1987 HCI starter wiring - LotusTalk - The Lotus Cars Community
post #1 of 4 (permalink) Old 06-26-2017, 02:18 PM Thread Starter
Billy
I'm getting closer and closer to putting my esprit back together. I have a question about starter. On the main battery terminal how many wires go to that? I know I have red from battery and a brown from the alternator. But there are also two other wires. Another big red one like the battery wire and a brown like 10gauge wire from the harness. So are there 4 wires going to the positive starter terminal? I'm doing away with distributor and coil so is there wires I can start disconnecting as well. My car by the way is an 1987 HCI turbo. Thanks in advance.
rollingzep is offline
post #2 of 4 (permalink) Old 06-26-2017, 05:30 PM
Project Addicted
Jcslocum's Avatar
Here is a picture of my 1984. It has 3 heavy wires going to it. I changed the brown one from the alternator to a much heavier gauge wire. One from the battery and one to feed the car electrics.
Jonboy
1984 Esprit Turbo "Vivian"
Jcslocum is offline
post #3 of 4 (permalink) Old 05-24-2019, 05:39 AM
Integrator
MRDANGERUS's Avatar
Esprit Alternator Wire
[QUOTE=Jcslocum;5461962]Here is a picture of my 1984. It has 3 heavy wires going to it. I changed the brown one from the alternator to a much heavier gauge wire. One from the battery and one to feed the car electrics.
Changing from the brown 12GA (?) wire to 4GA is a very prudent step to prevent eventual fire.
Congrats on your 90 deg oil filter adapter install.
MRDANGERUS is offline
post #4 of 4 (permalink) Old 05-24-2019, 06:32 AM
You might still want a short section to be 12 ga to act as a fusible link. Be sure to keep the wire away from anything that could damage and short it out like sharp corners and hot surfaces.
David Teitelbaum
jtrealty is offline
