87 Esprit - narrower rear tires with OEM rear track? - LotusTalk - The Lotus Cars Community
post #1 of 1 (permalink) Old 04-06-2019, 02:01 PM Thread Starter
sleekgt's Avatar
Iím looking to use run flat tires ( apologies but letís save the heresy discussion for later )
Issue: the widest tire I am constrained by the 16x7 BBS Mahle wheel ET 11 is 215/55-16 (OEM is 235/60-15). Thatís 20mm narrower.
Narrower tire will result in oversteer (if OEM offset of ET -20 maintained.
But - if I create a wheel adapter of 20 + 11 (wheel ET) + 10 ( 1/2 of the 20mm narrower tire), that means:
1. Outer tire edge is exactly where the OEM tire would be rear-track-wise
2. Inner tire edge is narrower and 20mm further away from car center.
3. Rear track is the same; contact patch is 20mm shorter on each side.
Question:
1. Did I reduce the oversteer possibility moving the offset out 10mm?
2. What handling issue do I introduce with with this combination of skinnier tire maintaining rear track?
Cosmetically Iím less concerned about the skinny tire look. I have 245/45-17 currently.
Part of me said mucking with suspension geometry is bad but Iím trying to compromise. because my available wheel choice is 16x7 and if I had 16x8, it would be easier solution.
Eddie B
87 Esprit 'SLEEK GT'
sleekgt is offline
Similar Threads
87 Turbo Esprit clunking noise rear driver side sleekgt Lotus Esprit 6 03-21-2019 11:18 PM
87 Esprit rear Girling vs. Bendix discs sleekgt Lotus Esprit 3 12-24-2017 05:53 AM
'85-87 G-Esprit Tires Available as of March 2016 (Caveat Emptor!) greentengu Lotus Esprit 3 03-14-2016 06:32 AM
Just ordered the Continental Extreme DWS tires for my '87 Esprit... s2mikey Suspension (including wheels, tires, brakes) 3 08-05-2011 06:08 AM
WTB: 86-87 Esprit or 88-92 Esprit s2mikey Lotus Cars Wanted 0 07-02-2010 04:49 AM
