After a number of starts and stops along the way I have finally got my car on the Dyno and hopefully be able to start track testing early in the new year, albeit without a body .. but hopefully that will follow by March / April as I still have a good amount of work to complete.
Anyway thought I would post up some information and pictures of the car as it stands now.
I have taken a lot of information from LT, so hopefully this gives something back.
Its certainly been a learning experience and at times frustrating especially when I think what is a brilliant idea turns out not to be and hours of work can suddenly go down the drain… but the second version [or perhaps the third!!] usually gets it sorted.
The car started out as 2003 Elise 111S that came OEM with a Rover K engine . I purchased the car in the UK after it had been fitted with a Honda K20. The kit used for the install was a Linkup conversion that was developed Simon Scuffham . Some of you will recall Simon with his somewhat abrupt manner but undoubted knowledge of the Lotus Platform.
The plan from the start was always to completely strip the car down to bare chassis and rebuild as required using race worthy parts wherever possible.
As can be seen from the spec list not much of the original parts remain.
I wont go into full details , but here’s an overview.
The K20 was built to upgraded parts specs to cater for the SC but is basically a stock engine, head is not worked etc. Compression was set at 10.7:1
Fitting a dry sump to the K20 turned out to be major project in itself as there is hardly any room to work with and had to employ some seriously low profile fittings that screw directly into the body of the dry sump to make it work.
Initially I had planned to run a Jackson SC with Charge cooler … a kit developed by Simon but after much research I decided to go with TVS1320SC [same as BOE Rev400) and joined forces with Innovative Motorsport Technologies to develop a kit that would employ charge cooling and also fit the tight engine bay area. IMT did a great job and the quality of the build is 5 star.
Have a look here for more detail: 1320 TVS
I have developed a charge cooling system that employs 3 x Rads, 2 take up the position of the OEM oil coolers and the other sandwiches with the main engine Rad and utilizes 2 x Pierburg CWA50 pumps . System is run in series and flows “plenty” of water.
Using the Pro Alloy [seriously good quality parts and great service] cooling kit that places the Rads [engine & CC] further forward and more upright, plus approx 20% larger surface area. So far on the dyno IAT results have been great but that’s a fair way off the track so will see how it goes then.
Sequential gearbox is from Elise parts [ as are many other parts, big shout out to the team at EP , fantastic parts and service ... rear these days ]
At present I am using a gearlever but the plan is to go Paddle shift at a later date once the car is sorted.
Flatshift is run by Gearlever knob strain gauge and the Motec M1 ECU takes care of the shift.
I have used Motec throughout ECU – M150 / Power Distribution - PDM30 / E888 Expansion Box / Motec keypad
Not by any stretch of the imagination am I an “electrical” guy, I get the basics ok but the in-depth stuff is beyond me. Install of the “electronics” was left to the local tuning shop to get everything installed and talking to each other . The entire loom was a bespoke build and very high quality. [ yes you can read “expensive” into that !]
I have gone with Elise Parts 4 pots on the front with 330mm discs and on the rear is AP 4 pots wit 308mm discs . Also running the Pillbeam pedal box with bias bar. Late in the build I could not resist installing the Bosch M4 Race ABS system after using it in another car .. fantastic. It will be interesting to see how the brakes work as I have a feeling they may be a bit oversized , but hopefully the ABS will sort it out … plenty of testing to be done.
Roll cage was made from Chro-moly to keep the weight down . Hopeful final weight will be around the 700- 730kg mark , not including driver.
Initial tuning on the Dyno has given 411Whp [DynaPak] and xxx Torque and produces this at 12.4psi boost . SC revs are 15800RPM at Redline. Engine has been built to go 15-17 psi so still a bit to find but will keep at this level during testing.
Currently running on 98 Octane pump fuel that we have here in NZ [ about the same as your 95 I suspect] with an Increase in boost may look to go with E85 but the extra fuel consumed may be an issue in Enduro races.
Its 50-50 these days if I enjoy the building or driving more these days, but certainly looking to having the car on the track and see if it measures up to expectations .
Please feel free to ask any questions and I will do my best to answer .
