Elise/Exige Racing Wide-body - Page 4 - LotusTalk - The Lotus Cars Community
post #61 of 150 (permalink) Old 05-29-2010, 04:26 PM
ggelise's Avatar
Awesome project.
Did you consider a center seat?
Do you think the Sun Speed mounts place the drive shafts in too acute of an angle? The mounts are for an s1 chassis was it difficult to modify them for the s2?
What are the plans for the k20 to hit the HP target?
Great work, thanks for sharing!
ggelise is offline
post #62 of 150 (permalink) Old 05-29-2010, 08:43 PM Thread Starter
re: Mounts, etc.
This car had a Honda engine in it before. It was a grey-import non-Toyota-engined car, originally.
Drive-shaft Shop said that their new axles can handle more angularity. They certainly appear very strong. I used Corvette outer shafts, since I went with Corvette bearings, anyway.
I am using a turbo good for 500hp +. I will run 20psi boost. The trany internals have been slightly modified.
I am waiting for a dry-sump pump. Also work is keeping me out of town...
Anton
Originally Posted by ggelise View Post
Awesome project.
ageshelin is offline
post #63 of 150 (permalink) Old 08-22-2010, 06:10 PM Thread Starter
re: Dry sump mount
Finally made pump photos coming. Flat part is the pump side. Alternator bolts to same bracket. Water pump is electric.
Anton
post #64 of 150 (permalink) Old 08-25-2010, 08:28 AM Thread Starter
Engine dressed and ready to drop in
Note the dry sump anb alternator mount.
Anton
post #65 of 150 (permalink) Old 08-28-2010, 11:02 PM
ChronosWS's Avatar
Any more pics of the car out of the garage, front, rear and side? I'm curious to see how the car as a whole ends up looking. With that wide rear clam and big side scoops, it looks so much more aggressive and exotic - if only this were streetable!
2009 Gray and Carbon Audi R8 4.2 MT Stasis Challenge Extreme
2007 Arctic Silver Lotus Exige S - Totaled https://www.lotustalk.com/forums/f231...1/#post5317729
2005 Suzuki Hayabusa
2006 Honda Element
ChronosWS is offline
post #66 of 150 (permalink) Old 08-29-2010, 04:21 PM Thread Starter
re: Widebody pics
The engine is in for the final install.
I will have more pics when we put it all together, probably, by the 12th.
The body kit is streetable, the car is not
Anton
post #67 of 150 (permalink) Old 09-28-2010, 01:11 PM
Shawn C's Avatar
Wheres the pics
http://www.youtube.com/jerusdc
BOE TVS
Shawn C is offline
post #68 of 150 (permalink) Old 02-07-2011, 02:12 AM
Pilbeam says that there is a balance bar, but it does not have a remote adjuster. Seems like a good piece of kit. I am just used to Tilton...
pilbeam now offer their own 90` drive and dash adjuster with which you can adjust the balance of the brakes and they offer a liteweight fabricated throttle pedal for cable operated systems......
www.pilbeamracing.co.uk
justin cole is offline
post #69 of 150 (permalink) Old 02-08-2011, 01:31 PM Thread Starter
re: Tilton
I have been used to Tilron.
So, I used a 3-pedal kit 600-series kit, floor mounted, with short masters and remote adjuster.
Seems to work fine. Lots of choices for throttle connection and master cylinder sizes.
Anton
post #70 of 150 (permalink) Old 02-25-2011, 05:10 AM
RENDERMAN's Avatar
Sorry but this car looks like a Bullfrog on steroids, REVERT, REVERT!!
"I take life one pixel at a time"-RENDERMAN
Adobe Photoshop CC and Autodesk Maya Certified Instructor
WILL.I.AM
My work:
http://www.wilsart.com/
RENDERMAN is offline
post #71 of 150 (permalink) Old 02-25-2011, 07:40 AM
plastique999's Avatar
What specifically did u do to the tranny to handle 550 hp?
2011 Final Edition S260 Isotope Green
2005 Track Elise LotusCupUSA
2008 211 FS
plastique999 is offline
post #72 of 150 (permalink) Old 02-25-2011, 07:45 AM
robains's Avatar
+1 that's a good question, how are you making the tranny hold 500 HP for 1 hour race conditions?
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring." - Carl Sagan
robains is offline
post #73 of 150 (permalink) Old 02-25-2011, 06:50 PM Thread Starter
re: Tranny
So far I took low-cost road.
Treated stock gears.
Carbon clutch. these are easier on the engagement.
Torsen LSD. They put less heat in the oil and no limited slip additive is needed.
Tilton pump and cooler for tranny and RedLine fluid.
We will see what happens.
With Honda there is M-factory, Albins, PPG, Quaife and a few other racing boxes or gears.
I was told that REM treated stock will hold up to road racing.
Anton
post #74 of 150 (permalink) Old 02-25-2011, 11:33 PM
KazeSpec's Avatar
take a look at Gear-X for gears, and Kaaz or ATS if you want to upgrade your torsen to clutch type.
19-- Europa S2 62 Replica/Track Car Build
02 Suzuki GSX-R750 (daily/track) - current
03 Acura RSX Type S (daily/track) - sold
KazeSpec is offline
post #75 of 150 (permalink) Old 02-26-2011, 06:29 AM
doug_porsche's Avatar
On the wing. The old Can-Am look makes me think of the old Can-Am days.
Maybe its time to rethink the ideas of old. What about mounting the wing directly to the rear suspension, not the body?
Can-Am McLaren M8B - Profile and Photos by Pete Lyons
Apexes are a lot like relationships. So tough to get right, so easy to see where they went wrong.
The secret to a long life is ------- not dying.
doug_porsche is offline
post #76 of 150 (permalink) Old 02-26-2011, 11:03 AM Thread Starter
wing mounting
Mounting the wing to the suspension i.e. upper A-arms is the right way to do it, since the downforce is applied directly to the tires instead of springs. The amount of traction and downforce becomes unlimited.
Unfortunately, disallowed in all racing classes.
Anton
post #77 of 150 (permalink) Old 08-26-2012, 02:25 PM
Anton, whats new here? how is your car?
evo 11 is offline
post #78 of 150 (permalink) Old 08-26-2012, 07:32 PM
HKFEVER's Avatar
I just saw this is Hong Kong.
With my CF door and Hatch.
S240 Exige S with BOE FW300 + over 40 mods
HKFEVER is offline
post #79 of 150 (permalink) Old 08-27-2012, 11:25 AM
evo 11 is offline
post #80 of 150 (permalink) Old 10-09-2012, 07:58 AM Thread Starter
re: Progress
I am back in town and trying to finish the car to shake-down before the snow comes out.
Working on 2 problems:
1. Pulleys for oil pump and alternator. Almost solved...
2. Need smaller turbine housing. On backorder till Thursday?
The car makes good power at 20psi boost of 520whp. My target is 25psi, my power target was 500. It just comes on boost at 6500, my target was 5000.
The Honda motor runs pretty cool. With my rad and electric water pump and a single fan (the dyno shop's fan), we cannot get the water temp above 160. I am contemplating a thermostat
Final pics and power coming.
What initial setting should I run on Nitron 3-ways?
Thanks,
Anton
  LotusTalk - The Lotus Cars Community > Lotus Discussions > Lotus "Track" and Racing Cars
