1991 Nissan R32 Skyline GTS-T - LotusTalk - The Lotus Cars Community
 4Likes
post #1 of 21 (permalink) Old 08-13-2018, 11:10 AM Thread Starter
Palombo
Talking 1991 Nissan R32 Skyline GTS-T
Pictures can be found on my Instagram here= https://www.instagram.com/finallyrhd/
Since I canít load attachments.(not on my computer)
Iím looking to get into a Elise so if anyone is interested in the car Iíd be willing to trade.
Cars worth around 25K as is
Feel free to contact me
Text-386-466-9890
Email- [email protected]
1991 Nissan Skyline GTS-T
Engine- 97 R33 RB25DET (S2)
Trans- 91 300zx tt 5spd with RB25 bellhousing
Mileage on the cluster-166,821km
Mileage on current motor build-4000km~
310hp, 275tq @11psi, very light tune
El Paso, TX
Up for sale is my R32, I have had the car for 2 ,almost 3, Yearís now. I love it. Iím in no rush to sell. I have no mechanical issues with it currently. It is a old car so you never know what might start squeaking the next day. This car is daily driven and has never left me stranded. R&R of the motor and trans was done by myself and some trusted buddies. All machine work was done by me or my boss at my work. I have about 400+ pics of the build process so those are available upon request. Car does NOT have AC/heat currently. Heater core cracked on outside of firewall and have just been to lazy to replace since itís summer so I just bypassed it lol. I removed AC system in the bay because race car lol. Also doesnít bother me. Car does have some flaws. Driver seat is torn from getting in and out(purchased like that), rear glass seal is starting to curl in on the top edges from heat (applied some black rtv as quick fix), doors have no speaker grills(not big deal just bugs me), no vent in driver side dash, power steering pump leaks from the makeshift plug I used for hicas delete(removed fins from rear of pump) and hopefully I will be looking at that soon. If the car does not sell I will just keep building it. But any mods are on hold while I finish another project.
I will update list if I remember anything else
Engine mods
-CP Forged Pistons (+.5mm/.020)
-H Beam RB26Manley Rods
-King main/rod bearings (std/std)
-ARP head/main studs
-Tomei Head Gasket (1.2mm)
-Oem Gasket set
-Arashi 20G Billet Turbo
-Greddy Type FV bov
-Silione vacuum lines
-deleted PCV grommet for fitting
-Hydro-dipped valve covers/intake/timing covers
-Spline Drive oil pump upgrade
-N1 Water and Oil Pumps
-Tomei oil orifice restrictor in block (x1)
-Nismo Thermostat
-Fresh Pilot bushing
-Nismo motor Mounts
-Rebuilt stock Cylinder head (done by me personally)
-Oil clearances are (.0015-.002) rods/mains
-New fan clutch (600miles)
-New Belts (500miles)
-Spec 3+ Clutch
-Resurfaced Flywheel
-Oil filter sandwich plate
-Raw Brokerage oil filter stud direct to Block
-Raw brokerage exhaust manifold stud kit
-Pancake downpipe with custom side exit exhaust (3in straight pipe)
-Fully wrapped exhaust and turbo blanket
Machine work performed (Dec 2017)
-Balanced rotating assembly (have balance report)
-Bored/Honed/ Plateau finished (diamond stones used)
-Decked Block (.004)
-Resurfaced Cylinder Head (.003)
-Cylinder head óóNew stem seals(oem), 3 angle valve job, light port and polish, clean and drained lifters, polished cams and cam journals)
-Head and Block Soda blasted and acid Washed
-Installed ARP Main Studsó-Verified Line bore within spec
-Install ARP Headstuds
-Cut Crank for Spline Drive installation
-Clean and Mirco-polish crankshaft
-Long Block assembled by me
-Still have arp bolt boxes for any warranty claims*
Suspension
-D-max D1 drift spring coilovers
-Hicas Delete Driftworks
Transmission
-91 300zx TT 5 Spd
-Rb25det bellhousing
-rb25det oem slave cylinder
-Spec 3+ clutch
-New OEM Rb25det pivotball
-Xcessive Manufacturing shifter relocation kit
-300zx external shifter
-One piece driveshaft- made locally
Misc
-Dress-up bolt engine bay kit -Titanium
-AEM boost,wide band, oil pressure gauges
-GTR steering wheel
-turbo timer( came with car,works great) unsure brand
-New door window trim/seals(will be installing this weekend)
-17x9 STR wheels all around
-uncut GTR key
-Car is wrapped,original color is black(have extra wrap left still)
Christopher Palombo is offline
post #2 of 21 (permalink) Old 08-13-2018, 02:40 PM Thread Starter
Palombo
Figured out how to do pics lol
post #3 of 21 (permalink) Old 08-20-2018, 10:26 AM Thread Starter
Palombo
Update**
Fixed power steering leak this past weekend!
Car is now completely leaked free.
Thank you for looking.
post #4 of 21 (permalink) Old 08-24-2018, 06:20 AM Thread Starter
Palombo
So leak is fixed and no signs of any other issues
Again I drive this car daily so any thing that comes up is addressed quickly 👍🏽 Also here some pictures of the seats( came from Japan) and interior
post #5 of 21 (permalink) Old 08-24-2018, 06:53 AM Thread Starter
Palombo
Here’s a few pictures of engine build.
