Electric Quirks on 1986-88 Esprits w/ Bosch CIS K-Jetronic Injection
24 ohms, connected to ECU pin 12 which goes to the LOW TEMP sensor. Pin 12 is grounded by the sensor until temp is greater than 25C which enables the choke function equivalent in the ECU
I also have a spare (that's not for sale ) but note that its the same module fitted to the M100 Elan and over on the LEC forum somewhere it was discovered that this was fitted to several GM cars of the period (85 to 95) so they are still available, should you want to replace not repair
Thank you Van for this insightful investigation and a repair procedure.
Fri Mar 17, 2017 7:36 am (PDT) .
Posted by:
"Van Overhouse" van_overhouse
For 86-88 MY cars with the Bosch CIS system the green ECON light should come on steady while off throttle and in overrun condition. In two cases now I've seen that the light blinks rather than remain on. I traced this back to a bad "Speed Sensing Module" which I replaced the first time. Now that I've seen the problem a second time I decided to try and fix the Module rather than buying a new one. The first step was to do some reverse engineering and generate a schematic for the Module. I've posted the schematic at Turbo List files/tech/electric .
What I found was that either the Module design has an error or the Lotus application is incorrect. Within the module there is a 750 ohm 1/4W resistor connected between pin #15 (V+ from RPM Relay) and terminal #31b going to the Thermal Time Switch. During warm up, terminal #31b is grounded by the Thermal Time Switch until the water temperature reaches 35C. During this period the 750 resistor has 14.5V across it which generates (14.5*14.5/750= 0.3W) watts which is greater than the resistor specification allows. Once up to temperature the ground is removed and the power drops to about .13 watts. This extra stress on the resistor eventually causes it to fail.
In addition, the 750 ohms is too large a resistor and current flowing through it and out to the thermal time switch is causing too much voltage drop. The voltage at the node with the 750 ohm (?), 27K and ITT diode is too low to turn on the BC547 transistor. Making the resistor smaller will raise this voltage to the acceptable level.
?What would be the smallest 1/4W resistor you could use to replace the 750 ohm (R= E*E/P).
So if you put in a 1W resistor that would be 316 ohms you're be fine. I'd replace it with a 330 ohm, at least 1/2 W resistor.
After replacing the resistor, the relay module should not fail again.
If you have a blinking Econ light and want to quickly test if you have the same problem just disconnect the Thermal Time Switch connector once the engine is up to temperature. If the Econ light no longer blinks you most likely have the same problem. If you do have this problem you should fix it as it is also pulsing the air bypass valve which will wear it out prematurely. Don't throw away your old Speed Sensing Modules they are repairable and we may need them some day.
Module: It's the one with the black base and you should see the Bosch part number 0 280 230 103 on the case [back wall, above the coil]. I didn't replace the Ecap on the PC board since I tested the module on the bench. Probably should have replaced it with 35V or 50V cap. Hopefully, it doesn't come back to bite me.
After thinking about the error I believe it must be the Lotus application of the module that is incorrect. Also, I believe that pretty much every Lotus module out there has a "750 resistor problem".
The original resistor looks to be a ceramic thin film resistor and the failure mechanism for this type of resistor is when it overheats is for the resistance to increase (if it doesn't fail outright like a fuse).
Once the resistance becomes high enough, it will no longer overheat. In some cases the higher resistance is not sufficient to cause the circuit not to work. In other cases it is too high and the module fails with the blinking ECON light syndrome.
Yes, I believe there is an error in the [Overspeed Module] design. There is a "B" revision (B082M6374) which may correct the problem but I'm not sure since I dissected the "A" rev part.
The failure symptom is after driving the car and you park it hot and leave it for 10-20 minutes it will not start. If you wait for an hour or so and it cools down it will start.
The problem, I believe, is that humidity is collecting around R6 (2.2Meg ohms) and lowering its resistance. The specification for the TC4538 says that the maximum resistor value allowed is 1Meg (!). If you look at the bottom of the schematics you can see a note where I changed the value of R6 to 220K ohms and C4 to 1uf. Other values which result in the same time constant (R6 X C4=220ms) would also be OK. After replacing these parts I've never had the problem reoccur.
C4 and R6 are soldered directly to the pins of the IC! Yikes!
If you try to de-solder them, you're may overheat the IC chip.
Solution:
Crush C4 to expose its conductors sticking up above the board and solder the new cap to them. Resistor can be replaced in the same way.
Note: Tantalum caps have polarity! The + leg is always longer.
"While you're there", replace the 22uF electrolytic cap (large, blue) with a fresh 50V rated part. After 15 years they can fail any minute and their 16V rating may cause a bad day for you.
There are electrolytic capacitors in every Engine Management Module/PC board on our 86, 87 and 88 Esprits.
Like all components, electrolytic capacitors eventually do wear-out. Unfortunately, their lives are relatively short (~15 years) compared to other components in the system. Capacitor is essentially an electro-chemical device, hence increased temperatures accelerate the chemical reaction rates within the capacitor. Environmental factors include temperature, humidity, atmospheric pressure and vibration. Electrical factors include operating voltage, ripple current and charge-discharge duty cycle. Among these factors, temperature (ambient temperature and internal heating due to ripple current) is the most critical to the life of aluminum electrolytic capacitors.
OEM capacitors are rated 16V, which (in real life) is inadequate.
Continuous application of excessive operating voltages will rapidly increase the leakage current. Internal heating and gas generation caused by increased leakage current may destroy the capacitor.
Other modules also have these dreadful caps inside. Replace them all.
The old OEM cap(s) should be replaced by modern electrolytic capacitors (rated 50V) of the same capacitance value.
Over the last weekend my Esprit failed on me. My son was driving it and it just cut out. My first thought was to jump both fuel pump relays but that did not work. I believe the 86 and 87 HCI turbo may be slightly different from the 88. The EOM and fuel pump module are one unit.
My car died on me at a set of traffic lights, the garage told me this fuel pump overide module is not putting out 12volts to drive the fuel pump. Can I bypass it and go directly to the pump with the 12volts
www.lotustalk.com
Related Threads
The Lotus Cars Community
2.7M posts
51.4K members
Since 2002
