I have been a checking out LT for the last 4 years and have gained a lot of valuable information over that time … so thought it was about time I put a bit of information back .
Purcahsed my 2-11 approx 4 years ago in used condition with 3000km / 1850 miles on the clock . It was in almost perfect condition and since then I have systematically gone about changing just about everything.
It started with an innocent email to Phil enquiring about a little more power and ended up as a full blown project.
The project has taken almost 2 years to get to this stage and as per pictures below it has just completed an easy test day to check all parts and systems / leaks etc .
A full test with the body on is schedled in a couple of weeks , so will post more pictures and data then.
Have also posted a copy of the Dyno results … on a Dyna Pack ..so its 367 WHP running on E50.
The driving experience compared to OEM is best described as “Night and Day” Engine makes power everywhere and I havent really pushed it that hard at present …. A bit difficult with no body Shell !!
Very pleased with the way the initail test went and all pressures and temps are well within bounds .
The IAT temps have improved since the inclusion of the OEM intercooler and running E50 .
Car weight is 718 KG/ 1576lb with Body work / 40L of Fuel and all oils and water / no driver
And just for the record want to give a big shout out to Phil and the team at BOE who has been very helpful and patient throughout the process . It has been a big learning curve for me plus add in that I am based in Christchurch, New Zealand you start to get an idea of the issues involved.
Also to the team at Elise Parts in the UK .. great parts that fit like they are supposed to , great service and delivery … a big thanks to Geary and Ian.
The local guys here at NZEFI have also been fantastic , going the extra mile to get this car tuned
Happy to answer any questions
ENGINE & GEARBOX
BOE Race engine 10.5:1 / Standard Rod length
JCR Ported head
BOE REV 400 SC
BOE Dry Sump with Peterson Pump and tank
Laminova Oil cooler
2ubular Exhaust system
Aeroflow Fittings and Braided Hose
BOE Fastworks Software
Quaife Sequential with Geartronics Flat shift
Exedy Clutch
ELECTRONICS
Motec C127 Dash with I/O upgrade and Race logging kit
Motec E888 CAN expansion Unit
Cartek Battery Isolator
FUEL SYSTEM
Pro Alloy 60L Alloy Tank
BOE Fuel Swirl Pot
Upgraded Fuel pumps for Ethanol & HP – InTank Lift Pump / Swirl Pot Pressure Pump
Aeroflow Braided PTFE Ehanol Hoses
Aeroflow Fuel Filters Pre and Post Swirl Pot
COOLING / ENGINE
Pro Alloy 3 pass Radiator
BOE pressurized Header Tank
EP Silicone Hoses
COOLING / SC
BOE Frount Mount Heat Exchanger HEX
OEM Air to Air Intercooler converted to Water / Air – extra Heat guards over exhaust
2 x Davies Craig EWP80 water pumps
BOE Header Tank with Sensor
Aeroflow Silicone hose
WHEELS / TYRES / BRAKES
Lotus Sport Wheels [2 sets]
Dunlop Slicks – Soft Compound 200/580 16 & 235/610 17
BOE Wheel Studs
EP 15mm Spacers
AP Big Brake Kit / 308mm Rotors / Performance Friction Pads
OEM front Brakes on Rear /Performance Friction Pads.
SUSPENSION / UPRIGHTS / STEERING
Quantum 2 way Adjustable shocks / 850lb Rear – 750 lb Front
Elise Parts [EP] GT uprights
OEM wishbones with Sector 111 Monoballs
Sector 111 steering Arms
EP Quick Rack
Simply Sports Toe Link Kit
EP Anti Roll Bar
OTHER
Lifeline Fire Extinguisher / Plumbed in
Full Roll Cage
Tillet B7 FIA Carbon Seat
6 Point Scroth Enduro Seatbelts
Sector 111 SYS 6 pack
Magic Racing [Japan ] Carbon Mirrors
ENGINE & GEARBOX
JCR Ported head
BOE REV 400 SC
Laminova Oil cooler
Exedy Clutch
ELECTRONICS
FUEL SYSTEM
BOE Fuel Swirl Pot
COOLING / ENGINE
EP Silicone Hoses
COOLING / SC
BOE Wheel Studs
EP 15mm Spacers
EP Quick Rack
EP Anti Roll Bar
OTHER
Full Roll Cage