Again, all assembly and machine work were done by me personally or my boss 🙂
post #6 of 21 (permalink) Old 08-27-2018, 11:00 AM
Please PM me your number
anali786 is offline
post #7 of 21 (permalink) Old 08-27-2018, 03:48 PM Thread Starter
Palombo
My number is 386-466-9890
Preferably text because itís difficult to talk on the phone due to work and night class.
post #8 of 21 (permalink) Old 08-30-2018, 12:58 PM Thread Starter
Palombo
Took the injectors off to have them cleaned and flow tested no issues just something I have been needing to do and havenít had time lol
post #9 of 21 (permalink) Old 09-04-2018, 05:44 AM Thread Starter
Palombo
Bump,cars loving the fresh injectors !!
post #10 of 21 (permalink) Old 09-16-2018, 05:00 PM Thread Starter
Palombo
Bump
I just upgraded the old RB series coil packs to AUDI R8 red top coils! Much better ignition and burn with these packs
post #11 of 21 (permalink) Old 09-19-2018, 10:20 AM Thread Starter
Palombo
New addition, Iím sure this will not be everyoneís taste
Edit- CF GT wing, idk brand but wing is good quality
post #12 of 21 (permalink) Old 09-19-2018, 12:03 PM
Poor guy...
dude joins LT, a forum of people who generally like raw lightweight cars, to sell his GTS-T for GTR prices.
good luck on selling your, essentially, rb25 swapped 240sx.
- 1300lbs, 170hp. British.
- 2100lbs, 200hp. Japanese.
- 2350lbs, 600hp. British.
- 2900lbs, 140hp. Japanese.
- 3500lbs, 280hp. Italian.
HondaCRX is offline
post #13 of 21 (permalink) Old 09-19-2018, 03:23 PM Thread Starter
Palombo
Originally Posted by HondaCRX View Post
Poor guy...
I enjoy folks like you, that would buy you a bone stock GTR in decent shape (30-60k km) Lol
Not the same as a forged internal engine that has already had all the little things done your GTR would still need ,AFTER, u paid that 25k lol
Too each their own, but you obviously donít know RB engines if you canít understand the price
post #14 of 21 (permalink) Old 09-20-2018, 06:31 AM
Originally Posted by Christopher Palombo View Post
Too each their own, but you obviously don’t know RB engines if you can’t understand the price
Had it been a GTR, I'm sure there'd be more interest, but instead.. you got the eco-boost Mustang and tried to make it a GT350R. Then added an ebay knock-off wing on it, to help further seal the deal of "trying to be something it isn't"
Plus side, your thread is getting SOME action other than you posting updates of you fixing your broken skyline.
HondaCRX is offline
post #15 of 21 (permalink) Old 09-20-2018, 07:36 AM
Narberry's Avatar
Welcome to Lotus Talk!
Sorry for your rough entry into the lotus world. I promise we are generally friendly and enthusiastic about people being interested in Lotus things.
I know nothing about RB motors and Skylines (except for watching the Mighty Car Mods series). Best of the luck with the sale/trade.
Enjoy poking around and definitely go find a Lotus at your local C&C to check out and take a ride in if you haven't already. I think the Elise/Exige is a simple car to understand for a potential buyer. it is what it is. 2 minutes and you'll shout "YES!" or begin to doubt the desire.
2005 Elise - Starlight Black // BOE Clam Hinge // Top Speed Exhaust
"I have found a desire within myself that no experience in this world can satisfy; the most probable explanation is that I was made for another world." -C.S. Lewis
Narberry is offline
post #16 of 21 (permalink) Old 09-20-2018, 08:03 AM
not your dad's puns
Turbopun's Avatar
What is this registered as? In other words, is it an actual R32, or a 240 with an RB swap?
Also, no AC in a Texas car seems like a hard sell.
Honest question, as I don't follow Nissans much anymore. Back in the day I dreamt of a red top SR20 turbo swap into my many P10s...
because racecar
Turbopun is offline
post #17 of 21 (permalink) Old 09-20-2018, 08:46 AM
The Enforcer
oldmansan's Avatar
Poor guy...
Read the rules. No comments on price unless the OP requests it.
San
oldmansan is online now
post #18 of 21 (permalink) Old 09-20-2018, 08:47 AM
The Enforcer
oldmansan's Avatar
Move along or take it to PMs.
San
post #19 of 21 (permalink) Old 09-21-2018, 05:46 AM Thread Starter
Palombo
First off, never once claimed it to be a GTR.
Second, you must have some personal issue here so feel free to take that ricer ego and PM me
I actually got the chance to go for a test ride/drive and itís great! The Skyline is actually much faster but I can easily build a K20 swap for half of my RB build
I did also enjoy how nimble the car felt. Main reason I want to switch is itís different. Skylines are becoming popular in my area so Iím exploring something a little less known. The platform is great for the 32 and solid if built right!but Iím just losing interest for this and falling in love with a Elise more and more
This is 100% JDM skyline R32, I have the Japan Auction papers still.
Registered,insured,and titled as a R32 Skyline
USAA even calls it ďGodzillaĒ in the system lol
Yes while this car is very similar to the 240, itís not a 240 lol. It would be the equivalent of me saying ďthe Lotus is just a MR2Ē lol while parts swap over each is completely different in their own way
San
Thank you for addressing that, from what ive seen and the owners I talked to, I gathered this was a mature car enthusiast community. But there is always that one guy
post #20 of 21 (permalink) Old 09-25-2018, 04:15 PM Thread Starter
Palombo
Just a pic from the show this weekend👍🏽 Got the canards and wing flowing finally
  LotusTalk - The Lotus Cars Community > Marketplace > Cars for sale (not Lotus)
