Wheel Liners? - LotusTalk - The Lotus Cars Community
 2Likes
post #1 of 23 (permalink) Old 07-28-2011, 12:09 PM Thread Starter
erubin's Avatar
Wheel Liners?
Anyone running their car without wheel liners. I have worn holes in all 4 of my liners and would prefer to just remove them all together? Any concerns?
2007 Lotus 255 Cup, AP BBK F&R, Innovative mounts, RLS CF Intercooler heat shield, Railer diffuser, Custom hood Pins, gPan, Saikou Michi oil cc, RLS AL Intercooler tubes, Radium FST, 2Bular GT3 8X24, RLS suplemental IC Scoops, APR canards, CF rear wing, CF Scoops, Radium Fuel Rail and AN fuel pump adapter, AN fuel lines, 2bular decat and headers.
erubin is offline
post #2 of 23 (permalink) Old 07-28-2011, 12:27 PM
DeanG's Avatar
The stones thrown up by the tires hit the part that was protected by the liners and make little stars on you paint.
DeanG is offline
post #3 of 23 (permalink) Old 07-28-2011, 07:04 PM
metrocube's Avatar
Yes. Road debris will start hitting the stuff that used to be protected by the wheel liners.
Just live with the holes.
metrocube is offline
post #4 of 23 (permalink) Old 07-28-2011, 07:07 PM Thread Starter
erubin's Avatar
Thanks for the input. I will just let them be.
erubin is offline
post #5 of 23 (permalink) Old 07-28-2011, 07:28 PM
MotoGeek's Avatar
I just had one of my fronts fall apart. I was considering strategic placement of stick on foam padding on the inside.
MotoGeek is offline
post #6 of 23 (permalink) Old 07-28-2011, 08:20 PM
metrocube's Avatar
My front right one fell apart because all the fasteners had popped out on the track. Replacement cost me about $50. Replacement hardware cost me another $20 or so, but that $20 bought me enough hardware to replace 25 OEM wheel liner fasteners with more secure versions. I love Mcmaster-Carr.
neight likes this.
post #7 of 23 (permalink) Old 07-28-2011, 08:55 PM
shay2nak
shay2nak's Avatar
black duct tape
'07 Lotus Exige S310
WTC 2
shay2nak is offline
post #8 of 23 (permalink) Old 07-28-2011, 09:01 PM
metrocube's Avatar
Originally Posted by shay2nak View Post
black duct tape
I did that, actually. I made my own wheel liner out of gorilla tape while the replacement was being shipped over from the UK.
Unfortunately, because it's not rigid, the wind that passes through your oil coolers will billow your duct tape to the extent that it will begin to rub on the tires.
The result of this is that your wheel will become absolutely coated in black, melted, vaporized tape particles that will take about 4 hours to clean off to get to the 'yeah, that's good enough for now' stage.
So, I would advise other owners against this.
post #9 of 23 (permalink) Old 07-29-2011, 06:03 AM Thread Starter
erubin's Avatar
I was thinking about some type of foam liner as well. I have access to very high temp foams that would not melt. Since my car is a track only car it would be nice to be able to easily inspect my suspension at the track. I have also had one of my liners come lose and rub my wheel during a sessions causing me to pit. I am also considering adding the Reverie vents to my wheel wells so I would need to vent the liners as well.
erubin is offline
post #10 of 23 (permalink) Old 07-29-2011, 07:13 AM
apk919's Avatar
2-Elevens don't have wheel liners, and if anything... their clams are even thinner. On my 2008 2-Eleven, I "tiled" the inside of the wheel well with rectangular dense foam rubber pads, about 1/4" thick. So far I haven't had any cracks in the clam.
apk919 is offline
post #11 of 23 (permalink) Old 07-29-2011, 08:08 AM
MaineLotus's Avatar
I made my own liners out of slightly thicker ABS plastic. A good option if you want to position liners to avoid rubbing.
