send it to you after the Holiday. The drawing is very helpful. For reference, this is something I built when I was hailing my Neon race car around in a school bus...
Washburn is offline
post #17 of 30 (permalink) Old 12-25-2017, 05:13 PM Thread Starter
I think you might be right on having clearance issues. The box truck sits a little lower in the front. So getting over that top edge could be a problem.
Do you know who made this lift gate? Mine is more of a standard aluminum one for a pallet jack. It can left 3000lbs
redcar9 is offline
post #18 of 30 (permalink) Old 12-25-2017, 05:20 PM Thread Starter
That's an awesome setup! I love the school bus!
There is a different version of the ramp system that has two uprights, I don't see them in the drawing or pictures. It seems I need a longer length to get the angle lower. Which looks exactly like what you have.
Thanks so much for the help!
Two upright version.
http://www.discountramps.com/images/...-High-Rev1.pdf
redcar9 is offline
post #19 of 30 (permalink) Old 12-27-2017, 10:30 AM
A quick study...
redcar9 likes this.
Washburn is offline
post #20 of 30 (permalink) Old 12-28-2017, 01:48 PM
All this said and done, if I had a lift gate that could lift 3,000 pounds this would be a no brainer. Get some ramp extensions like the one pictured above, and just lift it. That's way cooler than any ramps!
Washburn is offline
  LotusTalk - The Lotus Cars Community > Community > Transporters, Trailers, Towing & Tie-downs
