Reverie large front Splitter with OEM Exige wing? - LotusTalk - The Lotus Cars Community
 1Likes
  • 1 Post By difflow
post #1 of 11 (permalink) Old 08-08-2016, 02:41 PM Thread Starter
qz5gxt's Avatar
On my first track day with my Exige S my front end felt loose/light on high speed straights and I would like more downforce. My last high hp track Elise had a large front splitter and the large Reverie 1300mm rear wing and was amazing downforce and felt so much more planted.
I am considering getting the Reverie larger front splinter but wondering if anyone has done this keeping just the Exige OEM wing?
This is the splitter I am looking at;
Exige S2 front spoiler / splitter, carbon (with clamshell hump clearance cut-outs). | Front Splitters | Reverie
My Exige is 50% corner balanced
120mm frt 125mm rear height
zero toe with 2.0 camber front and 2mm toe in with 2.5 max camber rear
Track pack suspension (just order BWR Penske’s)
Current 2007 Exige S TOURING PACK, TRACK PACK, LSD, Aspen White, BOE Torque300, Tank,2bular muffler, Larini header/Decat, RLS Intercooler, Intercooler Vent Ducts/tubes PENSKE SINGLE-ADJUSTABLE SHOCKS, CUPdiscs-Front ULTRAdisc rear, Lotus AP 4 Pot Calipers, Fidanza lightweight flywheel, ACT HDSS Clutch......way too much to list..
Past 2014 Arial Atom
Past Lotus- 2005 Elise, BOE REV400TVS,Nikasil SB, Arias pistons,....et cetera-track monster
qz5gxt is offline
post #2 of 11 (permalink) Old 08-08-2016, 03:14 PM
acslater's Avatar
OEM Exige wing is garbage and should be replaced, too. But the ReVerie splitter is primo. I have one on my car and there really isn't a better option out there as far as plug-and-play. As far as wings go, get something clamshell mounted with support to the frame e.g., Reverie or APR versions. The Reverie has a better df/drag ratio, but the APR is an excellent value.
In between getting the splitter and the ReVerie wing, I did a few events with just the front splitter and it was definitely an improvement, but with the wing too everything just feels more balanced.
acslater is offline
post #3 of 11 (permalink) Old 08-08-2016, 04:28 PM
The Enforcer
oldmansan's Avatar
To clarify, both the early Exige rear wing and the 2010 style rear wing are garbage. They flex like wet noodles. The exception is the carbon 2010 wing that is extremely expensive. I bought HKFever's 2010 style dry carbon wing as the APR and Reverie giant wings aren't my cup of tea. For track use I have no doubt they are very effective.
San
oldmansan is offline
post #4 of 11 (permalink) Old 08-08-2016, 06:07 PM
JGalt's Avatar
You should have a Reverie rear wing if you are going to run the Reverie front splitter on the track. Look at this downforce data (link below) and you'll see that the Reverie front splitter increases downforce by more than twice factory. So keeping that fakey-do OEM rear wing is going to result in very significant oversteer.
I run Reverie splitter, canards, and rear wing and am quite pleased with the track performance, but a bit poorer because of it.
http://www.sector111.com/images/prod...erie_wings.pdf
JGalt is offline
post #5 of 11 (permalink) Old 08-08-2016, 06:12 PM
acslater's Avatar
I wouldn't say the front splitter with the OEM wing resulted in significant oversteer at all, and I'm running canards, too. Then again I also had Nitron triples at the time that were properly setup
acslater is offline
post #6 of 11 (permalink) Old 08-08-2016, 06:44 PM Thread Starter
qz5gxt's Avatar
Next week I will have BWR SA Penske's on with 500/700R springs to help with any potential oversteer. V2 Motorsports is local for me and Ralph does my final suspension and corner balance set up after I get it close.
qz5gxt is offline
post #7 of 11 (permalink) Old 08-08-2016, 08:07 PM
acslater's Avatar
I say go for it. And you're gonna love the Penskes, but of course you already know that
acslater is offline
post #8 of 11 (permalink) Old 07-25-2017, 07:44 AM
VTLotus's Avatar
ACSlater
What wing are you running?
VTLotus is offline
post #9 of 11 (permalink) Old 07-25-2017, 08:03 AM
acslater's Avatar
Originally Posted by VTLotus View Post
ACSlater
https://www.reverie.ltd.uk/product_d...code=R01SB0160
ReVerie single 225mm chord 1650mm width with their high level wing support legs
https://www.reverie.ltd.uk/product_d...code=R01SB6039
acslater is offline
post #10 of 11 (permalink) Old 07-25-2017, 08:38 AM
kfennell's Avatar
Front splitter without the wing is going to be better than nothing because the car understeers a ton stock. Just the gains under braking are worth getting the front splitter.
If you do want a real wing I have a carbon HK fever adjustable for sale ... moving up to the reverie frame mounted from BOE.
kfennell is online now
post #11 of 11 (permalink) Old 08-08-2017, 08:34 AM
Licensed Driver
difflow's Avatar
An Exige 5 Element Rear Diffuser would help add downforce and reduce your drag from rear-air-swirl on the track as well!
qz5gxt likes this.
difflow is offline
  LotusTalk - The Lotus Cars Community > Lotus Discussions > Lotus "Track" and Racing Cars