My car is modified.
www.lotussport.org
MaineLotus is offline
post #12 of 23 (permalink) Old 07-29-2011, 12:33 PM
carphoria's Avatar
I have worn holes in all 4 of my liners ... Any concerns?
What do you think it would hit if you didn't have the liner?
Creating your own is a good option, or look on the wrecked forum, see if you can nab a set from a FUBAR'ed car.
2006 Exige KoldFire270 Bought in 2010 - Sold in 2014 - Bought again in 2018
Other Toys SOLD
2006 Elise "Toothless" FIRE=TOTAL LOSS
carphoria is offline
post #13 of 23 (permalink) Old 07-29-2011, 01:35 PM
Butters's Avatar
I've always wondered why these cars always wear through their wheel liners. My Exige has the same issue. I'm at stock ride height and stock wheel/tire size.
2007 SUZUKI SV650 Track bike.
Butters is offline
post #14 of 23 (permalink) Old 11-15-2011, 07:56 AM
Subarubrat's Avatar
I ditched my rear liners after running a few thousand miles without them after doing the clamhinge. I have yet to get any marks or chips even on the underside. The gravel seems to accumulate rather harmlessly at the rear of the clam's wheel well.
Like classic video games and pinball, check out the Retrogaming Roundup Show, available on iTunes and our own website.
Subarubrat is offline
post #15 of 23 (permalink) Old 11-15-2011, 08:30 AM
zygotesoup's Avatar
I have a brand new FR wheel liner for an exige if anyone is interested. I thought the elise and exige liners were the same, but no dice.
2005 Krypton Green Lotus Elise
1993 Black BMW 325i
zygotesoup is offline
post #16 of 23 (permalink) Old 10-13-2012, 08:55 PM
Gripp's Avatar
Whats the part number? I am looking for fronts...keep in mind the fronts are two parts front and rear. I looking for both rear parts of the front liners... thanks
Exige S 07... ReVerie Rear 1650mm wing, CF 3 element diffuser, Front Exige flat bottom splitter, Craftsquare CF Side Mirrors, CF Exige Side Scoops, ,CF Binnacle, CF Center Console, CF Side Skirts & CF Canards on order.
Arqray Twin Muffler, ACT Clutch, Findanza Flywheel, Schroth PROFI II ASM Harness for Hans, WorksBell Rapfix II Quick Release, re-ENFORCER, ULTRAdisc-Front & rear,Nitron Sport PRO, Pagid RS14 , LSS RIMS Powder coated, stellaCORSE Wheels Street Ducati , R1-LE
Gripp is offline
post #17 of 23 (permalink) Old 10-16-2012, 08:50 AM
One thing to watch for. I was running without a liner on the left-rear and the wires to the tail lights worked their way down and got completely workn through by the tire (I had installed a BOE surge tank.) So if you do some non factory solution, make sure your wires are secured and out of the way.
ddurham is offline
post #18 of 23 (permalink) Old 12-03-2012, 06:25 PM
Gripp's Avatar
Any chance you can post a few more pictures?
I am considering louvers myself..tired of liners.
Where did you get the foam pads?
Gripp is offline
post #19 of 23 (permalink) Old 03-03-2017, 01:12 PM
purveyor of lightness
darkSol's Avatar
Holy Thread Resurrection Batman!
Also thinking about doing this as I'm SICK and TIRED of replacing the damn FRONT liners.
Peectures!
d.a..v...i....d
David Thomas Stewart - [email protected]
2005 Midnight Silver Lotus Elise (www.darksol.com)
388hp (342whp) BOE RevX 1736lbs.
darkSol is offline
post #20 of 23 (permalink) Old 03-03-2017, 02:59 PM
cyow5's Avatar
Peectures!
The tiled foam seems like gold. Looks like that'll probably be the route I go since the last horrible, awful shop that worked on my car didn't reattach the bracket for one of the liners, so it always rubs.
cyow5 is offline
  LotusTalk - The Lotus Cars Community > Lotus Discussions > Lotus "Track" and Racing Cars