Donor Car
2003 S2 Elise 111 [ OEM with Rover Engine]
Chassis / Suspension /Steering
Elise parts [EP] GT uprights heavy duty bearings
EP T45 Wishbones with spherical bearings
EP Steering arms
Nitron 3 way 46mm shocks / Springs 650F / 850R
EP Anti roll bar with Adjustable Links *
EP Quick Turn steering Rack – 2.45 turn
Bespoke Alloy Steering Arm
Woodward Steering Brackets
Roll Cage
Bespoke Chro-moly Roll cage to NZ Motorsport Spec
Braced Rear Sub frame
Brakes:
Caliper Front: EP 4 pot Calipers
Caliper Rear: AP Pro 5000 4 pot Rear Calipers
Disc Front: AP 330mm discs*
Disc Rear: AP 315mm Discs*
Brake Pads: Pagid
ABS :Bosch M4 Race
Pedal Box: Pilbeam with Brake Balance Bar and separate AP master cylinders for Brakes and Clutch
Aeroflow SS hose
Aeroflow Fittings
Engine
K20A Engine / Type R
OEM Head
Toda Forged Pistons 10.7:1
Toda Rods
K20 Cams Type R
Toda Tensioner & Toda HD chain
Competition Clutch Light flywheel*
Exedy clutch
Aviaid Dry Sump Pump [bespoke build for Lotus Fitment]
Peterson Remote Filter / Primer
Laminova Oil Cooler [ Dual Laminova – shared with gearbox]
Aeroflow SS hose
Aeroflow fittings
Chris Tullet UK 4-1 / 3”
BOE QS Muffler [with additional small mufflers inline to reach 96db]
Supercharger
TVS1320 SC with bespoke Charge cooler and Manifold. Developed in conjunction with Innovative Motorsports Technology
DBW J37 Honda Throttle Body
Merc Racing Tensioner
Gates Belt
Cooling - SC / IAT
Innovative Charge Cooler
Pro Alloy Vertical Mount CC & Engine Radiators
2x x Pro Alloy Side Rads
2 x Pierburg CWA 200 pumps for CC Rads / M1 ECU controlled.
Aeroflow Silicone Hoses
Gearbox
Elise Parts 6 speed Sequential and drive shafts
Sadev Sequential shifter with Adjustable Rod connection to gearbox.
Motorsport Solutions Gearlever Knob for Flat shift trigger
Laminova Oil cooler
EP Gearbox & engine mounts*
Aeroflow Oil Filter
Aeroflow SS hose and Fittings
Electrical
Bespoke Mil-Spec wiring loom with Quick disconnect plugs
Motec M1 ECU with required upgrades to run Flat shift & traction control
Motec PDM 30 Power Distribution
Motec Keypad
Cooling - Engine
Pro Alloy Vertical Mount CC & Engine Radiators / modified to suit S2
1 x Pierburg CWA200 pump for Engine cooling / M1 ECU controlled
BOE pressurized Header Tank
Cooling - SC / IAT
Fueling
Pro Alloy 60L tank
98 Octane [approx 95 octane USA]
Bosch 750cc injectors**
Hybrid Fuel Rail modified to suit.
Turbo solutions Regulator.
Honda J37 DBW Throttle Body
BOE Surge Tank
Aeroflow S/S Hose
Aeroflow Fittings
Aeroflow Filters pre & post Surge tank
Sensors
Throttle
Steering
Brake Pressure
Water Temp
Water Pressure
Oil Temp
Oil Pressure
Fuel Press
Fuel temp
Fuel Mixture
Air Temp Ambient
Inlet Temps – IAT
Charge Cooler Temps – [In and Out]
SC Boost
Manifold / Vacum Pressure
Gearbox Temp
Gearbox Press
Plus – Batt V / G Force
Bodywork
Exige Rear Clam / lightweight Fibre-glass
Elise Front Clam OEM
Font splitter / Lightweight Marine Plywood.
Bespoke Kevlar / Carbon Bulkhead between Engine bay and cockpit
Oversized Side scoops
Bespoke rear diffuser
Bespoke side sills*
Bespoke Canards
CF wing mirrors
CF rear wing
Wheel Arch Louvres F&R
Wheel Arch Flare Kit F&R
Wheels /Tyres
Braid Wheels Full Race 7”x16 ET25 / 8.5”x17 ET5 [TBC after testing]
Dunlop Slicks 200/580 x16 / 235/610x17 [TBC after testing
Wets – Tyres and Rims TBC
Interior:
Tilley B7 CF Seat FIA certified
Schroth 6-point Harness for Hans
Sector 111 seat mounting kit
Modified Standard dash and air Intake system
Rear Vision Camera [ to replace mirror]
Lifeline Zero 2000 4L Electric plumbed in fire extinguisher
Lifeline QR QR boss
AP Air Jacks
AP Lance and connector
Motec V2 Camera
Excuse the close up of the starter motor , that wasn't supposed to be there !!!
Donor Car
EP Steering arms
Roll Cage
Brakes:
Brake Pads: Pagid
ABS :Bosch M4 Race
Aeroflow SS hose
Aeroflow Fittings
Engine
OEM Head
Toda Rods
K20 Cams Type R
Exedy clutch
Aeroflow SS hose
Aeroflow fittings
Supercharger
Gates Belt
Cooling - SC / IAT
Gearbox
Laminova Oil cooler
Aeroflow Oil Filter
Electrical
Motec Keypad
Cooling - Engine
Cooling - SC / IAT
Fueling
Pro Alloy 60L tank
BOE Surge Tank
Aeroflow S/S Hose
Aeroflow Fittings
Sensors
Throttle
Steering
Brake Pressure
Water Temp
Water Pressure
Oil Temp
Oil Pressure
Fuel Press
Fuel temp
Fuel Mixture
Air Temp Ambient
Inlet Temps – IAT
SC Boost
Gearbox Temp
Gearbox Press
Bodywork
Bespoke side sills*
Bespoke Canards
CF wing mirrors
CF rear wing
Wheels /Tyres
Interior:
Lifeline QR QR boss
AP Air Jacks
Motec V2 Camera
