Check out my "curves" :)!?!? - LotusTalk - The Lotus Cars Community
 1Likes
  • 1 Post By Jack
post #1 of 9 (permalink) Old 01-16-2017, 04:04 PM Thread Starter
docjay's Avatar
2008 Exige Cup Car...2.9 pulley...750 injectors.....100 octane.....look OK?
docjay is offline
post #2 of 9 (permalink) Old 01-16-2017, 04:16 PM
The Enforcer
oldmansan's Avatar
Was the car tuned for 100 octane? I'd expect more power unless that dyno reads really low. I'm at 281rwhp on 91 octane with a lower AFR. @Phil for his opinion.
San
oldmansan is offline
post #3 of 9 (permalink) Old 01-16-2017, 04:20 PM Thread Starter
docjay's Avatar
San
Yes this Dyno is quite a bit less than my Dyno jet in NC...I will re Dyno in 2 weeks...curve looks ok and safe to me.....I was going for safe as this will be a DE car and not a race car for now
docjay is offline
post #4 of 9 (permalink) Old 01-16-2017, 06:36 PM
Plug Whisperer
turbophil's Avatar
San
Not all dynos are created equal for sure and the conditions of the pull, tire air pressure and compostion, fuel, heat saturation of the inlet system, etc all factor in a bunch when trying to compare his numbers to yours... that said, that curve looks more like that from a standalone like the EFI than the stock ECU, so again, if I'm right, another variable.
Congrats on the new car doc!
Phil
turbophil is offline
post #5 of 9 (permalink) Old 01-17-2017, 03:19 PM Thread Starter
docjay's Avatar
Phil
Yes it is an EFI. The good news, Phil, is that it has the stock 260 Cup ECU as well!.......I suspect you could get more power with your tune.....I was going to go with the 2.7 pulley but decided to play it safe with the 2.9
docjay is offline
post #6 of 9 (permalink) Old 01-17-2017, 04:24 PM
Plug Whisperer
turbophil's Avatar
I think you're smart to stick with the 2.9/3.0....
EFI makes sense. The graph looked to be a dead give away...
Feel free to send me the map and I can see if it's close to where it should be.
Cheers!
Phil
post #7 of 9 (permalink) Old 01-19-2017, 08:30 AM
Jack's Avatar
San
That particular car was running in the Cup class of Lotus Cup and was supposed to be limited to ~245 RWHP under class rules. I'm sure it could be improved upon by Phil with his Fastworks tune even with the stock S/C pulley.
oldmansan likes this.
Jack
2008 2-Eleven
2015 Exige CupR
Jack is offline
post #8 of 9 (permalink) Old 01-20-2017, 10:05 AM Thread Starter
docjay's Avatar
Yes it was legal until I bought it and changed the pulley as well as injectors....my 2-11 I think has 248 RWHP with Phils tune and stock pulley
docjay is offline
post #9 of 9 (permalink) Old 01-20-2017, 10:14 AM
Jack's Avatar
Doc,
Do you have headers on the 2-11? If so, FW's tune should yield higher RWHP numbers -- check your records.
Get BOE's intake (to go along with the injectors) and Phils tune on the stock ECU for the Exige Cup255, if you haven't done so already.
Also, adding a smaller pulley very often only adds a bit more HP for the first few laps --- then the higher IATs due to the extra heat caused by spinning the MP62 faster actually makes the car slower on track.
Jack
2008 2-Eleven
2015 Exige CupR
Jack is offline
  LotusTalk - The Lotus Cars Community > Lotus Discussions > Lotus "Track" and Racing Cars
